Results 1 to 32 of 32
    May 13 2014
    New Orleans, LA
    Instrument Cluster Display Dead
    Hello Everyone,
    I was driving on the express way, pretty chilly outside today around 27f/-1c, I didn't have my AC on and decided to roll down my window to get some fresh air in the car, then next thing I know the display in the center of the instrument cluster had turned off. Very odd. Any ideas? I will most likely be seeing Audi very soon, the jingle the car makes when an error has occurred or someones seat belt is not on is very distorted sound now (Louder and rougher)
    (03-29-2015) 2015 8V S3 in Mythos Black, Prestige + 19" Package
    2013 C7 S6: Stock, not for long
    2011 B8 S4 APR Stage 2: Totaled
    Oct 12 2014
    Richmond, Virginia
    Long shot...there's a button on the bottom of your wiper stalk...push that button and see if any of the computer functions show up in the display. If not, try pushing the "mode" button on the left side of the steering wheel...see if anything lights up in the display.
    If not, I can't advise. I'm hoping somehow you've *darkened the display through the mode function.
    2008 Audi TT 3.2, DSG
    Veteran Member Three Rings Amorphic's Avatar
    Jun 05 2009
    2013 A4 2.0T Premium 6MT
    BC, Canada
    I doubt it was the weather that affected it. Many of us in Canada have taken these cars through -30 C without issue (other than the screen being slow). Sounds like some kind of electrical error.
    2015 Subaru WRX STi | Limited | Dark Grey Metallic | Sport Tech | Xpel Ultimate
    Sold -2013 Audi A4 2.0T | Premium | 6 MT | Brilliant Black | Xpel Ultimate | Tint: 35% Front 20% Rear
    Feb 25 2013
    MI
    Gotta scan with vcds to get an idea. The problem remained after restarting the car?
    May 13 2014
    New Orleans, LA
    Quote Originally Posted by RING IT OUT View Post
    That was the first thing I tried and it didnt work out. I'm going to to continue playing with it tomorrow
    Quote Originally Posted by drob23 View Post
    Problem remained, I guess I'll have to go get it scanned
    Deactivated Three Rings
    Oct 03 2014
    Boston
    Mine went entirely white one time, restart didn't fix it but sitting overnight it fixed itself.
    Aug 02 2014
    Langley, BC Canada
    Quote Originally Posted by akenharris View Post
    Hello Everyone,
    Hey I had this exact problem for a few weeks now, it went blank then i would shut the car off wake up the next morning then it would work again, then while driving the screen would just go blank then i would hear a "DING" about 3 times. Then it was off for 1 week straight then 3 days ago it came back on with a low oil message i fill up the oil and the screen has worked every since....very weird anyone else have this problem? I also drive a 2011 s4 b8
    Veteran Member Three Rings Brozee's Avatar
    Oct 12 2009
    Oxford, MI
    Pull the battery on the car for 5 minutes and do a hard reset. That should fix the issue. If not looks like your instrument cluster has a wiring issue or it just died/fried.
    2013 S5
    APR Stg. 2+ Ultracharger, DSG, CPS | Full AWE Touring Exhaust | Roc-Euro Intake | H&R Coilovers | MRR GF6 | 034 Trans + Diff + Subframe Inserts | Apikol Rear Diff Mount | CR-15 | Full Eurocode USS Suspension | DEVAL CF Rear Diffuser | Adams Rotors / Akebono | Stoptech SS Lines | RS5 Grill | Tint | LED Interior, Reverse + Turn | HID Fogs | Escort Max 2
    Veteran Member Four Rings d.p's Avatar
    Nov 08 2006
    F80 M3
    Annapolis MD
    Its ghost.
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    I had this problem last year with the extreme cold. Had to take a vid to show the dealer, they eventually replaced it.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Veteran Member Three Rings Mr.Tan's Avatar
    Sep 02 2014
    '01 GTI
    York, PA
    Quote Originally Posted by roadkillrob View Post
    this happened to me the other day. Got in the car to drive and it went white.... stopped car, got out and locked it and then unlocked and started the car up and it was fine.
    www.epautohaus.com for all your aftermarket performance parts, wheels & tires
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    There seem to be quite a few electronic glitches with these cars. i'm starting to believe that the electrical engineers at Audi used to work for Lucas Electronics prior to working at Audi.
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    Quote Originally Posted by Dr GP View Post
    or BMW!
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Senior Member Three Rings Riu's Avatar
    Apr 03 2011
    Boca Raton Florida
    I valeted my car at my parents country club and when I got the car back the screen was white... I was like wtf....
    Turned car off and back on and it was still white.
    Turned it off waited 10 min and turned it back on and it works. This was prob 3-4 months ago.
    Jul 14 2013
    British Columbia, Canada
    Quote Originally Posted by Riu View Post
    Exact same issue on mine and resolved the same way... Weird.
