Results 1 to 23 of 23
    Jun 15 2010
    Chicago
    Does my B8 have AFS or non-AFS headlights?
    Thinking about buying headlights on ECS without the amber sidemarkers but noticed they had AFS and non-AFS versions. How do I tell if mine comes with AFS? All I notice is that when I start the car, the headlight beam goes up and down. Car is a 2010 premium plus with nav.
    Veteran Member Four Rings Leor604's Avatar
    May 25 2010
    Vancouver
    When I turn my lights on, they go down, in (cross-eyed), out (Marty Feldman), and then back up. Also, you have to be moving for them to point left/right with the wheel. Just crank the steering wheel left/right while you are moving and you'll see the lights also go left/right if you have the adaptive lights.
    Somehow, I don't think they were available in the US in 2010, but I could be wrong.
    Jan 22 2013
    '10 S4, '02 Subaru RSTI - EJ207 Swap, '75 BMW 530i Chump Car
    Quote Originally Posted by Leor604 View Post
    My 2010 has them...
    At least, they do the dip and go cross-eyed and Marty Feldman when I turn the car on...
    2010 Audi S4 || Meteor Grey Pearl || 6MT || Sport Diff || Nav || B&O Sound System || Advanced Key
    VMR 721 19x9.5 w/ Michelin PSS 265/35/19 || 034 Transmission and Rear Diff Mounts || CR-15 Brace
    The ex: 2002 Subaru RSTI || Midnight Black Pearl || JDM STI Swap - EJ207 || 6MT || ST Coilovers || Blouch Dom 1.5XTR Turbo, etc. || Airboy Tuned
    The racekar: 1975 BMW 530i || Classic BMW Paint Scheme || Caged || 5MT Swap || Body Roll
    May 25 2010
    Vancouver
    To quote myself: "I don't think they were available in the US in 2010". Canadian Premium trim cars have had them since day one and I think they are now standard in the US as well.
    Jan 22 2013
    My mistake. I read US as North American market. Didn't know there was a difference. Thanks!
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by chi123 View Post
    You're describing the self-leveling feature of the headlights. If your headlights actively move side to side to point in the direction that you're turning, you have AFS. If they remain fixed, you don't. I don't know if this is/was available as an option on non-Prestige trim cars.
    Dec 01 2005
    Edina, MN
    You drive an allroad...
    ...the uncola
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by umyskam View Post
    With AFS headlights. Hi Will.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Adaptive headlights(AFS) are only available on Prestige model cars. Your Prem+ could not have them from the factory
    Jun 15 2010
    Chicago
    Good to know then, thanks guys! Saves me a few hundred getting new headlights without the amber sidemarkers.
    But has anyone bought ecodes or ones with with clear sidemarkers from ECS without the AFS option? Do they still have auto-leveling?
    Veteran Member Four Rings amz's Avatar
    Apr 29 2013
    Ottawa
    I don't think mine go crosseyed, but they definitely go Marty. When I turn the wheel at night, I can see only the inside light re-aim, the outside light stays where it is...is that normal for the 2012's?
    2012 S4 ~ Phantom Black - Mustang Brown - B&O - Sport Diff - DSG
    AWE Touring Exhaust | Roc Euro Intake | Eurocode Alu-Kruez | Eurocode USS Swaybars & Solid End Links
    Canada: the land of Quattro
    May 25 2010
    Vancouver
    AFAIK, all HID headlights must have auto leveling by law. They really don't want them shining up into oncoming traffic.
    May 25 2010
    Vancouver
    Quote Originally Posted by amz View Post
    I may be mistaken with both cross-eyed and Marty movements, it may be Marty only. I don't really take notice of it that much any more.
    On my 2011, both headlights definitely move together when the wheel is turned so not sure if that has changed for newer versions.
    Veteran Member Three Rings LawDawg's Avatar
    Feb 20 2008
    Naperville, IL
    Canada was able to get AFS from day one. Not sure if it was on all packages though.
    Here in the US, they were NOT available on 2010 and 2011 cars, no matter the package. In 2012 they came back on Prestige cars, and possibly as an a la cart item on P+ cars as well (not sure on the last bit though).
    If you have a '10 or '11, you do NOT have them if your car is a US market car, and is otherwise unmodified.
    Current:
    '13 S6 Prestige [Oolong Grey Metallic, B&O, Innovation (HUD, Night, ACC, Active Lane/Side Assist., Top-view), Cold Weather, LEDs, 20"]
    Former:
    '11 S4 Prestige
    '05 A4 1.8T USP 6MT
    '01 A4 1.8T QMS
    '95 Dinan M3
    Veteran Member Three Rings Jcam14's Avatar
    Aug 17 2013
    fully built 1998 Camaro SS/ 2000 Silverado RCSB/ 2000 Camaro SS
    Tucson, Arizona
    So I have a 2012 prestige.... That means I have AFS?? I've never noticed that they follow my turns... Is it really noticeable?
    2015 White S4/Lowered/034 CAI/034 STG 2 Tune/034 Upper & Lower Crank pulleys/19" Peelers/Black Leather with brown inserts/full CF inlays/Full LED interior lights/ Prem+
    Feb 20 2008
    Naperville, IL
    You should, as far as I know. The easiest way to tell is if the lights cycle through "cross-eyed" as well as up-down when you turn them on.
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    You can also pull the part number off the top of the headlight and search for it if you aren't positive. Little white label on top of the housing.
    For example:
    Veteran Member Three Rings a1dan_87's Avatar
    Mar 07 2018
    Utah
    Quote Originally Posted by Dr GP View Post
    Our 07 A4 Avant has them. It's obvious when you start the car, because the lights test movement in all 4 directions
    Sent from my ZTE B2017G using Audizine mobile app
    Mar 31 2008
    eS-4
    CAL*SO
    Quote Originally Posted by Jcam14 View Post
    I have a 12 prestige and i never noticed mine going sideways. they just do the normal adjusting when car goes on and when I go over dippy roads I can see them bouncing to stay adjusted.
    Senior Member Three Rings Phil.Lmbrt's Avatar
    Apr 12 2017
    La Sarre, Quebec
    It's pretty obvious yes ! Just go on a darker road at night and take a turn, you'll see immediately
    2012 S4
    Phantom Black | 6MT | Sports Diff | B&O
    IE Dual Pulley W/ TB | 57/187 Pulleys | Rabbit Hole Motorsport | CTS | USP | 034 | JHM | PLM | BFI | P3cars | Rotiform | CR-15 | Macan Calipers | StopTech | Hawk Performance| SPEC Clutches | Snow Performance | Airlift Performance | Accuair | Kühl Rennsport
    IG : Phil.lmbrt
    Jan 26 2018
    Albany, NY
    I only noticed it if I'm looking for it. I think it's easier to see them return to center, after a turn, than see them adjust into your turn. Just my opinion, though.
    Sent from my SM-G930V using Tapatalk
    2014 S4 Prestige - Ibis White - 6MT
    Mar 28 2016
    I sure hope they improved the AFS since my 2008 A6. I HATED them on that car. The mechanism started to wear over time, causing the headlight to vibrate over bumps. It looked like a goddamn strobe light on license plates of cars in front of me and road signs.
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by a1dan_87 View Post
    We are talking about B S4s on this forum.What non B8 S4s Audis have is not pertinent to the OP's question about B8 S4s which was originally posted almost 4 yrs ago.
