Page 1 of 6 123 ... LastLast
Results 1 to 40 of 201
    Sep 27 2008
    Phoenix
    Mixing 91 octane and E85?
    There was some discussion in another thread about adding a couple gallons of E85 to a tank of 91 octane to increase performance. I used the calculator from http://www.intercepteft.com/calc.html and it looks like 2.5-3 gallons of E85 would raise the octane level to 93 and the ethanol content of a tank would be around 22%. Is it safe to add E85 to 91 octane to boost the octane level to 93?
    Senior Member Two Rings _muppet_'s Avatar
    Mar 22 2009
    Clarion PA
    No, don't do that. E85 is higher octane, but requires a richer mixture. You will run lean mixing like that without tuning for it.
    Sep 27 2008
    Phoenix
    Quote Originally Posted by _muppet_ View Post
    I forgot to mention that I am running JHM stage 1 so the tune should adapt to the higher octane.
    Mar 22 2009
    Clarion PA
    Octane is not the issue here, the issue is that e85 requires a richer mixture, and unless the tune was made for this strange blend, then the ecu is only going to inject enough fuel for the proper mixture using gasoline.
    Veteran Member Four Rings Andrew149's Avatar
    Apr 19 2009
    Modesto/CA
    I wish it was that easy to get to 93 octane
    Sent from my HTC One_M8 using Tapatalk
    2012 Audi A6 3.0t
    2019 GTi 2.0t 6 speed
    2013 Touareg VR6
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by Andrew149 View Post
    Must be a west coast thing. 93 Octane is a normal thing here
    Mar 22 2009
    Clarion PA
    Yeah, but E85 isn't. I'd love to be running it in my vrt, but I'm about two hours from the closest station with E85. I think I'm about as far away from E85 as one can be in the state of PA.
    Mar 24 2013
    Oakdale, CT
    ^This is wrong. The car adds fuel based on the lambda value it is reading from the O2 sensor. 1.00 lambda is stoich no matter what you are burning. It simply measures the excess oxygen present in the exhaust. For older cars that have no O2 sensors or simple narrow band sensors, yes, you would need tuning. The 2.0 is advanced enough to where this wouldn't cause any trouble. I have done it before with 50% of my tank being E85, and the only differences I saw were changes in fuel trims due to the car needing to flow more fuel to put out the same power. This increase in fuel trims is proof that the car can and will add the extra fuel it needs to keep everything happy.
    -Adam
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    i heart you adam....I wanted to post this all day...but I was waiting for someone else to chime in and fuckin set the record straight. You give me confidence in this platform. Maybe one day we can ascend past the shitty products like frankenturbo and get on a new level. Like the evo kids. But we would obviously look way cooler going fast because our cars don't look hilarious.
    Mar 24 2013
    Oakdale, CT
    I got you bro.
    -Adam
    Veteran Member Four Rings ericpaulyoung's Avatar
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    The limiting factor is maximum fuel delivery. The Motronic will adjust, but its ability to do so is limited. For a stock K03 style setup, it can probably adjust enough. For a K04 or higher, you will start hitting limits in the low pressure delivery system. Which is why Seth has a drilled pump etc. But yes, the Motronic adjusts to Lambda and not AFR, and is a great system. :)
    epy
    Epy
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by ericpaulyoung View Post
    epy
    Seth is also running straight E85 and not a mixture. Adding 2 gallons of E85 to a tank won't hurt anything if your fuel system is functioning properly.
    Edit: IIRC, the max adjustment it can make is +/-20%
    -Adam
    Sep 27 2008
    Phoenix
    So no concerns with gaskets, seals, rings, or HPFP? Is anyone here mixing E85 with 91? Other than lower mpg do I have anything to worry about? I heard that a number of BMW drivers were running this mix, would that be the best place to find more information?
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Quote Originally Posted by wootwoot View Post
    Oh ya, definitely worry about that stuff. Just part of the game. E85 eats a lot of different stuff, and will also "flush" out your tank and lines. So all the gunk will end up in the injectors etc. But if you are pulling and cleaning your system right, you will be fine.
    epy
    Epy
    Apr 19 2009
    Modesto/CA
    Found this post full of information http://www.e90post.com/forums/showthread.php?t=665920
    2012 Audi A6 3.0t
    2013 Touareg VR6
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Yes, I agree. So look at what the volumetric mix will result in a 20% decrease in energy density, and boom, you got how much you can theoretically "cut" your petrol with corn and get away with it. But that is the theoretical amount, you can't actually achieve this. I would say go for a 15% change as a max.
    epy
    Epy
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    I heard that e85 with murder your mother and rape your father! Should I use only a 25/75% mix?
    Should I mix by volume or by mass?
