Results 1 to 19 of 19
    Established Member Two Rings jimtur's Avatar
    Jul 28 2014
    Audi Q5
    Sherbrooke / Québec / Canada
    DIY tail light dead LED remplacement
    Hello,
    first, I'm a french canadian, sorry about the language error... :)
    I had purchased last summer a 2012 A4 out of warranty. One tail light had dead LED. I decide to fix it by myself.
    tools that you need :
    - flat and phillips screw driver
    - knife
    - spare LED light (I don't have source for the LED, I take one from a salvage car)
    - small soldering gun
    - 5 minutes epoxy glue
    - 1 hour of labor
    - a precise hand...
    1- remove the tail light of the car
    2- remove the back panel and disconnect the wire connector
    3- separate the lens of the back section, use a flat screw driver. Note that tail light have no glue between the lens and the back section, it's a hot plating process (melted plastic). You need to gently turn and the lens will separate the case. The lower section of the lens is more difficult to separate.
    4- remove rear philips screws
    5- take in memory the LED orientation (look in the middle of the LED)
    6- remove the dead LED, use a sharp knife on the side of the LED for best result. Don't use a soldering gun, you may overheat the electric board and destroy the board.
    7- reinstall the new LED, be very carefull, do not overheat the LED and the board, if not you can burn the LED, it's a precision job !!!
    8- verify if LED is working, you can use a little toy power supply, voltage must be between 6Vdc and 12 Vdc. Depends of voltage, LED will be brightness ( 6V for parking light intensity and 12 V for brake/turn signal intensity)
    9- clean the len with fresh water (don't use a towel, this one can create static inside the lens and may create durty). Reinstall the lens on the case with 5 minutes epoxy self mixing glue. Don't use liquid "super glue", when this glue come dry, some white spot appear inside the lens.
    10- reinstall the back plate and put the tail light in your ride!
    Enjoy.
    Veteran Member Three Rings BMWBig6's Avatar
    May 20 2008
    Georgia
    Excellent DIY and pictures, thanks for posting!
    2020 F-Pace SVR / 2016 GLE350 4MATIC
    Favorite Former Rides: 2015 Boxster GTS / 19 E450 Wagon / 2015 X1 M Sport / 11 F-150 Limited / 09 A4 Avant / 08 TT / 03 SVT Lightning / 01 SVT Lightning / 93 740iL / 90 535i / 86 944 Turbo / 83 944
    Oct 30 2011
    Urbana, IL
    Thank you for this excellent DIY. Would you please provide the source of the new LED lamps.
    Thanks
    Veteran Member Three Rings kt883's Avatar
    Nov 10 2010
    Stoney Creek
    I realized after asking that he said he used a spare set of led lights and took the leds out
    I dont think you will find a comparable led that can withstand the extreme heat//cold/duty cycle found in a car and match the colour
    Jun 23 2013
    PacNW
    I don't think there is anything special about the OEM LEDs, many have operating temperatures of -40C to +100C
    Depending on brightness, they are either cheap or very cheap.
    Check this out:
    http://www.digikey.com/short/7wfqrr
    What you're looking for are "SMD LEDs" and it seems like this is a PLCC-4 or 4-PLCC package with a "flat top" lens.
    You can find them on digikey or mouser, etc.
    The key is finding the right color (the red ones vary in wavelength from 615nm to 640nm) and brightness (most are 600-2500 mcd "milli-candellas" some go up to 3500 or 4500).
    ~2000 mcd about $0.30/ea for the 3500+ mcd you're looking at $1-2/ea
    I have no idea what the stock ones are though you'd have to experiment a bit or get a better part no from the stock ones.
    Established Member Two Rings pf_lewis's Avatar
    Apr 10 2011
    Port Orchard, WA
    Very nice, I had a few LEDs go out in both sides of my 2010. Luckily within warranty- the dealer found that there was a recall on the tail lamp seals- They replaced both tail lights and told me the new improved ones had an actual thicker rubber seal. I haven't inspected them to confirm though.
    2010 B8 A4 Prem Plus
    Established Member Two Rings zxg01's Avatar
    Sep 23 2010
    1993 RX7 (1JZ swap in work)
    I'm curious but this should work for the outer light as well. I'd like to change the clear turn signal bulbs from red to amber.
