Page 1 of 6 123 ... LastLast
Results 1 to 40 of 216
    Dec 19 2004
    Fuel Leaks Recall for 2011-2012
    2011 B8 S4 | EPL Stage 2 | KW H.A.S. | APR Stage 1 & 2 Carbonio Intake | Borla Exhaust | Eurocode Alu Kreuz | Eurocode ÜSS Stabilizer Bars and End Links | 034 Motorsport Trans Mount Insert | Spulen Rear Differential Mount | Hartman RS 4 Wheels
    Veteran Member Four Rings audistealth's Avatar
    Mar 04 2012
    2012 Audi S4, 2017 Explorer Sport
    Argh, I'm hit.
    May 17 2012
    Houston, TX
    damn it! thought my '12 was bulletproof... now a trip to the dealer for them to beep-up my car.
    Mar 26 2010
    US
    http://www-odi.nhtsa.dot.gov/owners/SearchSafetyIssues
    It is VIN specific, so if your VIN does not show up, it is not part of the recall. It is not clear if all cars in that time frame and model list will be recalled.
    "Volkswagen says that it will begin mailing recall notices to owners no later than March 10, 2015. After receiving those notices, owners can take their vehicles to the appropriate Audi or Volkswagen dealer, who will replace the fuel rails and corresponding seals at no charge."
    BMW M3 Competition X-drive
    Mar 26 2010
    US
    Veteran Member Four Rings PitchS4's Avatar
    May 14 2007
    2021 SQ5 | 2019 Jeep GC Limited
    Northern VA
    Weird that it does not affect the 2010s. My HPFP was leaking and I had it replaced under warranty.
    Current:
    2021 SQ5
    Previous:
    2017 S3
    B8.5 SQ5
    B8 S4
    B6 S4
    B5 S4
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    looks like they changed the rail in those years or a manufacturing problem with those years with how the seals sit on there. Not a big deal to fix just have to take the S/C off. I would ask them to replace the crankcase valve while they are in there since they are right there and maybe see how bad your carbon build up is
    Veteran Member Four Rings shadycrew31's Avatar
    May 27 2013
    West Chester, PA
    Finally the 2010 isn't the one with the issue! I feel like getting a bottle of champagne.
    Established Member Two Rings lenf's Avatar
    Oct 07 2014
    C NJ
    Queried my car. The below is from http://web.audiusa.com/recall/#
    Audi also replacing thermostat and/or the crankcase pressure valve for free at the same time.
    "Results for your
    2012 S4 3.0 SEDAN 4-DR 6-SPD QUATTRO
    Recalls
    see details Fuel Injecton System Leak REPAIR NOT YET AVAILABLE
    START DATE
    Jan 20, 2015
    AUDI ACTION CODE
    24AP
    DESCRIPTION
    Due to a combination of production tolerance issues and vehicle vibration during dynamic driving, it is possible that, in rare cases, a fuel leak may occur in the vehicle's fuel injection system. Leaking fuel, in the presence of an ignition source, may result in a fire. Additionally, some vehicles may benefit from having the thermostat and/or the crankcase pressure valve updated. Repairs to these other components are not related to the safety recall, but can be easily performed at the same time as recall repair.
    REMEDY
    To help correct the safety defect, your authorized Audi dealer will replace both fuel rails and the fuel injector seals. The thermostat and/or the crankcase pressure valve will also be updated on certain vehicles. These repairs are not related to the safety recall, but can easily be performed at the same time as the recall repair. These repairs will be performed free of charge."
    2012 S4 Prestige - Phantom Black; MT6; Sport Differential; Titanium package; Napa Black/Red seats; APR Stage II +; APR Carbonio Air Intake; Milltek Non-Resonated Cat-Back Exhaust; AK
    2019 Shelby GT350
    May 17 2012
    Houston, TX
    yup, shows up for me too... no idea how much this frustrates me to have to leave the car with the dealer. I hope my motor mounts are gone so i can do that at the same time as well. will need to check those.
    As of now i dont burn any oil and have not have a thermostat failure. I wonder if i should not have them touch the crankcase for fear that issues may develop after they do something. For the thermostat... im 50/50. Not convinced that the replacement is any better. I hear its the same thing so no point it putting a new one.
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    Nothing for my 2011
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    No recall for my 2011 either (build date 10/2010)
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Veteran Member Three Rings MerkurRS's Avatar
    Oct 04 2012
    Four Passat W8's, 2003 allroad 2.7t , Ford Excursion Ltd V10, 1989 Merkur Scorpio, 1987 Merkur XR4Ti
    Berthoud, CO
    Ugh....
