Results 1 to 40 of 42
    Veteran Member Four Rings chrissurfr's Avatar
    Apr 26 2005
    Houston
    20x10.5 BBS CHR guys...tire questions....PSS 285/30/20
    Good morning, gents;
    I recently put CHRs on my car, and the stock P-Zero tires with a stretch ride like absolute dog sh*t. Is the PSS in 285 any better? Also, I'm low low so I'm worried about rub. Perhaps it could be dialed it with more camber, but I don't want to go extreme. Any feedback would be appreciated....
    Thanks,
    Chris
    2017 Cement Grey TRD Pro 4runner
    2014 Suzuka Grey RS5 >:)
    • AWE Track Exhaust with center muffler straight piped
    • H&R Street Coilovers
    • BBS CH R - Gold with red caps
    • eCode headlights
    • Eventuri intake
    • JHM Stage 2 ECU/TCU
    • other things I forgot about
    Veteran Member Three Rings HP Hungry S5's Avatar
    Jun 14 2012
    2016 Silverado Z71; 2006 CBR1000RR
    275/30 or 285/30 will work. If you are super low I would go with the 275 and also run adjustable control arms to dial in the camber so the ride is somewhat better.
    2009 Audi S5 | 20x10 AG M510 Wheels | H&R Sport Springs | APR Carbonio Intake | AWE Touring Exhaust | AWE Non-Res DP | APR Stage 1 Tune | StopTech | FL Shift Knob | RS5 Grill | Satin Black Vinyl Roof/Diffuser/Splitter | Tint
    Sep 30 2009
    b
    the more beef the better
    from the pictures I've seen of your car, you still have plenty of room for more tire.
    but some detailed side angle shots would help determine what you got going on.
    PSS are also very meaty compared to a lot of tires.
    Veteran Member Four Rings Sgibb16's Avatar
    Jul 02 2012
    2012 A5 & 2002 Passat Wagon
    Fredericksburg, VA
    Check @mops pics for PSS 275/30 for pics
    2012 A5 P+ | Sports Package | 6MT | 35% Tint
    REVO Stage II | AWE Quad Exhaust | 034 HFC | E-Codes | FK Silverline Coils | JHM Short Throw Shifter | Eurocode HFIC Pipe | Roc Euro Intake
    TR8 Intercooler | CTS Silicone Hose Kit & Turbo Outlet | CR-15 Strut Brace | Alu Kreuz | S-line Front & Rear Bumper Conversion
    Veteran Member Three Rings Racedoc11's Avatar
    Sep 26 2012
    2013 Rs5 , 2008 M3 Vert
    PA USA
    I have the same wheels and I'm lowered on H&R eo no rubbing with 285/30/20 PSS. I would love to go 295/30/20 but I'm afraid it might rub
    Sep 30 2009
    b
    ^ seriously looks like you could pull off a 305
    Sep 26 2012
    PA USA
    I think it might rub on full steering lock but I would love to have 305.
    Sep 28 2010
    NW NC / DE
    Those 285's look so good. The sidewall profile is slightly less stretched, and the leading edge of the sidewall is a bit closer to the wheel, bit it still has a bit of gap (I like) and that somewhat rounded profile that accentuates a concave wheel. A bit larger TD too. Love it.
    Veteran Member Four Rings LimaSierra's Avatar
    Apr 26 2013
    2025 Infiniti QX 80 Autograph, 2024 Chevy Tahoe RST
    KIAH
    Quote Originally Posted by Racedoc11 View Post
    Why you gotta tease Doc? Your car is perfect! Sheesh! Hope you are well btw...
    Chris, I'm sure the PSS are a TON better than the crappy Pirelli's. As you say you can always adj the camber if you need to. I'd do the PSS if I were you.
