Originally Posted by
Guitarmageddon
After studying the order of the guides and the route the chain takes, I would say that the particular failure prone center-ish tensioner cracks because of the curve downwards the chain follows, then has to almost immediately put pressure on itself to move around the crank. Seems like it was doomed from the start. Why curve the tensioner at all, audi? Why use plastic at all, audi?
Study all you want but:
Metal on metal is a TERRIBLE idea, the updated refresh is reinforced by metal but the guide runner is plastic.
Chains are meant to curve around a track; think of it like a stronger belt driven system.
You gripe and bitch about how bad the system is until you get a chance to look at it in person THEN you marvel at the engineering behind it. It's not poorly designed or over-engineered, for the date and time, it was an efficiently designed engine....so stop bitching about a system that is currently in use in the RS4 and majority of the B8 systems.