    2011 Phantom Black Effect S4 6MT Prestige, Sport Differential, Flat-Bottom Steering wheel with red stitching, RS4 Aluminum pedals, 034 Transmission mount, Roc-Euro Intake, Roc-Euro Short Shifter, 90mm AWE Touring Exhaust with stock downpipes, Unitronic Stage 2+, JHM 179mm Overdrive Crank Pulley, MercRacing heat exchanger, Stasis rear sway bar, CR-15, Gloss Black RS4 Grille, Sachs Xtend Clutch, 034 Density-Line Motor Mounts, Bilstein B12 Suspension Cup-Kit
    May 13 2014
    New Orleans, LA
    Alright. Disconnected battery, gave it a couple of second, reconnected it. Problem still exist. Fuse maybe? Going to my local Audi Dealership tomorrow. Will keep updated.
    Veteran Member Four Rings littleredwagen's Avatar
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    you need to leave it disconnected for more than a few seconds, you need at least 5-15 minutes since there is still residual power in the car systems.
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    2011 S4 Prestige 6mt Black
    2001.5 S4 EPL Stage 3 Yellow
    2005 S4 Avant 6spd Red
    Aug 02 2014
    Langley, BC Canada
    Let me know what you find out, mine went blank again this morning . Thanks.
    Jul 12 2012
    It has to be replaced. Don't wait because it doesn't happen while it's warm. You may need to take a video because it doesn't throw any codes.
    Aug 02 2014
    Langley, BC Canada
    Quote Originally Posted by blackfunk View Post
    Is this covered under any tsb? I'm just out of warranty.
    Oct 03 2014
    Boston
    Quote Originally Posted by B8Addict View Post
    I complained to my dealer about the white screen thing when it was in for an oil change last week, they replaced the cluster and said there was a service bulletin for the issue.
    Sep 02 2014
    '01 GTI
    York, PA
    all years? if this is true then i'll be calling to make an appointment to have mine fixed
    Jul 12 2012
    Quote Originally Posted by 604_s4 View Post
    No TSB, I'm still under warranty though.
    Oct 03 2014
    Boston
    Quote Originally Posted by Mr.Tan View Post
    I will late if the service bulletin number is listed on my paperwork tomorrow
    Aug 02 2014
    Langley, BC Canada
    Any updates OP?
    Sep 02 2014
    '01 GTI
    York, PA
    kinda dead, but i wanted to give my own update to anyone who may have issues... I took my car in today and dropped it off for some service work. Metioned the screen in cluster went white on me a couple weeks ago for a day. They are replacing the entire cluster for me because they've heard its happened before and aren't taking any risks.
    so if any of you had this problem and are still under warranty, take it in and have it looked at.
    May 13 2014
    New Orleans, LA
    Alright, so on Valentines day Cupid worked his magic and my display came back on. No less than 5 minutes later it went out again. I had an appointment to drop my car off at Audi on the 18th of February, and that morning my Display came back on. So it works again. My display has gone from completely dead (the day I posted this thread itself) to back and fine (as of 18-2-2015). I will keep updates as to whether it happens again, my local dealership has the part in case it does go out again.
    Oct 03 2014
    Boston
    For anyone that has these weird issues, get a video of it when happening - the dealer uses it as evidence of the issue to justify the replacement, so makes it a bit easier to get replaced.
    Junior Member One Ring 06SilverA3's Avatar
    Feb 23 2020
    '02 1.8t GTI, '01 F150 SuperCrew 4x4
    Goodview, Virginia
    Similarly, my '09 A4 Quattro Cabriolet S-line (8H B7) instrument panel displays, all 3, the central large DIS and both small red mileage/odometer/date etc. at the bottom of the speedo and tacho are black. Because all 3 are out it feels like they lost a common ground or power line, but fuses all check out and there's nothing amiss with the wiring or connectors to the rear of the cluster. The gauges and idiot lights work fine, and the car runs fine, and no VCDS codes relating to this at all. What are my options?
    Can I repair this?
    Do I send this out for repair?
    Do I buy a used replacement and have it cloned?
    Do I buy a used replacement and clone it myself?
    Do I take out a third mortgage and drop it off at the dealership?
    Thoughts?
    2009 A4 Quattro Cabriolet S-line - daily ride
    2002 GTI 1.8t manual project
    2003 New Beetle 1.8t [son's]
    2003 A4 Quattro 1.8t [other son's]
    2000 New Beetle 2.0L [daughter's]
    2006 A3 2.0t FSI [sold]
    2003 GTI 1.8t fun alt daily [sold]
    2001 GTI VR6 - miss her badly [sold]
    Veteran Member Four Rings f1torrents's Avatar
    Apr 27 2012
    B8.5 6MT S5 Coupe / B9.5 S5 Coupe
    Guelph
    get a used cluster and swap the display. Its just plugged in, No soldering or wiring.
    You just have to remove the cluster and open it.
    3/10 difficulty.
    Assuming the display is at fault of course.
    Feb 23 2020
    Goodview, Virginia
    Quote Originally Posted by f1torrents View Post
    3/10 difficulty.
    Sounds simple . Can I do that for all 3 displays, are they all attached separately?
    Apr 27 2012
    Guelph
    Oh sorry. I didn't catch that the smaller ones are out as well.
    I jumped the gun on that.
    disregard my previous post.
