Results 1 to 11 of 11
    Jan 21 2015
    Spokane
    some of my mmi buttons wont work HELP!!!
    I have a 2006 A6 3.2L s-line and i cant use my mmi fully because some of the soft bottons around the center knob wont work, so i cant use certain functions of the mmi. I need help or advice what to do with it. Im new to forums and audis and need help how to repair, fix it please. Sometimes the other bottons wont work either. The left buttons, nav, info, car, setup arent lit up and wont. Need help!!!!!
    Senior Member Three Rings discoverdeath's Avatar
    Aug 15 2010
    anahiem
    None of them are stuck?? Like a beverage spill? Also do you have a telephone prep module or bose installed on the vehicle. Last, have you 3 finger death punched the most system into reboot? If you look at your owner manual it will illustrate the procedure to reset the most system. Report back yo!!!!
    Jan 21 2015
    Spokane
    I can click each button and none of them are stuck but i have just recently purchased the car and dont believe a beverage spill was evident. Yes the car has the phone module in the arm rest and bose, all the right side buttons are lit up, but the left side are not. Also the center buttons around the center knob wont work. Cant change settings. I have tried the reboot, pressing setup, center knob and top right button it reboots and still same thing.
    Aug 15 2010
    anahiem
    Does the volume work? Functions on the steering wheel work, that's if you have the multi function steering wheel. The next step maybe ring break diag. Out there question, but did this happen after rain, or car wash?
    Veteran Member Four Rings Klum00's Avatar
    Nov 27 2006
    Baltimore, MD
    If some of the buttons work, but others do not, you'll need to replace/repair the actual MMI control panel.
    From all the cars we've seen with MMI issues, they system will totally shut off or non of the contorls will work if there is an issue with the amp or anything else that would require a ring break test.
    Quattro Kings
    @quattroking
    Currently in the garages
    2016 S6 . 2014 RS5 cab . 2013 Q5 . 2008 A6 avant
    2002 TT ALMS . 2001 S4 . 1992 UrS4 . 1974 100 LS
    1952 DKW RT125 . 1939 DKW F8 . 1937 DKW F7
    Jan 21 2015
    Spokane
    Quote Originally Posted by discoverdeath View Post
    yes the volume works, the turn dial works, cd, but others are iffy here and there. all functions on the steering wheel work well. what is a ring break diag? well it has been raining here quite a bit, I literally just bought the car earlier this week so I don't know much about it aside from the shape it was kept in.
    Jan 21 2015
    Spokane
    Quote Originally Posted by Klum00 View Post
    I have no issues with any speakers or anything else with the car, but it is very irritating when I cant use the buttons I need to even select certain settings. I bet the system needs an update but I cant even do that because I cant select the buttons I need to.
    Senior Member Three Rings SindreVjohnsen's Avatar
    Dec 21 2014
    Norway
    When I bought mine the mmi didnt light. Only handbrake and steeringwheel buttons. So I got a new one from the scrapyard/ part car. 100EUR . So its not that bad in price to just replace it if u find one local.
    If you anyway have to take it out to clean it. Heres an video link how to :)
    https://www.youtube.com/watch?v=SH1PrInREi4
    -Artic White Avant, 2.7 quattro
    - Audi A6 Avant , Shadow Line , ABT kit. (sold)
    Jan 21 2015
    Spokane
    Quote Originally Posted by SindreVjohnsen View Post
    Ok. I might have to check the scrapyard to see if one is available at a decent price. Yeah the only lights on this morning are the words on the buttons on the right. none of the little lights for each button work either. none of the buttons are sticky or anything and depress perfectly. but for some reason wont work. sometimes when I press the soft button to the left of the center knob it starts moving the mmi are on the screen.
    Dec 21 2014
    Norway
    Strange :/ Then its probably broken in some way. So happy hunting for a cheap new one :)
    Jan 21 2015
    Spokane
    ha great! thanks I appreciate the luck, ill need it