    I just had this apart six months ago, replaced the thermostat and crankcase vent (about $120 in parts) while I had the S/C off for repainting. Oh well.......
    2012 Audi S4 Prestige Glacier White, Alcantara Leather, Titanium/ Black Optics Pkg, Auto/ Driver Assist/ Drive Select/ B&O/ Carbon Inlays, UltraCharger, APR Carbon Intake, Flat-bottom Wheel, 3G+Google Map conversion, Passport 9500ix red/carbon limited edition, Michelin A/S 3's, Armytrix/ Custom Exhaust, Spulen Diff Mount, 034 Trans. Insert, Eurocode Alu-Kreuz, ACNA Member
    Jan 14 2009
    pasadena md
    Quote Originally Posted by MerkurRS View Post
    Ugh....
    Well wait and see if you get a notice for the recall and if you do you can call AOA and they might reimburse you the money you sent on the parts to fix those. If you kept the receipt for the parts.
    My guess is they are inspecting the thermostat and the crankcase valve to be able to replace it for you. I would wait till you get a real notice and see if you can get your hands on the real recall bulletin to see what replacement guidelines are for the t-stat and the valve and you might qualify for it. My guess its going to be part number compare or design markings
    Veteran Member Four Rings skiracerblah's Avatar
    Jan 03 2011
    Evo X MR : 290whp, 313 lbs/torque @ 24psi; Evo IX : 383whp, 383 lbs/torque @ 28psi E85
    San Fernando Valley, CA
    Quote Originally Posted by saxon View Post
    Nothing for my 2011
    Ditto... Car currently at dealership for a new Thermostat
    Sorry for newbie questions, this is my 1st Audi
    Current: Phantom Black '2011 S4 S-Tronic Premium Plus, Sports Rear Diff, JL Audio subwoofer upgrade, Milltek Resonated Exhaust
    Old cars:
    Evo X MR-Touring stock, but tuned by RRE: 290whp, 313 lbs/torque @ 24psi 91 octane
    Evo IX tuned by RRE: 383whp, 383 lbs/torque @ 28psi E85 ethanol fuel
    Mar 26 2010
    US
    Checked S4 MY 2011 VIN build 6/2010
    ""Results for your
    2011 S4 3.0 SEDAN 4-DR AUTO S TRONIC QUATTRO
    printing icon
    Recalls
    This vehicle does not have an open recall OR a recall was issued more than 15 years ago.""
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Quote Originally Posted by skiracerblah View Post
    Hmmm you said something that got me thinking. Have them do a thermostat while they are in there, should just be parts at that point and might save you money in the long run. If they will do it.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Dec 19 2004
    No recall on my 2011
    Nov 08 2014
    Ontario,Canada
    Weird. My car had the leaky fuel injectors replaced this year under warranty, yet I'm not affected by the recall.
    2016 A7 Technik S-line | Mythos Black Pearl | Black Optics | Remus Axle-back exhaust
    2011 S4
    2006 BMW 330i
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by Cooper993 View Post
    +1
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Senior Member Three Rings JJP1978's Avatar
    Dec 30 2012
    '14 WRX
    Tarpon Springs/FL
    Sweet I'm on it. Hopefully being out of warranty won't be an issue..
    2012 S4, Premium +, 6MT, Sports Diff, 20% Tint, CF Supercharged Badges, Roc-Euro Intake, VMR V708 Gunmetal mounted on Michelin PSS's, AK, VAG-COM mods, Spullen Rear Diff mount, 034 Motorsports trans mount. NEW CLUTCH @ 48,500miles..
    Jul 21 2014
    No recalls on my 2011 either.
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by JJP1978 View Post
    Recalls have nothing to do with the warranty. They will be performed free of charge regardless of vehicle age or mileage.
    Veteran Member Four Rings Jones2012s4's Avatar
    Nov 09 2011
    Michigan
    I also wonder if having them replace the thermostat is worth while, 55,000 miles and no issues yet.
    My car is part of recall.
    2012 S4 - DSG B8 - [email protected]
    Apr 11 2012
    my car is recalled too... 2012 here. At least they'll replace the thermostat if I have one from their defective batch/design.
    Veteran Member Four Rings GrkA4's Avatar
    Jan 14 2005
    B8 S4, MkV R32, B6 A4 (gone)
    Newtown, PA
    I called and spoke to my service manager yesterday and he said Audi/VW is supposed to formally publish the service bulletin today (1-28-15). He looked up my VIN and did not see any open recalls but said to call back later in the week and they'll check it again because he wasn't sure if Audi had finished flagging VIN numbers yet. He also mentioned they won't have parts in stock until March.
