Results 1 to 15 of 15
    Mar 05 2013
    CA
    Self-adjusting clutch components
    Clicky
    How are you all doing this?
    Aug 27 2013
    Philly
    We dont. Install new clutch and walk (Crawl) away. The SAC pressure plate will handle the rest. I believe this why the clutch pedal goes through various changes of "feel" during the break in period. I want my butter soft clutch back!
    Mar 05 2013
    CA
    Quote Originally Posted by SJorge3442 View Post
    I think the clutch friction disc is self-adjusting too.
    You have to set the pressure plate and make sure its working as intended. If you do, enjoy 200k mi+ of awesome driving. If not, smell burnt clutch and feel slippage.
    However, if ALL the parts are new, its pre-set from the factory.
    But, physical shock throws it out of wack. Such as from shipping the parts. Let's just say my once-rectangular box arrived at my door-step looking like a potato. Pretty sure I need to somehow adjust things.
    Self-adjustment meaning you set the initial point, and it adjusts from there to account for clutch wear.
    http://www.audiworld.com/tech/eng86.shtml
    https://www.youtube.com/watch?v=Tp5K...yt-cl=84503534
    http://www.schaeffler.com/remotemedi...ech_sac_en.pdf
    http://www.repxpert.com/lukas/binary...document=28509
    Aug 27 2013
    Philly
    I'm unsure if this is a 100% neccsary step or not. I have never read a recent DIY that referenced setting anything on the PP. I know my Luk instructions said to straightup install and be on your way. If you are reusing a pressure plate, you have to reset the SAC mechanism.
    Sep 16 2010
    Central Wash
    ^^ What he said. You're OVERTHINKING it! Clutch disc doesn't adjust- they just wear. If the pressure plate AND disc adjusted you'd have a pretty complicated system. Bolt it on.
    And no, the parts don't go out of adjustment by 'shock' or whatever, if they did we'd all be screwed because every time you dumped the clutch the adjustment would change and EVERY pressure plate would show up with faulty adjustment. The parts have to be more durable than that.
    I like how that guy up there removed the trans in 47 seconds by removing the one bolt holding the axle on and one trans mount. I bet only half the dealers in the U.S. had that clutch adjusting kit, and the half that did ever get it have never used it.
    Seriously- use the complicated and expensive clamp/screw adjusting setup...or make 700% profit on replacing parts.
    Which do you think they would rather do?
    Veteran Member Four Rings drjonez's Avatar
    Oct 27 2009
    2011 Q7 TDI Prestige, '72 Nova
    The Cheese State
    Skip all the foolishness and install something different- no DMFW, no SAC. KISS.
    It has been beaten to death, but the Valeo clutch kit is the one for 98% of B6 owners.
    '11 Q7 TDI Prestige
    Function > Form
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    my valeo has been very smooth got the single mass(non lightweight) and its been great
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Veteran Member Three Rings NathanGrayW's Avatar
    May 17 2014
    Akron
    +1 for the Valeo kit :p
    Difficult to drive the first time though lol
    2004 A4 Ultrasport 6MT "Almost-Brilliant" Black
    APR 1+
    Aug 19 2013
    minnesota
    My south bend stuff just bolted up no fuss. Adjustment? hah!
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Jun 27 2011
    The SAC mechanism is a double edged sword. I keeps pedal feel consistent over the life of the clutch, and can even extend the clutch life a bit longer, but its also somewhat prone to failure. The 240mm audi clutches (b5 s4, b6 3.0, all b7s) generally all have an SAC mechanism, while the 228mm ones generally don't. So us 1.8t guys don't have SAC on our clutches. Frankly I'm okay without it. My b7's clutch has really wonky takeup and I think it has to do with faulty SAC. Its relatively common for failures of SAC on the b7 forum (relatively as in common within the subset of b7 forum-going enthusiasts with 6mts who actually do their own work).
    Anyway, SAC is both good and bad I guess. Generally, when it comes to extremely tedious parts to replace, like clutches, I would tend toward simplicity over complication. SAC is just one more component that can fail, and thus it makes me less than excited to deal with it. I know a number of b7 guys who have reset the SAC on their clutches though without any fancy tools. I don't think its that complicated at all.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Sep 16 2010
    Central Wash
    My only gripe with the ECS tuning non-SAC unit is that "compared to" the Rs4 pressure plate there is literally almost zero pedal feel / feedback at all. It's totally driveable, I would have used the ECS kit on my V8 but I still haven't heard how much power it reliably holds.
    I could live with a lighter pedal and I'd prefer a SMFW- but to get one that works with the Rs4 unit costs twice as much.
    Mar 05 2013
    CA
    OK so apparently the clutch friction disc is not self-adjusting, but only has springs in it for dampening purposes. However, the pressure plate is called "self-adjusting". I assume that because it all makes up the "Clutch Kit", that is why they call it SAC.
    Note that in the video, it clearly states this procedure is for a new clutch disc, but used pressure plate. I assume that is what they are re-setting to work with the new clutch disc, since before that it self-adjusted to the old clutch or something. Which agrees with Audi factory procedures, that are basically like "don't touch anything, just install it" if everything is new, but they say you need adjustment doing the aforementioned method (new clutch, used
    However, starting a 3:40 makes it seem the tool is still necessary to install the PP, regardless of whether its new or not. It appears that without it, one could warp it, which I believe the manual warns about.
    For those of you who have seen the funny special tool control arm video, I guess that is his brother. (the link escapes me)
    I also wonder how it can stay in adjustment setting after going over the amount of bumps that a car hits, especially with a sport suspension. If I can feel it in the drivers seat, I imagine the pressure plate does too.
    Quote Originally Posted by drjonez View Post
    Maybe next time. IIRC, it would've been twice more expensive for a single-mass setup on the 3.0. My clutch friction disc is Valeo, it seems everything else is LuK though, and SAC as you said.
    Mar 05 2013
    CA
    Quote Originally Posted by rollerton View Post
    I understand your point, but Mathew J. Reid, Vice-President of Induktion Motorsports, seems to disagree. My PP looks exactly like his in the first pic, and mine too was jarred up quite a bit.
    ding ding ding
    Section 5.4, SAC installation on new components. Bolt it on. It's that simple. No special tools. I guess those are, again, only for used PP's, to re-adjust to new clutch discs...
    That still doesn't settle the AudiWorld write-up/claim by Mathew that the factory setting is ruined during aggressive shipping, requiring a "reset" as shown in the link
    Jun 30 2008
    Erie, Pennsylvania
    Quote Originally Posted by Spike00513 View Post
    Yeah, probably. But you just run the bolts in "evenly" and in a staggered pattern, like you would for a valve cover or cylinder head, and you'll be fine.
    Jun 27 2011
    This.
    Also given the way the mechanism works, its nearly impossible for it come out of adjustment while installed in a car (barring any sort of mechanical failure due to a defect or improper install procedure). In shipping, while the PP is attached to nothing, I suppose its possible that it could wiggle out of alignment.
    I'm pretty sure Sachs/Luk designed the mechanism to withstand shocks and vibration FAR above normal operating conditions while installed in a car. Lets not make a mountain out of a molehill here. Next time a ZOMG THIS COULD BE A PROBLEM NOBODY HAS EVER THOUGHT OF BEFORE!!!!! comes up, use some reasoning and logic skills, attempt to understand how the mechanism works, and trust that the engineers who designed an adjusting mechanism on a clutch know what the operating environment is for a pressure plate and engineered accordingly.
    -CP
    2017 Q7 3.0t
