Results 1 to 40 of 42
    Account Terminated Four Rings
    Apr 18 2013
    Right
    Transmission Swap
    Does anyone live in MD/PA area that is super experienced with this type of thing?
    http://www.audizine.com/forum/showth...nsmission-Swap
    I want to make my automatic a 6 speed and I would feel much more comfortable with someone from here who knows that they are doing rather than some garage. I am working on gathering parts and I have my eye on a B7 6 speed transmission. I of course would want to do all of the JHM upgrades to it that I can before installing, including a downpipe.
    Thanks.
    Mar 24 2013
    Oakdale, CT
    Aren't the engine blocks different for Tiptronic and CVT/manual cars?
    -Adam
    Jun 17 2013
    jersey city nj
    I believe the Crankshafts are different.
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by vce1232000 View Post
    I know that was true on the B5's. Don't know B7's well enough yet but I'd ask that question.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Mar 24 2013
    Oakdale, CT
    Maybe that was it. I just remember reading that something was different.
    -Adam
    Senior Member Three Rings chucklando's Avatar
    Jul 23 2012
    Oswego, NY
    I looked into doing this and ended up buying the same car in 6 speed (08 a4). I didn't want to do this at first because I had so many after market parts on my tip but in the end it was cheaper to swap the parts over to a manual car than to convert mine.
    The 6mt I bought was mostly stock except for a dtm package, rai dp, and awe exhaust. I bought it, swapped my after market tip parts to the manual, then sold the tip. It was about 2000 in labor and they had both cars for about a week.
    I was quoted 5-8000 from two reputable shops just for labor. They said it's possible it's just labor intensive. Redline speed worx said the other issue they run into is getting every nut and bolt they need to do it. They said the smoothest way to do it is to buy a donor car that had been totaled but with intact transmission and use that since every part you need would be there.
    Just some food for thought for you. Good luck either way you go with it. I don't regret going the way I did it for a second, I love every time I drive the car and the jhm ss makes it all the better.
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by chucklando View Post
    Solid advice right here.
    -Adam
    Veteran Member Four Rings 4rings5stars's Avatar
    Jul 31 2011
    I wasn't aware that the block was different on any audi motor with respect to tranny type. News to me
    The fleet
    2000 S4 EPL tuned Stage 3 -- Silver/Panda -- Latest fun project
    2002 S4 Avant 6spd -- Nogaro/Silver -- Long term rehab project
    2012 A8L -- Night Blue Pearl/Nougat
    2013 VW Touareg VR6 Lux -- Flint Grey/Black
    2001 BMW 540iA Sport -- Steel Blue/Grey
    2001 BMW 750iL -- Night Blue/Ivory
    2004 Jaguar XJ8 -- British Racing Green/Tan
    2005.5 A4 Avant 6spd -- Quartz/Black -- Sold
    Veteran Member Three Rings audihere06's Avatar
    Nov 11 2013
    Charlotte NC
    Transmission Swap
    The blocks aren't different. The swap has been done on a b6 just not a b7 that i know of. Been looking to do this myself if i ever blow up my zf6hp.
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by audihere06 View Post
    The B6 chassis have the 1.8T. The B7 chassis have the 2.0T. 2 Different motors
    Nov 11 2013
    Charlotte NC
    I know that i was just saying that it has been done. The b7 and b6 have the same 6 speed manual though.
    Senior Member Two Rings djsp00kyk's Avatar
    Jul 25 2009
    B9 Sq5, B7 A4, 2.5l swapped NC miata, LS swapped Jeep TJ
    Mississippi
    The blocks are the same as far as bolting up the transmissions. I am pretty sure that tips have a different crank than a manual/cvt car. I know cvt and manual have the same crank, as I have done the swap on my cvt, but I cant say positively that tips are different.
    Veteran Member Four Rings Lastsummer's Avatar
    Nov 25 2011
    2021 B9 Audi SQ5 Black Optics
    Grayslake, IL
    Incorrect... certain B6 A4's have the 01E 6spd trans which is used in the B5 S4's as well. The later VIN's for the B6 use the 02X and GJW transmissions. I do believe that the B7 does use the GJW as well though.
    So not all B6 transmissions are going to work from my understanding.
    2021 B9 SQ5 - IE Turbo Inlet, IE CAI, 034 Motorsport Stage 1 ECU/Stage 2 TCU, O34 Strut Brace, 034 F/R Sway bars w/ end links, 034 trans bushing & insert, 034 RSF inserts, 034 rear diff inserts, 034 lowering links
    B8.5 Audi S4 - Monsoon Gray - EPL Stage 2 - Single Pulley, EPL TCU, ECS Carbon Intake, ECS Mid-pipe, Magnaflow Catback, ECS Drivetrain/Trans inserts, ECS Lower Control Arm Brace, CR-15, S5 Peelers, H&R sports, Bilstein Shocks
    Nov 11 2013
    Charlotte NC
    As long as there is a place in the crank for the pilot bearing, it should work
    Nov 11 2013
    Charlotte NC
    Quote Originally Posted by djsp00kyk View Post
    What all was involved for your swap?
    Jul 25 2009
    Mississippi
    http://www.audizine.com/forum/showth...ed-manual-swap
    Here is the link. It was pretty involved but not as bad as I thought.
