Originally Posted by
Puddin Tane
Until the engine warms up to the coolant's BP, having the cap off is fine, assuming no trapped air.
I agree with that, A story for the readers below.
Puddin Tane
The coolant inside the engine will suddenly become steam, as with mine, but that phase change absorbs a huge amount of heat, instantly cooling the cylinders and head enough to prevent damage. The damage happens when the engine keeps running after boil-off; the more tuned the engine and the higher it's revved, the faster the disaster.
My experience from holding a radiator hose while releasing pressure is a sudden
increase in the temperature of the hose. I'm not clear about the thermodynamics of latent heat, etc., but it is easy to demonstrate this phenomenon.
Years ago, in an Audi 5000, I was not sure if the scenic two-lane highway was the correct way to the main freeway which must be miles away (pre GPS and no map). My wife suggested asking at the motel we were approaching, so as I started to go into their office, some guys walked past and one said "your car is leaking". Expecting condensed water from the AC at worst, I turned to see steaming hot coolant splashing below the engine. Moving the car to the far corner of the lot, expecting a hose clamp or something fairly easy, I could see that the coolant pump seal had blown. I told my wife to see if they had any room in the motel; she comes back telling me that they had one left but "it's $95 a night"! I told her to go sign us up, that we weren't going to sleep in the damn car.
The next day I finally reached my mechanic friend at home, and explained the dilemma. He said "so why didn't you just drive it home"? I re-explained that the coolant was dumping out of the pump's seal vent, to which he said "fill it up with water, leave the reservoir cap off so it doesn't pressurize, and drive it home! I can't believe that you didn't think of that"! "Won't it boil over without the cap?" I asked. "No, not as long as you just cruise at the speed limit". So we walked to the local store, bought jugs of water, and started down the road. First I stopped to check after a mile- water was still right near the filler opening. Then getting braver, went five miles; same thing. I ran the heater just in case, with windows open. A little uncomfortable, being a warm day, but absolutely no problem driving over 100 miles home.
