Results 1 to 23 of 23
    Dec 11 2014
    modesto ca
    what software for k26 turbo?
    As title states. Any one make a file for k26 or similar? Plan on swapping out the old k03. My ecu is unitronic stage 1 for the KO3. I have a Hi flow manifold for the k26 already. along with the 3" DP, FMIC etc. Any help would be much appreciated. Just trying ro figure out how to get this thing tuned.
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    So you have an exhaust manifold that will bolt up to your k26? I would say you will need something custom for your tune. Closest would be a gt28rs tune.
    '02 1.8TQ - Daily sold
    '05 Colorado Z71 Crew Cab
    STEVE
    Dec 11 2014
    modesto ca
    Quote Originally Posted by viceprp View Post
    Yeah i have a ATP manifold that bolts up to it. And that was what i was thinking as well.
    Another question i had was is the KO3 oil cooled? I beleive my k26 is water cooled. Im assuming its not hard to throw in come water lines?
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    K03 is oil lubricated and coolant cooled.
    What year is your car? There are different tuning options available depending on ECU / sensors.
    2001 Corvette (C5) Z06
    Dec 11 2014
    modesto ca
    Quote Originally Posted by MetalMan View Post
    Okay good to know. Its a 96 Quattro. Originally a 2.6 v6 swapped in AEB unitronic stage one ecu done by 034.
    What injectors are on a gt28rs tune?
    Dec 11 2014
    modesto ca
    The AEB is a 98
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Quote Originally Posted by spoolboyq12 View Post
    Injectors will depend on which tune you pick.
    For AEB I would suggest the United Motorsports Stage 3 tune. It runs well with just about any turbo from K03/K04 up to GT28R or larger. This particular tune uses 630cc injectors at about 3-3.5bar fuel pressure, and a 3" MAF housing with stock MAF sensor (like the MK3 VR6 MAF housing).
    A member here is selling his UM Stage 3 tune right now, actually. The tune when new goes for $600 by itself, and the MAF housing would normally go for at least $50 new. So his asking price looks like a good deal to me!
    http://www.audizine.com/forum/showth...ilter-for-sale
    Jun 10 2010
    2Bennett sells an EM/DP for K26s on 1.8Ts. They can probably help you find a tune.
    Dec 11 2014
    modesto ca
    Thanks for the help man much appreciated. And damn that is a good deal too!! If my tax return was in i would hop all over that. Cant wait to throw this k26 on so pumped. And as far as clutch upgrades go anyting required for that sort of tune? All i have is lwfw
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    You're definitely going to need a clutch to hold the torque. There are lots of options, one of the more popular and reasonably-priced options is the ECS Tuning RA4 Stage 1, which is basically a stock B5 S4 clutch with custom steel flywheel. I think that would be strong enough for you.
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    A K26 is going to be mega lag on that turbo. Its not really a good turbo for the 1.8t. Heck even the 2.2 are laggy with it.
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Veteran Member Four Rings ray4624's Avatar
    Nov 27 2010
    mass
    if its an AEB, you should buy my UM stage 3 tune and MAF in the classifieds.
    edit: thanks metalman!
    OP shoot me a pm, i can wait until your taxes get back haha
    Jun 10 2010
    Quote Originally Posted by nynoah View Post
    I'll have to agree.
    Jan 16 2006
    LA CA
    Seriously the K26 is old tech and not fit for any engine bellow 2.5 liters. If you own one, just ebay it and put your funds towards a franken turbo.
    Dec 05 2007
    Water and oil cooled, using oil to lubricate the bearings. Oil being run through the turbo has no way to avoid cooling it down.
    Dec 11 2014
    modesto ca
    Quote Originally Posted by ray4624 View Post
    Definitely interested. Ill have to get back to you on that. See how the money situation turns out .
    Dec 11 2014
    modesto ca
    I was thinking the same. But also the thought of the comparison to a gt28 came to mind. How much different are the two? Gt28 is bigger?
    Nov 27 2010
    mass
    roger that,
    for reference, the tune will work for anything from a k04 to a 2871 and is good for just under 300 horsepower with the right turbo etc
    Dec 11 2014
    modesto ca
    roger that,
    Fuck!. I want to buy it so bad! Wish i had the cash. Where are you located?
    Nov 27 2010
    mass
    Massachusetts.
    I'm not really in a rush. It was an awesome tune, i just went bigger as i am building my bottom end.
    Dec 11 2014
    modesto ca
    Massachusetts.
    Sounds good. You how the 28 series compares to the k26. Just wondering what rpm will the k26 hit full boost
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Once the oil is past 200 deg. F or whatever, I bet the coolant will start to do a pretty darn good job at cooling the CHRA :p
    Oct 17 2009
    alonE, Pa
    Eh, has anyone rode/driven in a k26? 5cyl k26 is a fun car and if they are so shitty, then they wouldn't have a k26 kit for the s4
    STEVE
