Results 1 to 21 of 21
    Senior Member Three Rings Roaldtm's Avatar
    Jul 20 2014
    Martinez / Georgia
    S Line Suspension VS Non S Line
    I haven't been able to found specs and differences on the suspension, what is the ride difference? Are the springs different? I know the color and part numbers are different on the shocks and struts but that's as far as I know(I understand color is not the only difference but I have no data on them). My car came with Koni Coil Overs (Previous owner) which are blown and I have a S Line car I was wondering if the sports suspension is like or close to a Springs and shocks set up. Any pictures of the difference or info will be greatly appreciated.
    Senior Member Two Rings esm's Avatar
    Jan 14 2010
    Chicago, IL
    I went from OEM sport suspension to PSS9 coils. Its a harsher ride, for sure, but I love the stance and the cornering performance. Basic OEM to OEM Sport will see a drop of maybe an inch or so, and a bit tighter cornering. If your car was nicely dropped on Koni, the OEM sport suspension will be higher and you will notice the extra gap. I think I dropped around an inch going from Sport to PSS9. Overall, if you are used to Koni, I would not go back to OEM basic. Either stick with a cheap coiler (Koni or ST), a shock/spring setup, or OEM sport (maybe the most expansive of these options).
    2017 Audi Q7 3.0T Premium Plus: Vision / Cold Weather / OEM 20" 10-Spoke Wheels / Goodyear Eagle Sport All-Season Run Flats 285x45x20 / Weathertech Mats
    FORMER: 2005.5 A4 Quattro Tip / JHM Stage 2 93oct / JHM HPFP / AWE FMIC / JHM 3" Downpipe-Y adapter / JHM-Fast Intentions S4 Exhaust / RS4 RSB / Bilstein PSS9 Coils / VMR 810 19x8.5 on 245x35x19 Michelin Pilot Super Sports / Adam's AR II Slotted Rotors / Bosch Platinum Sidefire Plugs (Bosch Heat Range 5)
    Veteran Member Four Rings onedumslack's Avatar
    Mar 05 2014
    phoenix/az/usa
    Audi stated that OEM sport suspension is 30% stiffer than OEM non sport. As stated above, the drop is about an inch. I was able to slip 4 fingers in the rear of non sport and barely 2 in sport. It was tight.
    Nov 15 2011
    Montreal | I sell in USD
    If im not mistaking the sport suspension upgrade also comes with a 18mm rear sway bar instead of the 16mm.
    *****I sell in USD*****
    Mar 05 2014
    phoenix/az/usa
    Quote Originally Posted by Axis View Post
    Correct
    Veteran Member Three Rings falconcrest32's Avatar
    May 19 2009
    2008 A4 S-Line Quattro 6MT
    MD/NoVa
    Quote Originally Posted by onedumslack View Post
    that's what she said
    2008 A4 2.0T Quattro S-Line 6-speed *Phantom Black*
    [SIZE=1]| Kohlefaser Luft-Technik Intake | VagCom | Ti Grille | Michelin Pilot Sport A/S 3 | fly300kts Headlights | Pioneer AVIC-8000NEX | Huper Optik Tint | BFI Catch Can | RS4 Front Brakes | GFB DV+ | 034 Snub Mount | JHM TP & DP-Y | Fast Intentions B6 S4 Catback | S4 Recaros Black/Black Alcantara | B8.5 FBSW |
    Aug 14 2007
    Los Angeles, CA
    My '08 is "s-line" but just in appearance, so for most of it's life, I lived with non sport suspension. The above posters are correct that its a combo of springs/shocks and bigger sway bar that makes it sport suspension. I recently upgraded to OEM sport suspension and its a huge improvement - you can definitely feel the 30% stiffness improvement.
    Mar 01 2013
    USA/VA
    Where can you get the s-line suspension? I checked ECS for my A4 but they didn't show up under suspension like other s-line products would if they fit? I would assume it's a direct fit? Also how much would the s-line suspension cost against something like H&R with about the same drop? for the kind of driving I don't need a super aggressive drop.
    • 06 Audi 2.0t Quattro Avant - Drop in K&N, Sony App Radio, 034 Snub Mount & Bracket, Carbon Fiber Interior Wrap - Sold
    • 01 Audi A4 1.8t AWM Quattro - AWE Boost Gauge, 18" Avus S4 Rims, 8000k HIDs, 3000K HID fog light mod, Pioneer Double DIN, Krauto Interior LED Kit - Sold
    Veteran Member Four Rings Andrew149's Avatar
    Apr 19 2009
    Modesto/CA
    Quote Originally Posted by phatjames167 View Post
    H&R or Eibach are not much lower than the sport suspension.
    Sent from my HTC One_M8 using Tapatalk
    2012 Audi A6 3.0t
    2019 GTi 2.0t 6 speed
    2013 Touareg VR6
    Aug 14 2007
    Los Angeles, CA
    Don't know if you can buy new (maybe from Audi), but you can find a used set-up super cheap from someone upgrading to coilovers. I found a set-up locally and paid $50 for shocks/springs. I live in a city with a ton of bad roads so its the perfect drop for me. FYI, although its cheap to pick the parts up, you'll have to pay a bunch more in labor to swap out if you can't do DIY - our suspension requires the removal of a bunch of other parts.
    Veteran Member Three Rings audihere06's Avatar
    Nov 11 2013
    Charlotte NC
    Dont waste your money on s line springs. The ride is too crashy. H&R sports are a much better spring. As far as shocks its up to you. Im keeping my sports shocks as they will work with h&r sports. Bilstien and koni both ride well. Anyone who tells you that lowering the car will ruin the ride quality knows nothing. As long as the suspension is set up correctly it will ride perfectly and sometimes better than oem.
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    Quote Originally Posted by audihere06 View Post
    What do you mean by that?
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Nov 11 2013
    Charlotte NC
    Quote Originally Posted by DannyDeez View Post
    I have an s line and when on the highway it is fine but as soon as the road gets a bit bumpy the ride gets a bit rough or crashy if you will. The sports shocks are S4 shocks making them over dampened for our lighter/ higher riding cars. If paired with a good progressive spring they are much better. Plus the s line springs ride just a tad too high for my personal taste.
    Sep 11 2004
    16 Q5
    Westchester, NY
    Oh, gotcha. Thanks
    Dec 16 2014
    What would be a good spring/shocks combo you recommend people to get?
    Nov 15 2011
    Quote Originally Posted by Ninja View Post
    Imo the best combo is H&R sport coupled with Bilstein Sport.
    (On winter wheels)
    Active Member Two Rings calexbrown's Avatar
    May 12 2013
    2010 Audi A6 3.0T Quattro Supercharged
    Charlotte, NC
    (On winter wheels)
    How is that suspension with the wheels? Do the wheels rub?
    Nov 15 2011
    Quote Originally Posted by calexbrown View Post
    Those are oem wheels in 17x7.5 ET45, I never even come close to rubbing. On my summer setup neither btw which is 18x8 ET29. Both on 235 oem tire specs.
    The ride height is a tad lower than the sport suspension.
    Dec 16 2014
    (On winter wheels)
    Thank you for the recommendation. How are the spring rates of the h&r compare to the sline or even eibach?
    Nov 15 2011
    I dont know the specs of the spring rate of h&r vs sport springs but they're a tad lower while they are as confortable.
