final angle torque. But my new head is weeping a bit of oil from the right front corner
right above the timing belt tentioner where is meets the head- this isn't my engine but it shows where the head is leaking.
Can I let the engine get dead cold, back out just that one bolt and replace with a new one and re-torque
or do I need to do the whole set, or can I put a bit more torque on the one bolt as is?
Any recommendation would be great
- Resurfaced and rebuilt head
- VC gasket not leaking visibly
- Cam seals fine
- new OEM head gasket, positioned correctly
- correct tightening pattern
- New Oem bolts
- No coolant leaks or coolant in oil
- plugs clean and dry
- Compression even across all cylinders, car starts right up, no smoke
