I have a 98 a4 quattro with the 2.8 engine in it. Replace both valve covers. Only time the car leaks oil is when it negative degrees here in Wisconsin. I have put dabs silicone in the common area of leakage. Developmentally on the back side of the passenger head near the cam seal holder. Cam seals were replaced. Open to suggestion. Thought this may be a crankcase pressure issue.
