Results 1 to 15 of 15
    Senior Member Two Rings street sleeper's Avatar
    Jan 04 2015
    Pittsburgh, PA
    Cold Air Intake - Silicon vs Aluminum?
    *typo - meant silicone not silicon in post title
    I’m looking to add a cold air intake to my (V8) S5. My previous car had a K&N filter with an aluminum pipe that produced a nice, throaty note.
    I noticed cold air intakes now come in either silicone or aluminum. Are there any performance or sound difference between the two? Wouldn't a silicone pipe sound significantly quieter than an aluminum one, or no?
    I’m leaning towards an AWE cold air intake, but was wondering what's the point of this carbon cover? Just for show? And wouldn't that muffle sound and restrict air - the opposite of what an aftermarket cold air intake is supposed to do?
    2008 Audi S5 (6MT)
    Meteor Gray / Magma Red Leather / Carbon Inlays
    Euro Spec Headlights / 35% Tint / Satin Black Grille, Fogs, & Rear Valence
    AWE Track Exhaust / AWE Carbon Intake / Short Shifter / H&R Sway Bars
    H&R OE Springs / Brembo Brakes / BBS CH-R 20x10.5 / Michelin Pilot Super Sport XL 275/30ZR-20
    Jan 04 2015
    Pittsburgh, PA
    Anyone?
    2008 Audi S5 (6MT)
    Jul 15 2014
    Carlsbad, CA
    Not sure about the difference between silicone or aluminum for intakes, but I have that AWE intake. It sounds much better than the stock, a little subtle, but better. The carbon fiber box is purely cosmetic, there are other versions with plastic boxes. I don't believe it restricts any more than the stock intake would.
    Sep 30 2009
    b
    I don't think it really matters. I could see the sound being very insignificantly different between the two.
    One thing that has made me appreciate silicon tubing is that aluminum pipes, if fitted incorrectly, can rub through some crucial lines in that area (not sure if true to the v8, however).
    Jan 04 2015
    Pittsburgh, PA
    It might sound silly, but in addition to performance (assuming the two will perform the same), I'm looking for a deeper sound over stock. And I would hate to pay several hundred dollars for an silicone intake that doesn't deliver a deeper sound like an aluminum intake does.
    So far all the cold air intakes for a (V8) S5 that I've found seem to be made of silicone.
    2008 Audi S5 (6MT)
    Veteran Member Three Rings Brozee's Avatar
    Oct 12 2009
    Oxford, MI
    Roccccccccccccccccccc euroooooooooooooooooooooooooooooooo
    2013 S5
    APR Stg. 2+ Ultracharger, DSG, CPS | Full AWE Touring Exhaust | Roc-Euro Intake | H&R Coilovers | MRR GF6 | 034 Trans + Diff + Subframe Inserts | Apikol Rear Diff Mount | CR-15 | Full Eurocode USS Suspension | DEVAL CF Rear Diffuser | Adams Rotors / Akebono | Stoptech SS Lines | RS5 Grill | Tint | LED Interior, Reverse + Turn | HID Fogs | Escort Max 2
    Jan 04 2015
    Pittsburgh, PA
    Quote Originally Posted by Brozee View Post
    Roc-Euro doesn't make a cold air intake for the (V8) S5. They only have it for the V6.
    2008 Audi S5 (6MT)
    Jan 05 2015
    Texas
    what options do we have as far as intakes are concerned when it comes to the v8?
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    The inlet length on the V8 is so short that I doubt you'd notice any difference between the two materials. One thing I would bare in mind, aluminium (unless it's ceramic coated) will become heat soaked and retain heat more so than silicone so going against the whole 'cold air' marketing idea.
    Another is flexibility, unless the air box is mounted to the engine then an alloy inlet pipe won't flex as a silicone one will as the engine moves and vibrates, ally will stress crack pretty quickly in those situations.
    Oct 12 2009
    Oxford, MI
    I'm embarrassed I didn't see it was the V8 :( smh.
    2013 S5
    Jan 04 2015
    Pittsburgh, PA
    Quote Originally Posted by LiLS View Post
    Unfortunately, there aren’t many cold air intakes made for the V8 S5. I’ve only found two!
    And I’ve heard some complaints that the APR Carbonio one doesn’t fit properly.
    So I’d go with AWE Tuning. They have a “fitment guarantee” on their intake. I have their touring exhaust and it’s awesome. High quality product. No complaints here.
    2008 Audi S5 (6MT)
    Jan 04 2015
    Pittsburgh, PA
    Little Update:
    I exchanged a few emails with John (Performance Specialist) from AWE Tuning. Over the weekend, before this thread got any replies, I asked him the same questions.
    He confirmed what many people in this thread have been saying.
    — silicone hose creates less stress on other parts and helps cut heat
    — silicone hose will be slightly louder than stock, but not as deep and throaty as an aluminum pipe
    — carbon fiber cover is just for looks
    — according to their dyno tests, you can expect 11hp gain
    — no solid proof of increased gas mileage, but may improve by 2-3 mpg
    Dyno charts and more info here. http://www.awe-tuning.com/s5-4-2l-s-flo-intake-system
    I think I'm going with an AWE cold air intake.
    2008 Audi S5 (6MT)
    Veteran Member Four Rings mozman68's Avatar
    Nov 09 2014
    2019 VW Atlas SEL R-Line
    South Carolina
    Quote Originally Posted by street sleeper View Post
    Little Update:
    Can't go wrong with anything from AWE...I'm going this route as well. Seems like a great option for a little increase in power without too much cost and something I can easily install myself.
    I have plenty of cold air going through my car right now....zero degrees out...going to wait until the Spring until I pull the trigger on this mod.
    2009 S5 in Bottle Green / 20x10.5 BBS CH-R in satin black (check with Mops) / AWE Tuning Track Exhaust (Mops again!) / H&R Street Coilovers (Mops...again) / Ecodes (ECS Tuning) / Rear LED retrofit (Europrice) / RS5 blackout grill (MrCarCar)
    MozMan's Build Thread
    Sep 30 2009
    b
    probably the route I'd go, if I didn't want to do something custom - and didn't have EC option available.
    Jan 04 2015
    Pittsburgh, PA
    Quote Originally Posted by mozman68 View Post
    Oh yeah. 19 degrees here. It's Mother Nature's cold air intake. Installs itself and the best part is it won't cost you a penny!
    2008 Audi S5 (6MT)
