Results 1 to 8 of 8
    Aug 11 2014
    houston
    06 A3 How many seals/gaskets on oil filter?
    My mechanic was confused. The Mobil 1 Extended Oil filter came with 2 seals/gaskets? One is flat like a rubber band and the other is rounder. His service manual TIS diagram only showed 1 seal goes on the oil filter housing cap and he couldnt make it work with the 2 seals that came with the oil filter. He ended up using the just the flat one on the oil cap. Is this correct?
    06 A3 2.0T
    Jan 07 2012
    Jacksonville FL
    Yes, just one seal, the flat one that seats into the groove at the top of the threads in the filter canister.
    Aug 11 2014
    houston
    Then why are there 2 seals on the parts diagram?!?!
    Registered User Four Rings Phil@USP's Avatar
    Sep 18 2012
    Coral Springs, FL
    The MANN filters we sell only come with one oring.
    I am not sure why that diagram is showing two.
    Here is a link if you want to see it: MANN Oil Filter - 2.0T FSI
    Here is an image to see what comes with it. I am not sure why the Mobil 1 filter would come with an additional one.
    Let me know if you have any questions,
    Phil
    Aug 11 2014
    houston
    That is the diagram straight from the Audi dealership website. Ive called two dealerships and they both have told me that it uses two O-rings.
    The oil filter housing for the cartridge was installed with one oring (the one in your picture) however my car is leaking oil from that spot.
    Is Audi diagram incorrect?
    Sep 18 2012
    Coral Springs, FL
    I physically looked at a housing and filter and just dont know where that other oring would go.
    I know in some of the V8s there is a oring that sits on the top housing but not on the 2.0Ts
    Jan 07 2012
    Jacksonville FL
    Did your mechanic torque the filter canister to spec or just do it by feel? I've done close to 20 oil changes on this engine in my own car at this point, always used the flat O-ring like in Phil's pic. The only time it ever leaked is the one time I had it done at the dealer. Re-torqued it myself and the leak stopped. My thought is the plastic filter canister can easily warp if over tightened.
    Jan 07 2012
    Jacksonville FL
    P.S. I normally use the Mann/OEM filter which only comes with one O-ring, but it is possible that Mobil may package theirs with two so it can be used on multiple applications.
