Results 1 to 20 of 20
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Hood release not working, how to get it open??
    I recently got my car back from the body shop and discovered the hood won't open. The body shop is an hour away and the car is needing some oil, is it possible to open the hood if I can get at the latch? I tried removing the panel under the radiator and could really get up there, everything looked very concealed. Is this possible?
    Veteran Member Four Rings amz's Avatar
    Apr 29 2013
    Ottawa
    Happy path: the trunk-release cable has somehow come disconnected from the hood-release grip
    Unhappy path: your trunk-release cable has come unhooked from the latch, or the latch is jammed. If that's the case just take it to a dealer because it's going to be a total PITA to fix. Bill the body shop after.
    Back to the happy path: The hood release is hooked via a cable to the latch on the front. I would imagine this cable runs underneath the front wheel liner. If you can get some pliers on the cable and give it a good pull; you should release the hood.
    2012 S4 ~ Phantom Black - Mustang Brown - B&O - Sport Diff - DSG
    AWE Touring Exhaust | Roc Euro Intake | Eurocode Alu-Kruez | Eurocode USS Swaybars & Solid End Links
    Canada: the land of Quattro
    May 16 2010
    houston tx
    plasma cutter
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Ask Skywagon
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Jul 05 2014
    Houston
    Unfortunately, I can hear the latch functioning when i have someone else pull the release.. Something must not be lined up right.
    Apr 29 2013
    Ottawa
    Quote Originally Posted by fitzydude View Post
    That's not a good sign. If someone else pulls the hood release and you try to lift the hood, can you feel if it's caught in one area in particular other than the latch?
    Veteran Member Four Rings d.p's Avatar
    Nov 08 2006
    F80 M3
    Annapolis MD
    Take it back to the shop and have them resolve it.
    I had this happen on my B6 S4 avant and the dealership (same ones who forgot to reattach the latch) spent north of 5 hours trying to get it open to no avail. In the end the buyer used a long socket to remove the latch from the hood through the grille but I dont think that is a possibility with our cars.
    Registered User Four Rings Sales@DriveAuto's Avatar
    Apr 13 2012
    Clifton/Mountainside, NJ
    With the earlier Audi's (B5/B6/B7/C5), if the latch got jammed, you could manually release it using a massive long screwdriver from underneath the car. I think the B8 has too much in the way to allow for that. I would call the body shop, explain the situation, and ask how they want to resolve it.
    Jul 05 2014
    Houston
    Thanks for the help guys, contacted the shop and having it sorted out Monday. Luckily there is an Audi meet that night where the body shop is so my trip won't be a complete waste.
    Sep 28 2010
    NW NC / DE
    4 B8 owners, booze and a pool stick...
    @bknewtype @sgibbs @NPuter Amirite!?
    Mops on the move
    Jul 05 2014
    Houston
    Could I hire the brain-trust? Hahaha great pic!
    Sep 28 2010
    NW NC / DE
    Lol! I was the most twisted, thus head photographer. I was not allowed to poke.
    Veteran Member Four Rings Usa's Avatar
    Dec 23 2013
    B8 S4
    Check the valet button inside the glove box isn't active
    S4 (B8) DSG / Quartz Gray Metallic / VAG-COM / 3M Crystalline 70% sides 30% rear / Roc-Euro Intake / APR Stage II / Non-res Milltek / Alu Kreuz Stabilizer / Eurocode Front & Rear Sways & Endlinks / 19x9.5 AG M590 / PSS / RS4 Grill / P3 Gauge / Bilstein PSS10 / AMS Boost Cooler System / ENLAES Rear Spoiler & Diffuser / OSIR Front Splitter
    Jul 05 2014
    Houston
    Does Valet mod restrict the hood from being opened? I know the trunk cant open. I did go out and check it because I was messing around in the glove box, but it is off and still won't open..
    Aug 12 2014
    Bexley, OH
    Mops on the move
    Wow, you saved that picture for the perfect post. I'm surprised it's not a picture of a sandwich.
    If Mops can't fix it, Skywagon can.
    Oct 20 2008
    Denver
    Quote Originally Posted by Usa View Post
    Aug 03 2014
    Queens
    Quote Originally Posted by AudiTFSI3o3 View Post
    It's for the roc euro
    Previous
    Jul 05 2014
    Houston
    The reason I ask is because I had a flash done on the vehicle since, does the hood have any kind of valet disabling mechanism?
    Jan 07 2011
    2013 C300 4Matic
    Mops on the move
    LOL. #goodtimes
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    If you can hear the latch being pulled out at the latch when someone pulls the cable, try to press and realease on the hood around the latch area and sometime making the hood wiggle will make the latch release and pop up so you can open it and see whats going on. Does their feel like resistance on the cable and down the latch handle go back down when you let go. It might not be hooked up to the latch on the other side of the cable out at the latch.