    2018 SQ5
    2012 Brilliant Red S4 DSG / Sport Diff / RS4 Grille / CF Supercharged Emblems / Resonated X-pipe, Muffler delete / epl stage1
    2006 A4 (CVT to 6 speed swap)
    Past Rides: E46 ///M3 Topaz Blue Metallic, Eclipse GS-T, Dodge Colt (4g63t)
    Jun 17 2013
    jersey city nj
    The manual-CVT crankshaft backside bore extrudes out further to accept the pilot bearing. The tiptronic crankshaft has a shorter bore in the crankshaft. I was @ my friends shop today and he had both complete short blocks side by side so I seen the difference today. Ive heard of shops using the manual- CVT motors to replace the tiptronic motors. But not the other way around
    Here's some other links
    http://www.audizine.com/forum/showth...ual-Crankshaft
    Nov 11 2013
    Charlotte NC
    This is good to know. Kinda sucks but i guess it confirms that one would need to buy a donor car to do the swap if one were to do it. Are you sure changing the flywheel wouldnt do anything?
    Jun 17 2013
    jersey city nj
    Not to sure Im understanding your question. The tiptronics have a flex plate and the manual has a flywheel. They will share the same bolt pattern. The problem will come in when you the pilot bearing into the crankshaft of the tiptronic crankshaft
    Nov 11 2013
    Charlotte NC
    I got it. Dammit audi why you gotta make separate cranks.
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by Lastsummer View Post
    Im showing B7 6spd manual transmission code are all GVE ... I guess you mite be able to adapt a B6 transmission in
    Veteran Member Four Rings derrek's Avatar
    Jul 23 2010
    arizona
    crank is the same, just swapped a auto motor into a manual car.
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by derrek View Post
    Really... Now Im really ....
    Jul 23 2010
    arizona
    dont remember if it was cvt or quattro though
    Jun 17 2013
    jersey city nj
    Shops have told me you can use a CVT engine for a manual engine. And a manual or CVT engine for a Tiptronic engine. You just cant use a tiptronic engine for a manual engine
    CVT and Tiptronic are different even thou they are automatic's in term's anyway
    Senior Member Two Rings projectb7avant's Avatar
    Apr 09 2013
    Ilion New York
    Any one know if pilot bearing deal will work with 2.0?
    A4 B7 Quattro Avant 2.0t tip - mild daily build for now (gathering parts)
    Registered User Four Rings Sales@DriveAuto's Avatar
    Apr 13 2012
    Clifton/Mountainside, NJ
    Not sure if you're looking for a shop to do the swap or not, but we've done our fair share of auto to manual swaps (C5 S6's and all roads, B5 S4's, B6 A4's, etc.) - give us a call if we can help!
    Nov 11 2013
    Charlotte NC
    Quote Originally Posted by Sales@DriveAuto View Post
    I live no where near you guys but just out of curiosity what would you ballpark the cost of the swap being?
    Jun 17 2013
    jersey city nj
    Here's the link to a classified that states that you will need a manual crankshaft to complete the swap from a tiptronic transmission
    http://www.audizine.com/forum/showth...-b7-trans-swap
    Nov 11 2013
    Charlotte NC
    Im still not convinced that the auto crank wont work. It makes no sense for audi to make 2 different ones. Especially since 3/4 of their trans (counting two different manuals) come with the same crank. Also that the auto engine can be replaced by a manual engine but not vise versa. I have been researching it and looked at several used engines for sale and none of them specify if it was the "manual crank" or "auto crank". I read the diy for the conversion over on the b6 forum and he had to trim his pilot bearing to fit, but it still worked.
    Jun 17 2013
    jersey city nj
    Try it and post back with results
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    If it's the same as the 2.7T, then you just have to remove the TC carrier from the crankshaft.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Apr 18 2013
    Right
    I'm still here, I just have nothing to contribute. I am reading though. Keep it going!
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    Doesnt this just seem like the biggest hassle? Why not just buy another car, swap your go fast, look good parts into the manual---done. Seems like its a $$ pit for dreaming people. I mean if you have all those hours and have all the parts--and maybe your time isnt worth much $$ ---otherwise I would think buying another car and swapping it all out makes more sense.
    Dec 10 2011
    CLT | MKE
    Transmission Swap
    It doesn't take that long to swap it. You'll have it done in a day if you know what you're doing and have all of the parts. This is assuming the crank doesn't need to be switched out. If it does, then I agree with you.
    As far as money, I guess that depends on the individual's situation as to how many mods they have, how much they can get a 6MT car for, etc... For example, I've seen tip cars for dirt cheap that would easily warrant doing the 6MT swap.
    Sent from my iPhone 6 using Tapatalk
    -Hayden
    Nov 11 2013
    Charlotte NC
    I would rather swap mine because I have a low milage all black titanium edition that was meticulously maintained by the previous owner and has no oil consumption. It took me way too long to find a titanium and i wouldnt be able to easily replace it.
    Apr 09 2013
    Ilion New York
    I cant find a definite yes or no on if it will work without swapping crank.
    Apr 18 2013
    Right
    I just got off the phone with DriveAuto and they said it would require new axles, crank, etc, etc. I would buy a manual and swap all of my interior parts but I do not have $10,000 to buy another car. I also just paid over $1000 to get my car painted. Plus my car is mint and uses no oil and has no engine problems. I feel like I got lucky with that and I wouldn't want to risk swapping my perfectly running car for a possible lemon. I also just paid to get the timing belt and all of that done.
    Reading more of this tutorial it seems like I would not need to swap out the axles at all...
    Jun 17 2013
    jersey city nj
    ^^^^^^Keep in mind that is for a B6 with a 1.8T. Completely different engine.
    Apr 18 2013
    Right
    Any place where I can get a DIY for a B7?
