All of the tail lamps use fixed pulse width modulation of the power supply voltage to the lamps, to control the brightness of the lamps according to the functional specifications, and to allow adjustment of the lamp illumination power accordingly. Because of this, the measured voltage at the lamps will be lower than +Batt voltage, as determined by the lamp power setting value in % dimming from 100%, in the adaptation channels of the CECM.
CECM Measuring block 006 shows the active power of the rear fogs as currently set in the adaptation channels:
006,3,Fog Light,Rear Left,Display Range: 0.0...100.0 %
006,4,Fog Light,Rear Right,Display Range: 0.0...100.0 %
The adaptation channel and values for the rear fog lamps:
A004,0,Rear Fog Light Dimming
A004,5,Rear Fog Light Dimming
A004,6,Standard: 28 %
A004,7,Range: 13...40 %
The CECM will disable certain lamps if there is a short in the wiring harness, resulting in an excessive current load on the CECM. A burned out lamp bulb, results in an open circuit, seen by the CECM as a infinitely high circuit resistance in Ohms. This is fundamentally different from a short circuit to chassis ground. An open circuit results in no current flow in the circuit, whereas a short circuit to chassis ground, (typically, but not always,) results in an excessively high current in the lamp power circuit. Since excessive current will overheat the wiring and damage the CECM, the CECM will disable a lamp circuit having excessive current load, higher than a specified limit, on the CECM. An open circuit results in a burned out lamp warning on the dash insert.
Testing the lamps power supply and ground circuit wiring, requires different methods. The power supply to the lamp socket can be evaluated for continuity and relative resistance between the origin and end point of the wire, and also the resistance in Ohms, measured between the power supply circuit wire and chassis ground. The resistance measured through the wire from the CECM to the lamp socket, must be no more than 1 to 2 Ohms, less is preferred, anything higher implies poor connections in the wiring harness connectors, or lamp socket or a broken wire. . The measured resistance to chassis ground must be open circuit, infinitely high Ohms, more than the meter is able to measure, displayed as "OL" by the meter or similar. However, a resistance value measured and displayed by a DVM, could be less than infinite, of a value in millions of Ohms, or megOhms, that is effectively an open circuit when the applied voltage is low voltage DC as is the case in our cars. Any lower values measured imply a short to chassis ground and must be found and fixed.
For practical guidance, open circuits are a lot more common than shorts to chassis ground, but either type of circuit fault or a duel mode fault can occur as well.
The CECM Diagnostics capabilities can distinguish what type of circuit fault exists. Use VCDS to scan the CECM for fault codes, the fault memory should have fog lamp related DTCs stored.
After the type of circuit fault is revealed by the diagnostics, the troubleshooting steps to find and repair the problem will be focused in the required direction helping avoid wasted time and effort performing tests irrelevant to the specific fault existing.
Ref: VCDS label file: 8E0-907-279-8EC.lbl
