Results 1 to 36 of 36
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    any way to clean CHRA on turbo?
    i just had my CHRA replaced by garrett not too long ago. ran the car for a couple hundred miles before taking the motor out.
    today i brought my turbo to work to glass blast the housing. masked everything off and even stuffed shop towels down the inlets etc..
    made the housing look brand new. but somehow some of the particles made its way into the turbo.
    i turned the propeller on the inlet and i can hear the grains grinding around inside it. they made their way into the oil feed and onto the CHRA.
    called up ATP since they are local, they said they cant service it for me. i gotta send it for a new CHRA again.
    is there any way i can take it all apart and clean everything off, and possibly lubricate it with oil and put back together? trying to avoid paying for a new CHRA again.
    thanks!
    Audi Club Bay Area
    Dec 05 2007
    How long have you had this chra for? It comes with new 1 yr warranty. If that isn't up, drive the car, blow the turbo, and send it in for free replacement. That thing is toast. Next time take the housings off the chra before doing stuff like that.
    Note: Def read the warranty fine print first to see if this can be done first, and you don't fuck yourself.
    Dec 05 2007
    An idea. If the warranty thing does not work you can possibly run deisel fuel through it. DO NOT spin the wheel at all during this. Then pump a lot of oil through it (restrictor removed) to clean oil out and lubricate. All done outside the car. Not saying it would work, but probable.
    If you damage your turbo doing this, I take absolutely no responsibility.
    Dec 19 2013
    car has no engine :(
    cant drive it to blow the turbo.
    new CHRA was done by garrett about 6 months ago.
    looks like its time for a new CHRA.
    Audi Club Bay Area
    Jun 30 2013
    Bowmanville
    Should have put bolts in the holes, You just ruined a good turbo for something that will inevitably happen again (get dirty).
    And if you are talking about the cold side housing, its easily removed with 4 bolts, blast away, powder, paint whatever. You should have never put the CHRA in the cabinet.
    Dec 19 2013
    Quote Originally Posted by War Machine View Post
    yea looks like i had to learn this one the hard way.
    i'll send it in for another CHRA. looks like i am shit outa luck on this one.
    Audi Club Bay Area
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    you cant just flush out the chra with oil?
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Dec 05 2007
    You would want to use some type of detergent first, hence why I suggested diesel fuel then oil. If it were me I would blow it and take advantage of the warranty. He needs to blow it first, though.
    Dec 19 2013
    i already filed it to send out to garrett for a new CHRA.
    you live and you learn. expensive lesson learned the hard way.
    this is what happens when you gotta learn shit on your own and dont have someone to help. wont happen again thats for sure :)
    i'll be dropping it off after work for a new center cartridge. there goes my plans for new wheels.
    Audi Club Bay Area
    Dec 05 2007
    Dude, just wait and blow it before sending it in if you can do it before your warranty is up.
    Oct 29 2005
    10speed
    San Francisco, CA
    is the sand actually in the cartridge or just the housing? You might be fine if you pull the housings off and clean it up
    - Clint
    Dec 19 2013
    my car doesnt have an engine. cant blow the turbo
    Audi Club Bay Area
    Dec 19 2013
    in the cartridge i believe.
    i tried to blow it out with compressed air and nothing. in fact it almost made it worse.
    i turn the shaft by hand and its grinding and stopping.
    looks like it got in through the oil line opening even though i masked it off.
    i'm taking it off now to check
    Audi Club Bay Area
    Feb 27 2011
    Winnipeg
    is it ball bearing or journal bearing?, if its journal bearing take the housing off and pull the shafts out and all the guts and clean everything, if you turned it with grit and its journal bearing it may need a new bearing as it may be scored now.
    Dec 19 2013
    It's a 2871r
    Took the housings off. It's definitely the CHRA.
    Audi Club Bay Area
    Aug 26 2005
    The glass bead particles are inside the ball bearing cartridge. Since the cartridge can't be taken apart, the only fix is to replace the ball bearing cartridge with a new part. There is no way to flush the cartridge to be sure there is no glass bead particles left inside. The correct way to glass bead the CHRA housing is to disassemble everything from the housing first. It is difficult to reassemble the CHRA with the compressor impeller located perfectly on the turbine shaft as originally assembled to maintain the dynamic balance of the rotating parts, without having a dynamic balancer machine. This has to be done on a dynamic balancer when the CHRA is assembled.
    Depending on how you manage the exchange, this is at the minimum an inconvenient lesson for you. Sorry.
    Vorsprung durch Technik
    Dec 05 2007
    Quote Originally Posted by Furly View Post
    Turbo is toast. Probably would have blown as soon as you started the car. When is the warranty up and when will you have an engine? Don't pay if you don't have to. Blow that puppy first...then send it in.
    On a side note, I'm pretty much done with Garrett. Had bad experiences with them. But on the flip side, people had bad experiences with the company of the turbo I am running now. Guess luck of the draw.
    Dec 19 2013
    If I can find a better turbo that can spool faster for a good price, I'll just buy it now. I want to make sure i have a good turbo for when the engine goes back in.
    I have an engine it's just in pieces while I drop rods in and put my built AEB on it.
    Audi Club Bay Area
    Veteran Member Three Rings Charlie240sxt's Avatar
    Mar 28 2010
    95 240SX SE Ka-T,90 240sx LS1,12 Ram 2500
    tulsa,ok
    Holy crap dude that sucks......remove the housings next time.
