Results 1 to 13 of 13
    Dec 18 2014
    Huntingtown, MD
    SiriusXM with aftermarket HU
    I just installed a JVC double din head unit and want to hook up siriusXM to it. I know the car is set up to readily accept satellite radio, but is it possible to use the same hookups for an aftermarket head unit?
    Thanks!!
    Dec 18 2014
    Huntingtown, MD
    Has nobody tried to do this?
    Account Terminated Four Rings
    Apr 18 2013
    Right
    For the head unit I use there is no hook up. Just use the phone app if you have unlimited data and plug it in.
    Dec 18 2014
    Huntingtown, MD
    No unlimited data :(
    My HU is siriusXM ready but the hookup is different from what's available behind the radio
    Apr 18 2013
    Right
    Then you need a new SiriusXM cable. You post doesn't make much sense. You radio is SiriusXM ready but your radio doesn't have the wire?
    Dec 18 2014
    Huntingtown, MD
    The car has a wire and hookup that ties into the back of the stock HU. My new head unit is SiriusXm ready, but the connections are different
    Apr 24 2014
    CO
    if your aftermarket HU is sirius XM ready, then you need the add on tuner. You could put this in the trunk where the oem tuner is/was and use the factory antenna, that's what I would do.
    The aftermarket HU won't talk to the audi tuner or use the existing wiring to the trunk easily. I mean, you could probably cut the harness off at the back of the OEM HU and splice the aftermarket cable and do the same at the other end, but to me it's just easier to tuck the wire up to the headunit.
    this is what you need
    http://www.crutchfield.com/p_220SXV2...9238465&awdv=c
    Dec 18 2014
    Huntingtown, MD
    Ok, so new tuner and wire to the head unit, but I can use the existing antenna? That's mostly what I want to do, is to use the existing antenna
    Apr 24 2014
    CO
    Quote Originally Posted by ImAudiMyMind View Post
    Yes. worst case you need an adapter depending on how old your car is and if you have a two wire or one wire antenna.
    Apr 18 2013
    Right
    An adapter seems like a better option that cutting a splicing.
    Apr 24 2014
    CO
    Quote Originally Posted by mccorkled View Post
    what? No one would cut and splice an antenna cable nor was it suggested.
    Dec 18 2014
    Huntingtown, MD
    Car is an 06 with one wire at the head unit. Not sure about in the trunk.
    Apr 24 2014
    CO
    what's at the headunit has nothing to do with anything