    Should I invest in an e85 test kit so I can find out how much ethanol there really is in my e85? Should I Run e85 in my meth? FUKKKEKKEKEKKK
    Apr 19 2009
    Modesto/CA
    I have e85 next to my house I'm curious by starting out with 2 gallons in my car
    2012 Audi A6 3.0t
    2013 Touareg VR6
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Well the bitch of the situation is that E85 actually is like screwing the prom queen's sister. It is the methamphetamine of the cocaine racing scene. In no way is it as good as race gas, but people use it because it is CHEAP in comparison. The bad part is, well it may have high octane like race gas:
    1. Corn has much lower energy density
    2. Corn has serious corrosive properties
    So in reality is it truly the poor man's racing fuel. B. U. T. that doesn't make it bad, it just means you have to take care to treat it properly. So where your rich friends are blowing through 7 gram rocks of glory with porn stars, you can have just as much fun pulling green vapor off tin foil hits and strippers. You just have to have the right mind set.
    epy
    Epy
    Apr 19 2009
    Modesto/CA
    At the pump now
    2012 Audi A6 3.0t
    2013 Touareg VR6
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    At the pump now
    Definitely only put 2-3 gallons in. And give it a few miles to adjust the fuel trim before stepping on it.
    epy
    Epy
    Apr 19 2009
    Modesto/CA
    epy
    Sounds good
    2012 Audi A6 3.0t
    2013 Touareg VR6
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Unless you are on a tune that requests more timing, you might not feel a difference. But, just remember that you are clearing your system of all the build up gunk. So give it a few flushes, and them put the "race gas" tune on and give it a shot. You should be able to push more timing before knock with little problems.
    epy
    Epy
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    May the force be with you brother!
    epy
    Epy
    Veteran Member Four Rings RAudiB7A4's Avatar
    Nov 08 2010
    2015 Hyundai Santa Fe Sport AWD
    Rochester/MN/Mid West
    All I have run in the B7 for the last 3 years is BP 93, and I have E85 everywhere around me. I'm planning on switching to JHM soon but for now I'm on APR's 93 tune. I'm sure I couldn't mix enough E85 to get me to 100 octane for my race fuel tune from APR correct???
    DTM_B7_S4
    Previous car: APR_Stage_II+_B7_A4
    Apr 19 2009
    Modesto/CA
    epy
    For sure worse case is my fuel system gets cleaned
    epy
    2012 Audi A6 3.0t
    2013 Touareg VR6
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    Quote Originally Posted by RAudiB7A4 View Post
    Yes. If you have not reached the limit of your fuel pump or injectors, then definitely you can.
    epy
    Epy
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Sounds good
    You have really expensive gas....2.09 gets me 91 octane!
    Apr 19 2009
    Modesto/CA
    Damn, this is at a cruisers so it's normally cheap
    E85 is in the car and it started smoothly let's see what happens
    2012 Audi A6 3.0t
    2013 Touareg VR6
    Veteran Member Four Rings derrek's Avatar
    Jul 23 2010
    arizona
    When you talk and no ones listens.......
    Nov 08 2010
    I'm not sure if I have or not?! I've run the race fuel (100 octane) tune a few times, but always on 102 unleaded or 110 octane leaded fuels. I can get 110 octane leaded 5 miles from my work. I've ran about 15 gallons through the B7 without any ill-effects.
    I have read that leaded fuels are most dangerous for clogging catalytic converters (which I don't have because test pipe), and hard on O2 sensors if you run to much of it.
    But the 110 octane is like $8+ per gallon! E85 is around $2 per gallon.
    DTM_B7_S4
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Quote Originally Posted by derrek View Post
    Dude I've been waiting for you! Where have you been?
    Ladies and Gentlemen, the b7 resident e85 spokesman!
    Jul 23 2010
    arizona
    been at the track raping my car all weekend
    Apr 19 2009
    Modesto/CA
    Car feels like it gained a lot of torque
    2012 Audi A6 3.0t
    2013 Touareg VR6
    Jul 23 2010
    arizona
    leaded fuel will clog cats and 02 sensors and you wont see any gains with it over 100 leaded unless you're tuned for the higher octane
    Jul 23 2010
    arizona
    how much did you mix?
    Apr 19 2009
    Modesto/CA
    2.5gallons and filled up the tank with 91
    2012 Audi A6 3.0t
    2013 Touareg VR6
    Nov 08 2010
    Yeah I know that, but I can get leaded 110 octane fuel 5 miles from my work or get 102 octane unleaded 80 miles away... I can get E85 everywhere around me, and 93 octane with in 10 miles of my home. All I have run is 93 octane for the last 3 years.
    DTM_B7_S4
    Jul 23 2010
    arizona
    so you should be around e22, i didn't notice to big of a difference when i ran that mix. I run e50-e60 now and use my race gas file. you should log your low pressure fuel trims, afr, and timing pull to see how its running.
    are you getting at the pump or in 5gal drums from vp or sunoco
    Jun 17 2013
    jersey city nj
    Sounds good
    Shit 1.99 a gallon for E85. Its a 1.99 a gallon for 93 octane over in NJ
