Results 1 to 13 of 13
Thread: Oil Additives.
    Jan 03 2015
    Hollywood, CA
    Oil Additives.
    What's up Audizine? (Besides your ceilings, the sun or the moon) I'm a new owner to a used Audi S4. I was wondering if these liqui moly or lubri moly additives are good for my engine. And do theybdo what they say they are mean to?
    Thanks in advance..
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    BG MOA is the only good oil additive that I have found.
    BG 44k is great to add to the fuel system on a full tank right before an oil change too. Really helps clean out the injectors and fuel system but it is expensive at $25 per can.
    Jul 13 2014
    1997BMWZ3
    Daly City,CA United States
    I have used couple of liqui moly additives such as mos2, ceratec, oil saver, injector cleaner, motor flush and valve cleaner. I spend a lot of money on additives but if I were to reuse that money, I would just get the ceratec instead of mos2 since it last longer. Oil saver didnt really do much for me if your car burns oil. Dont use valve cleaner since it doesnt work in our car. Motor flush didnt really do much to my car. Im guessing its clean already. Dont use seafoam on engine oil. It actually made my start up rattles even worst.. Injector cleaner works great but use it when youre close to your oil change. How many miles do you have in your car?
    Veteran Member Four Rings SpoolBus's Avatar
    Aug 07 2013
    ATL/GA
    Quote Originally Posted by JimmyBones View Post
    X2 BG109 to clean the motor WORKS because I did it and saw the crap that poured out (and yes its properly maintained)
    The BG44 makes the engine run smooth as silk...only con is it's so damn expensive...
    Veteran Member Four Rings Guitarmageddon's Avatar
    Oct 23 2010
    EARTH
    I wouldnt mess with the stuff. Just search for MOS2, ceratec, BG109 on bob is the oil guy and theres a lot of good info.....a lot of super heated debates over their merits as well.
    BITOG
    I think the only logical way to tell if it does anything is to have a virgin oil analysis done of the additive itself, then of your oil, then a used oil analysis of just your oil after a given interval, and of your oil plus additive of that same interval. Then you would compare/contrast. Other than that, Im not sure how youd determine they did anything good other than looking at what came out of the drain (additives change oils appearance anyways) and by butt dyno.
    Not to knock BG though, I use a fuel system cleaner ever 10k or so
    Sep 09 2011
    2011 Chevy Duramax, 1999 Mazda Miata
    Chardon, OH
    I have a shit ton of 44k here I can sell cheaper if people want it
    RIP 2004 S4 built by Gellner Engineering Racing Engines
    Veteran Member Four Rings FulhamFTW's Avatar
    Jul 10 2010
    STL, MO
    BG 44k is $22 shipped with Amazon Prime. I might give it a go.
    Veteran Member Four Rings A4Maine-iac's Avatar
    May 03 2010
    2012 TT Sold
    Maine
    Quote Originally Posted by aroderick56 View Post
    What are you talking $?
    2002 A4 1.8T - sold
    2007 DTM S4 -Sold Sound clip - https://www.youtube.com/watch?v=bGz60n-31jc
    2012 TT - TTS Rear & Exhaust- UNI Stage 1+ " More to come"
    2021 SQ5 - " Just getting started
    Sep 09 2011
    Chardon, OH
    $20 a can shipped, or if you buy 2 or more $18 each free shipping?
    I just checked my one cabinet and I have like 50 cans right now plus I think I have more in another storage room lol
    May 03 2010
    2012 TT Sold
    Maine
    dam! that is a shit ton. pm'd
    2002 A4 1.8T - sold
    Mar 04 2013
    05 Audi S4 Avant
    Central MA
    Here is a good thread on this subject. As with anything having to do with oil..... see dparms posts.
    http://www.audizine.com/forum/showth...=oil+additives
    I've tried fuel system cleaner at times in the past. I used it once previously in the S4 and was thinking of using it regularly. Techron, Regain and Redline being the best according to the experts on BITOG and dparm here. When I had my IM out I saw that my valves couldn't really have been cleaner. They had absolutely 0 carbon build up on them. If I do use it again it would only be once every 20k miles or so and not to clean the valves as there is nothing to clean.
    As for oil...... instead of spending the money on additives and guessing if it's working, just send your oil to Blackstone for a UOA just before an oil change. I've done it a few times and after seeing the results see absolutely no reason to use additive in a good VAG approved synthetic. My oil after 5k miles was still good enough to go 7,500 miles per Blackstone. I did end up doing the next oil change at 7,500 miles, mostly because of lack of time to do the change, but also out of curiosity. I then had it analyzed and results were that it was still in great shape and I could go to 9k if I wanted (I won't stretch it that far though).
    Jan 03 2015
    Hollywood, CA
    I Have 71,435
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    As I've always said, what is it about your current oil and state of your engine that leads you to believe you need to use an additive?
    And if these additives are so great, why aren't they in every off-the-shelf oil? How do you know they aren't already?
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