    --Nate
    LimaSierraPhotography.com
    2014 Panther Black RS 5: Pics | Build
    Veteran Member Four Rings scottykenneth's Avatar
    Dec 01 2006
    S .NJ
    someone sell me your black BBS.. mops or racedoc cough- :)
    Instagram:ScottyKenneth
    ScottyKenneth's Build Thread
    PRESENT : White 2018 Porsche 911 GT3 ( manual) / 2018 Jeep Grand Cherokee Altitude
    PAST : 2018 White Carrera 911 GTS / 2018 GT Silver Carrera 911 GTS / 2016 Porsche Cayman GT4 / 2015 []RS5 / 2014 S5 / 2010 A5 SLINE / 2007 A4 SLINE / 2001 A4 /
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by scottykenneth View Post
    In a 2-3 months
    Dec 01 2006
    S .NJ
    In a 2-3 months
    oh worddddddddddddddddddddd-
    Sep 28 2010
    NW NC / DE
    Yea, I'm sure I'll be sporting the CI-R when it arrives. I'm not looking forward to going Ti again, but you know I'll have to try them. Mine will also come with freshly painted gloss black rim guards. That should happen in the next couple of weeks.
    Veteran Member Three Rings Brozee's Avatar
    Oct 12 2009
    Oxford, MI
    Are you on H&R Street Sport Coilovers? This pic may just be the evidence i needed to pull the trigger on 285/30/20 vs getting the smaller 275/30/20
    2013 S5
    APR Stg. 2+ Ultracharger, DSG, CPS | Full AWE Touring Exhaust | Roc-Euro Intake | H&R Coilovers | MRR GF6 | 034 Trans + Diff + Subframe Inserts | Apikol Rear Diff Mount | CR-15 | Full Eurocode USS Suspension | DEVAL CF Rear Diffuser | Adams Rotors / Akebono | Stoptech SS Lines | RS5 Grill | Tint | LED Interior, Reverse + Turn | HID Fogs | Escort Max 2
    Apr 26 2005
    Houston
    Just ordered a set. Thanks racedoc for the pics....
    • eCode headlights
    • Eventuri intake
    Sep 26 2012
    PA USA
    Quote Originally Posted by H8H8 RS 5 View Post
    --Nate
    Thanks Nate! It is a picture from the summer. We are here about to get buried in the snow
    Quote Originally Posted by Brozee View Post
    I'm on H&R OE springs but I'm planning on installing H&R Street Performance Coilovers once the winter is over.
    Dec 01 2006
    S .NJ
    Yes! Dibs :))
    Sep 28 2010
    NW NC / DE
    Yes! Dibs :))
    Congrats
    Veteran Member Three Rings Avantmaniac's Avatar
    Feb 21 2007
    2011 S5/2011 A4 AVANT
    Houston, TX, USA
    I might go with 285 but for now 275 is suffice.
    [IMG][/IMG]
    - iKe -
    2011 S5
    2011 A4 Avant
    Veteran Member Three Rings choice89's Avatar
    Sep 26 2013
    San Antonio TX
    I'm running 285/30/20 Michelin Pilot Sport AS3 on 20x10.5 Vossen CV5 square all around. I ran H&R OE springs for a year and had absolutely no rubbing at all big bumps fast...slow...no issues. But I had a bit of a fender gap at 27 1/2 FTG measurement that I just could not take anymore...and finally I pulled the trigger and went with a full coil over Bilstein B16 Ride Control setup with IRC module to bring her down to earth.....initially down to 26" FTG all around....rubbing experienced on small bumps...big bumps...hard turns...no good.....then raised and now sitting at 26 1/2 FTG all around and only really big bumps do I rub. So I'm happy with the setup and feel.
    BEFORE: H&R OE
    AFTER: Bilstein IRC coilover
    2013 Audi S5 Phantom Black Premium Plus
    Full AWE Exhaust System/APR Stage I Tune/Stage II APR Tune/APR Supercharger Pulley Upgrade
    Roc Euro Cold Air Intake System/Meisterwerk adjustable short shifter
    VIPER 5906 2 Way Remote Start Alarm System/ JL Audio Sub 12"
    Vossen CV5 Graphite/Machined 20x10.5 Michelin 285/30/20
    Bilstien B16 IRC Coil Over Kit with Module iPhone Control "1.65 drop all corners
    Escort Passport 9500 CI Radar System/Show-n-Go License Plate Motorized Holder
    Oct 12 2009
    Oxford, MI
    Quote Originally Posted by choice89 View Post
    Thanks for your input. Do you think going with a 275/30/20 instead would have helped your problem at all or would you still go with 285/30/20 given the chance?