    I ran my VIN a few minutes ago on the recall website (http://web.audiusa.com/recall/) and I have no open recalls.
    B8 S4 Sprint Blue - UNITRONIC Stage 2+ & S-Tronic Flash, Roc-Euro Intake, Magnaflow Exhaust w/ non-resonated downpipes, Eurocode Sway Bars & AK, 034 Trans Mount
    MkV DBM R32 - VF Engineering Intake, Magnaflow Exhaust, HPA Dogbone Mount, Neuspeed RSB and End Links, H&R Springs, RNS-510
    CB Tuning
    Unitronic
    Dec 19 2013
    Dublin, OH
    2012 here; showing as needing recall on the Audi page.
    Yee haw
    Established Member Two Rings pfft's Avatar
    Jul 24 2014
    '05 Nissan 350z
    Grand Rapids, MI
    Checked my vin...
    Results for your
    Recalls
    Is this basically saying that the car was manufactured with the working 2010 part?
    Jan 09 2008
    Winnipeg
    No recall showing for my 2012. I don't think it makes a difference but my car is a Canadian car but I assume it is looking at a global database or at least a North American database. Anyone know for sure.
    Senior Member Three Rings Riu's Avatar
    Apr 03 2011
    Boca Raton Florida
    No recall on my 2011.
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    Recalled!!
    Results for your
    Recalls
    see details
    START DATE
    Jan 26, 2015
    AUDI ACTION CODE
    24AP
    DESCRIPTION
    NHTSA RECALL NUMBER
    Awaiting#
    REMEDY
    2016 S6
    Jan 14 2009
    pasadena md
    Well what happens with a recall like this is they have identified the part in question and the part in question what was wrong with it. And they have traced the part back with the window of how it was manufactured like that and then vin range that those defective parts were put on then they expand that window by a few months to make sure they get them all.
    Jul 12 2013
    8V S3 and B5 S4
    Old Bethpage, NY
    i'm recalled too. I just called my local dealer and they said to call back in a week or two as they don't have anything in their system regarding this recall.
    2018 Carrara White Audi Q7 3.0T P+, Cold weather package, Vision package, Warm weather package, Driver Assistance package and towing package
    Stock
    2016 Mythos Black Audi S3 P+, Black Optics Package, Tech Package, LED Lighting Package, B&O, Red Calipers
    Modded
    2001.5 Brilliant Black Audi S4 Sedan 6MT
    Stage 3
    Aug 17 2010
    Vancouver, BC
    Quote Originally Posted by AudBoost View Post
    Recalled!!
    Most unfortunate, never a good thing to need work due to manufacturing or design defects. What is your build date?
    2011 S4 (Cdn Spec) premium, 6MT, Quartz, Eurocode SS, APR Ultracharger, DP Stage 2 & CPS, Carbonio intake & exhaust, Ported S/C by Matty
    2013 Q5 3.0T S-line, EPL Stage 1 (the missus' car) 2007 RS4 (sold)
    Apr 05 2005
    Tampa, FL
    Just spoke with two Audi dealerships in my area and both said the recall won't be able to be performed until March??
    2016 S6
    Apr 05 2005
    Tampa, FL
    Quote Originally Posted by JonS4 View Post
    4/11
    2016 S6
    Veteran Member Four Rings Docwyte's Avatar
    Feb 02 2005
    '03 911 Turbo, '15 Cayenne Diesel
    Nothing for my 2011...
    '15 Porsche Cayenne Diesel ** Wifes DD
    '03 Porsche 911 Turbo 6 MT **
    '18 Land Cruiser ** My DD
    '17 KTM 690 "Adv"
    Oct 04 2012
    Berthoud, CO
    That's what I was just informed as well. No parts are slated to arrive until mid/late March.
    My car has Audi care and I am waiting to have oil change, DSG service all done with the recall. Now I must wait.....
    Deactivated Three Rings
    Oct 03 2014
    Boston
    It's weird you would think it would be a contiguous range of time that had the issue, but mine doesn't have the recall and is a late later build 05/11, so maybe just the really late 2011's and early 2012's because they changed something for the 12 model year that made it into late 11's?
    Veteran Member Three Rings tanklee's Avatar
    Dec 31 2004
    NJ / Miami
    they currently have limited supply of parts for this recall, so most likey you guys have to wait til march. also, not all VINS that fall under this recall get a new thermostat or crankcase breather valve. depending on the criteria number, you may get just the fuel recall, or fuel recall and thermostat, or all three.
    2000 B5 A4 Quattro
    2000 B5 S4 6spd Stage 3
    2014 B8.5 S4 DSG
    2005 B6 A4 Quattro USP