    Mar 03 2016
    beds
    Lightbulb
    Those who are looking for SMD LED here is the link https://uk.rs-online.com/web/p/visible-leds/6655104/
    I have done it after reading this thread. Job well done. Please freeze ur light first as that way cracking it opening will b much better. Just one more tip if u don't have a precision soldering iron please use a small copper wire and attack it to the last bit of iron and make it very pointy.
    Make sure solder it same way you take it off as if you put it wrong way then whole side won't work. Lol I did put on wrong way first, had to redo it 😜
    here how to do it more details
    Jun 23 2013
    PacNW
    Quote Originally Posted by ch_mudassar View Post
    In case that site disappears, here is the info on those:
    Osram Opto LS E6SF-V2BA-1-1, Power TOPLED Series Red LED, 633 nm, PLCC 4, Round Lens SMD Package
    LED Colours Red
    Package Type PLCC 4
    Mounting Type Surface Mount
    Number of LEDs 1
    Forward Voltage 2.15 V
    Luminous Intensity 1.6 cd
    Number of Pins 4
    Viewing Angle 120 °
    Luminous Flux 4.65 lm
    Lens Shape Round
    Dominant Wavelength 633 nm
    Dimensions 3.4 x 3 x 2.1mm
    Series Power TOPLED
    Lens Colour Clear
    LED Material AlGaInP
    Active Member Two Rings Quiet514's Avatar
    Jul 06 2015
    MS3, Tesla P70.
    Montreal Canda
    Digi-Key Part Number 475-1322-1-ND
    Price Break Unit Price Extended Price
    1 0.51000 0.51
    10 0.38800 3.88
    25 0.32480 8.12
    100 0.27980 27.98
    250 0.24824 62.06
    500 0.21212 106.06
    1,000 0.16699 166.99
    OSRAM Opto Semiconductors Inc.
    Manufacturer Part Number
    LS E6SF-V2BA-1-1-Z
    Description LED RED CLEAR 4PLCC SMD
    Lead Free Status / RoHS Status Lead free / RoHS Compliant
    Moisture Sensitivity Level (MSL) 2 (1 year)
    Cheap price! But, wait, one year moisture level? Can someone explain?
    Jun 23 2013
    PacNW
    https://en.wikipedia.org/wiki/Moistu...sitivity_level
    Components must be mounted and reflowed within the allowable period of time (floor life out of the bag).
    From what I can tell, this describes how long the LED can sit in ambient air before it absorbs enough moisture that it will be damaged during the high-temperature soldering process when you're mounting it to the tail-light.
    Does not mean anything for how long it will operate.
    Mar 03 2016
    beds
    been nearly 2 months and all is good so far no problems with light at all
    Jun 30 2013
    PL
    Guys any other hints about dissasembling cover of lamp? i am afraid about cracking it...some people recommend to use oven or fridge
    Apr 11 2016
    Botswana
    Thank you very much for the information. This will save us a lot of money. Mine have 5 blown LEDs on each side. I managed to find the LEDs bulbs on Ebay.com ($6 for a set of 20). I have ordered and will replace them when they arrive. Your post will be my guide.
    Apr 11 2016
    Botswana
    How did you make the tail light easy to open? Did you freeze or heat it as other members say or you just opened them with the screw driver. I have ordered the LEDs and will start the repairs when they arrive.
    Apr 11 2016
    Botswana
    Thanks for the info. How long do you put the light in the freezer?
    Jul 28 2014
    Audi Q5
    Quote Originally Posted by Mmolaik View Post
    30 minutes is well.
    Feb 17 2004
    2010 Meteor Grey A4 Prestige
    Peoples Republic of Kalifornia
    I'm glad someone figured out the parts to fix these lights. My inner left tail light had a couple of the LED's go out a few years ago, then a few more , and the other day the last of them bit the dust. So i'll be replacing all of them. And at only $0.61 each, it sure beats paying $300+ for each replacement tail light section.
    2010 Meteor Gray A4 2.0T
    quattro | 6-spd | prestige | B&O | 19" Sport | nav| HID | black leather
    Coming: APR Chip, Exhaust, and H&R suspension
    Dec 30 2019
    RÍAS BAIXAS
    Hi
    Here in aliexpress (SMD LEDS) ???
    Regards
    https://es.aliexpress.com/item/32969...archweb201603_