    2013 S5
    Feb 08 2013
    2019 Cayman GTS, 2016 Forester XT, 2013 S5, 2011 A4 avanti, 2004 TSX
    BEFORE: H&R OE
    What offset on your Vossen? I have 20"x10.5" ET25 CH-R wrap on 275/30/20 PSS too. When I have my H&R OE spring, I have no issue at all. But after swap to H&R coilover, I have the big rubbing issue as well. So I have to raise it up a 1/2" but still rubbing once a while. The first pic is with OE spring and the second one is with coilover
    2019 718 Cayman GTS 6MT
    2016 Subaru Dark Grey Forester XT touring
    2013 Audi Phantom Black S5 6MT Sport Diff, 20" BBS CH-R, Navi, B&O, PSS10, AK, EC sway, Alcon BBK, RS grille & Ecode
    2011 Audi Deep Sea Blue A4 Avant prestige, 19" OEM Ti rotors, PSS10, AK, sway, RS style grille + rear spoiler, Votrex diffusor
    2004 Acura Premium White TSX 6MT
    Sep 28 2010
    NW NC / DE
    275 vs 285 can 100% be rub vs no rub. If you were to do a 285 on a standard body 5 and drop it much, go with a V12 for a profile more conducive to not rubbing. Going forward, BBS is doing a 10" ET25 for the Audi fit. That way we are back around ET30, and can run a 275 and have hardly any stretch, and use small spacers if we choose.
    Apr 26 2005
    Houston
    Quote Originally Posted by ians View Post
    You are rubbing because of your alignment setup. I would dial in a little more camber to fix that. I have no rubbing on mine at all currently with 275
    • eCode headlights
    • Eventuri intake
    Dec 01 2006
    S .NJ
    Mops. What are yours? 10 or 10.5
    Feb 08 2013
    Quote Originally Posted by chrissurfr View Post
    Is it because RS5 has wider fender than S5? dun really want to have visible negative camber and eat up the tire
    Sep 28 2010
    NW NC / DE
    10.5 ET25 with 3mm rear
    IMG_2689 by Audiyos, on Flickr
    Sep 28 2010
    NW NC / DE
    Correct. You can clearly see they are standing straight up. I actually prefer a good -2.0. I could care less if I lose a bit of tire life to ensure my fit is what I want.
    Feb 08 2013
    So am I need adjustable control arm to achive -2.0 camber?
    Sep 28 2010
    NW NC / DE
    You'd be surprised how much that would help. You'd basically be taking the top of the tire in 5-7mm. Not sure you need arms though. What you see above is -2.5 to -2.7 and it came naturally with low :)
    Feb 08 2013
    Should try to do that after winter then
    Dec 01 2006
    S .NJ
    Yummy. Get some stockers and send these my way lol.
    Dec 01 2006
    S .NJ
    Same setup on old A5sline. H&R coils 3mm rear spacer. Maybe slight rub over big dips. But basically none. 275 tire
    Sep 28 2010
    NW NC / DE
    ^And with a V12 and that natural camber, you're gonna have next to no rub.
    Sep 26 2013
    San Antonio TX
    My Vossens have a +30 offset.
    Sep 26 2013
    San Antonio TX
    Well I'm sure by going with a shorter profile tire such as a 275/30/20 it would provide me just that much more clearance and probably less rubbing.....how much though is a mystery to me because I have yet to run that setup. When it's time for new tires I might have to try that option, trust me I am very curious as well.
    Apr 26 2005
    Houston
    Tires are on. No rub....fills out the fender gap much better
    • eCode headlights
    • Eventuri intake
    Sep 28 2010
    NW NC / DE
    Love it! The RS handles that fit very well. The A/S would not.
    Dec 01 2006
    S .NJ
    Lookss great!!
    Senior Member Two Rings JAG836's Avatar
    Jul 01 2013
    Cleveland, OH
    Is dis still gonna happen (bold text above)? I deliberate between wheel and tire size combos multiple times a day. It is a heavy burden to bear.