    04 A4 1.8 Quattro 71R, 12 Ram 2500 6.7, 95 240sx 2.4 6058,92 240sx Coming soon ls1??
    .............ModdedDD.............Tow Pig...............Dust collector.............Track Whore............
    Dec 19 2013
    Quote Originally Posted by Charlie240sxt View Post
    its my first turbo car. lots of important lessons learned with this one ;)
    Audi Club Bay Area
    Dec 05 2007
    With a built engine, forget that turbo. Go bigger. Journal bearing CT turbo would be my suggestion. I run a CT2 5152 Triplex Ball Bearing unit from them, rated at 530hp, and cost the same as a GT2871R (had this turbo prior, but CT prices have gone up tremendously unless they are inflated on the site below. I paid $1,2xx for mine).
    http://www.ringer-racing.com/category.sc?categoryId=216
    I personally purchased from CT directly. Tell them your story (don't tell them how you blew it, but just tell them you blew it) and they may give a sympathy discount. It happens. Would not be surprised if they would sell you a journal bearing turbo for like $650. This route, you would actually be able to appreciate and use your built engine.
    With a BT, the whole powerband changes and you will basically have to relearn your car (not joking). I mean like a complete 180. With my tune, I have really aggressive timing on the low end so it is rather tolerable for me before boost kicks in. Then when it does, it's just fun. But with BT power and sitting on a built block you will get tired fast. That is why I suggest a bigger turbo now. You will get tired of the GT2871R really quick. Incredibly fun turbo and ideal for those with a stock block (basically at it's limit, safely), but not for those with a built engine and you would just want a more powerful turbo. Ask me how I know.
    Active Member One Ring BISHILVR's Avatar
    Jan 22 2015
    OH
    Do not ever put a turbo on a car if it has any kind of grit in it, especially when you know its sand blasting media! that grit will end up in your oil and destroy your engine, not to mention contaminate your intercooler pipes and intercooler with grit (you will then have to replace the intercooler) AND if that turbo comes apart, it can easily breath pieces of the turbo's bearings or pieces of broken blades into your running engine and destroy your engine in that way too. Bad advice right there.
    Dec 05 2007
    So he would simply need to run an inline filter on the oil drain line. Small hurdle. Intake side would be fine. It's in the chra. Blades would need fod for what you are saying. Oil filter should pick up that crap before it reaches any journals anyways.
    edit: just thought about it and he can keep the oil drain detached from the turbo and collect the oil. The turbo won't see much oil by the time he blows the turbo. it's not as big of a deal as you may think. your sump naturally has much more sh*t in it already and it doesn't harm anything...till your pick up tube clogs.
    Jan 22 2015
    OH
    Bad idea all the way around.
    Dec 05 2007
    New idea. Put a power drill with socket on the nut for the compressor wheel and spin it. Now..send it in . Run a detergent and flush with oil before, to hide the evidence.
    Jan 22 2015
    OH
    Mark the relationship of the wheels, (pull the compressor cover off) remove the compressor blade (nut) pull the turbo apart and clean each and every piece inside of it and re-assemble, otherwise send it in for a cleaning or a new center section, if you want to try to salvage it dont turn it any more at all.
    Dec 19 2013
    Got a question for you guys.
    Will a GTX chra work in the housings of my 2871r? What would I need to turn it into a gtx turbo that would outperform my current one ?
    Just seeing if it's an option at all.
    Audi Club Bay Area
    Dec 05 2007
    The GTX is sold with the CHRA and compressor housing for the redesigned compressor wheel. You reuse your old turbine housing.
    And for the record, Garrett BB cartridges are fully rebuildable for the DIY guy but the balancing would need to be performed by a specialist. But since you have a warranty, it is much easier to get a free replacement. Seems you are trying to avoid that like you want to pay, which is strikingly odd.
    Dec 19 2013
    Its not that I want to pay. But more so that I already opened an RMA and dropped the turbo off.
    Going back in the morning and taking It back (if they hopefully have not shipped it yet) and then filing another RMA through another shop would be sketchy. Unless of course these shops don't open the RMA directly with Garrett. Then it wouldn't matter.
    I know I made a dumb and expensive mistake. but i have too much going on, that I rather not have to worry about it. Really borderline considering parting the car out if shit keeps going downhill like it has the past 6 months.
    Audi Club Bay Area
    Jan 22 2015
    OH
    Ball bearing center section parts are not made available by Garrett or any other name brand turbo company that I know of, I'm sure some chinese knockoff bearings could be bought which goes without saying you should not waste your money on. The bearing rotational assembly is pressed onto the the turbine shaft and then the compressor wheel is added and the whole assembly is then balanced as a whole, there is no way to accomplish this at home and thats why the parts are'nt made available.
    Aug 19 2013
    minnesota
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Dec 05 2007
    Quote Originally Posted by BISHILVR View Post
    Really? Then what's this? Garrett parts are most likely China made just like eBay replacement parts. From what I gather there are many shops out there that can both rebuild and rebalance bb turbochargers. My current bb turbo has a center housing designed to be opened and fully serviceable.
    http://www.audizine.com/forum/showth...R-GT3076R-etc)
    Aug 26 2005
    I agree. It would be similar to putting a half teaspoon of glass bead media into the the oil fill and intake manifold directly. Also, the CHRA would show evidence of failure from contamination, when inspected for warranty purposes. I am skeptical the warranty would cover contamination from dirt of any type since that is not a manufacturing or material defect.
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    some ppl just have no brains **cough-cough OP
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by GrapeBandit View Post
    great contribution here.
    - Clint
    Dec 13 2010
    FL
    ditto
