So I have a 2002 A6 2.7t (auto) with ~170k miles on it. I replaced battery and alternator last winter (almost exactly a year ago) when I was doing a timing belt/water pump/valve cover gasket job. Battery has been strong and never slow to start or left me stuck even on the coldest nights this year. So I don't think it's that... now... the issue.
The car has been starting fine and running fine but today when I left work (about 7 hours after getting there, car hadn't been started at all during that time) it had a big issue starting. The key would turn and the engine seemed to turn over fine and strong, but wouldn't start. If it DID start it was for like half a second to one second when the rpms would jump to about 1,000 and then almost immediately stall. I did this about six times with it starting maybe four out of the six but stalling right away. Each time it seemed to start strong but just wouldn't catch and when it DID for that second or so before stalling it sounded HORRIBLE and really weak. I let it sit for a few minutes trying to think what it might be. Started it again and pounded the gas AS SOON as it started, expecting at least a quick roar before maybe stalling, instead it was like a kill switch, it died the SECOND I floored the gas. Did that a couple times with no change. Decided to hold the gas pedal to the floor and try to start it while doing that and it wouldn't catch and start at all, again, started and battery power seemed strong. Decided to try the opposite of that and be SUPER gentle on the gas as soon as the engine caught and I was able to push the rpms up to like 1200 for maybe three or four seconds while it sounded rough and really uneven (misfires maybe? Just really weak, like hardly running but it was showing 1200 then bouncing down to maybe 200 and then back to 1000 and back down again and then stall). I did this a couple more times while being SUPER gentle on the gas and it got better each time till finally the 3rd or 4th time it didn't stall, but still sounded weak and really rough. I let it run for maybe a minute just keeping a super steady gentle pressure on the gas till the engine sounded almost normal. Then I pushed down harder and it ALMOST stalled so I let the gas up right away and it coughed a couple times and leveled out at ~600 rpm again. I was able to rev it up to maybe 3000 or 4000 rpm if SLOWLY using the smallest increasing amount of pressure on the gas. After about two minutes of the car running almost normal sounding between 1,000 and 3,000 rpm I decided to put it in gear and see if it would stall (didn't), then letting off the brake and seeing if it would roll without stalling (it did roll), and then decided to drive home the back roads going super gentle since I only had about 1 mile to go on residential streets that are almost always empty. It made it home but seemed to cough a little bit once when I pushed the gas a little harder off a stop sign. If i was super gentle I could get it up to like 10 mph fine (didn't try going above that) and transmission seemed to shift fine on it's own. Battery was showing ~14v. By the time I made it home and into the driveway I floored it while in park a couple times and it sounded basically normal again. Strong sound, normal amount of lag, full rev without shutter. Turned the car off, talked to family about my day and had dinner. Went out just now after 3 hours of it sitting there and it did start on the first try while my foot was off the gas but seemed to be shuttering and when I pounded the gas it would dive down to like 200 revs and almost stall before starting to rev up again to maybe 2500 rpms which was when I let off the gas again. It would shutter a little and then level out at normal idle. Pound the gas again and it repeated the same thing. Decided to turn it off and come report back to you guys. I'm catching a ride to work tomorrow just in case she doesn't start in the morning or make it home from work, easier to work on it here then in work's parking lot, lol
What do you think is the issue? Recommended parts to replace? Links to DIY/parts? Thanks guys!!!
(Sorry for the long post, just wanted to provide EVERY bit of details and info I have... also, yes it had gas, about 3/4 a tank)
