Results 1 to 40 of 57
    Jan 03 2013
    Baltimore
    Oil Extractor vs. Drain Plug - What's your method?
    I saw a post on the s4 forum and thought this might be good to have over here. What is your preference when changing the oil - drain through the oil pan bolt or use an extractor? I have never used an extractor and last time i did my oil change on my a4 i used the drain bolt. The extractor seems like a good bet since you don't have to jack the car up and remove all the under panels. I searched around and I think i am going to pick up this:
    http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
    Has anyone used this model and can comment on its effectiveness? Any other extractors that you prefer? I will be completing my own oil changes from here out since my audicare is over and I am not shelling out the 150 bones for the dealer to do it any longer.
    Senior Member Three Rings Slim0531's Avatar
    Aug 05 2014
    2010 Santorini Black Land Rover LR4
    I change my oil twice a year. Since I still have Audi care, I use oil extractor in between my scheduled
    Maintenance.
    Senior Member Three Rings DJ_AudiA4's Avatar
    Oct 01 2012
    2005 Kawasaki ZX6R
    Temple City, CA
    So I have a funny personal story with this one, changed my oil the first time through the drain plug. Set my torque wrench to the wrong calibration. (Ft lbs instead of in lbs) over torqued and stripped the bolt. So I Used Jb weld to fix the plug and bought an oil extractor. I love the freaking oil extractor. It works great! Gets all the oil out and even let's me drain it from where the oil filter is. Makes the job super fast and clean. Don't even have to put my car on a lift or jacks.
    Should probably replace the oil pan anyways hahahah
    09 A4 6MT Quattro Frankenturbo, Eurodyne Tune,K&N intake , SPM TP, AWE catback, CTS FMIC, ST Coilovers, Roc-Euro STS, 034 Transmount, Apikol bushing, GFB DV+, H&R sway bars, AWE boost gauge, VMR 701's 19x9.5, RS4 grille and fog light housings.
    289HP @ 6100| | 297ft lb @3900
    Jun 26 2009
    Bremerton WA
    I have an earlier model of this pump. The mityvac pumps that have the vacuum pump inside the oil reservoir had issues. If you left the oil in the tank too long it would migrate into the pump and spray oil out of the handle. The one you linked to should solve that problem. I also found the small tubing in the kit a bit too small and you must have the oil at full temp to work effectively. The medium size tubing doesn't fit the dipstick hole size. I bought a section of tubing at the hardware store that fits the dipstick hole better and now I get much better flow. Changing the oil doesn't take that many pumps as you would think either around 20 to 30. I usually give it about 10 at a time and let it do its thing.
    VMR 710's, APR software, Eurocode HFC
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    I use the Motive extractor and love it, no getting out the jack and crawling under the car, start to finish is about 10-15minutes.
    Established Member Two Rings Viru5's Avatar
    Oct 27 2014
    Rockord Illinois
    Im going to have to pick one of these up will come in handy for these winter months when its to damn cold to get under the car.
    | 2009 A4 Premium+ Quattro 2.0T | 20% Window Tint | AWE Vent Gauge | RS4 Grille |
    Veteran Member Four Rings oascom's Avatar
    Jan 08 2013
    New Jersey
    I'm using oil extractor. I got the one from Harbor freights. I know many shops using this extractor. Also Audi dealers using extractors too. Very easy oil change and with powerful air compressor it is so fast. It suck the oil dry lol
    APR, Eurocode, AWE, P3, aFe , CTS, Spulen, H&R, 034Motorsport, STaSIS
    Jan 03 2013
    Baltimore
    I ordered the one i had in the link from amazon. I will do a review once its in and I change my oil in the next few weeks.
    Established Member Two Rings oldred's Avatar
    Jul 06 2011
    Honda CRV (The Bus)
    Northern Illinois
    I use mityvac 7400.... Love it
    2011 A4 Quartz Gray / Premium Plus / Stasis touring springs/bar / Alu Kreuz / VMR 701 / LLumar Tint 35% / Clear Bra / Leather wallet
    Dec 27 2014
    2001 Mazda Miata
    SW Florida
    I have the model 7201 that is in the link. No fuss, no mess oil changes. The ability to pump the waste oil out of the extractor into containers is a big benefit. The medium-sized tubing was a perfect fit in the dipstick tube of my 2.0t.
    Dec 01 2011
    i have the Pela 6000, had it for 2 years now and used it a total of maybe 6-7 times. still works great and just used it recently too. i prefer over the top since i can just do it myself, not have to jack anything up or take it to a shop, and no risk of stripping the oil plug or anything. and it seems to get out all the oil and just a quick way for me to do it myself, every 5-6k miles i try to do. and once in a while if im getting work done on it by a friend, who works on it at the dealer, he uses the dealer's extraction pump and changes the oil through the top too.
    IG @theshawon
    Veteran Member Four Rings Chanman94's Avatar
    Jun 09 2014
    Calgary, AB, Canada
    Never tried using the drain plug method. But I use the same oil extractor you posted, does the job great and keeps everything clean. Just pump it about 10 times, come back like 10 mins later to check on it and continue until it's drained completely. There's really no reason to do the drain plug method when the oil filter sits next to the engine on this car.
    Just keep in mind when you're putting the tube through the dipstick hole not to ram it in. You'll hit a bit of a snag, just give it a gentle push and it will reach the oil pan. But push it too much and the tube bends back up and you won't get all the oil.
    - Richard
    2017 Audi A4 Allroad - Mythos Black - 034 Dynamic+ Springs - Volk Racing TE37 Ultras
    2021 Lexus NX300 - Ultra White - BBS Evo X Wheels
    2017 Honda Civic Touring - Lunar Silver - Sold
    2018 Volkswagen Golf R - Oryx White Pearl - Sold
    RIP - 2010 Audi A4 - Monza Silver
    - Apparently not resting in peace anymore.
    Senior Member Two Rings eirebob's Avatar
    Apr 13 2010
    santa rosa ca
    I went a little lower end with the Hydro Turf extractor, now about 50 bucks on Amazon. I've used it 7 or 8 times on the A4 and the daughter's Passat without complaint.
    A little reminder if you're just beginning is to remove the oil fill cap prior to extraction. This facilitates an easy and complete extraction.
    Easiest oil change ever (well, for me, anyway).
    2009 A4 Quattro, Manual, Prem Plus, Sport Package
    Mods: APR Stage II, Stratmosphere short shifter, Alu Kreuz, Tips, Tint, 034 Turbo hose, Cocomats. EC Intercooler pipe, hose kit. RS 5 pedals. Apikol rear diff kit. Vag.com mods. Stoptech slotted rotors, Akebono pads. Interior LEDs, BFI heavyweight knob, CF trim. BC BR coils. P3 Guage. ECS SS brake lines, 10/15 spacers. CR 15 brace. USP HFC.
    Apr 22 2014
    2018 Q5, 2018 X1
    Sacramento
    Oil extractor for me as well~
    2018 Q5 Tech Premium Plus
    2011 A4 JHM K04-R : JH MOTORSPORTS TUNED : CTS : 034 : ECS TUNING : SNOW PERFORMANCE
    Jan 02 2015
    Connecticut
    Use it when the engine is hot. The oil comes out faster and easier that way
    Audi Certified Master Technician, PM Me For Advice.
    Veteran Member Four Rings AWDLover's Avatar
    Feb 07 2012
    Oil extractor method here. I use the hydro turf also....works perfectly
    http://www.amazon.com/Hydro-Turf-Oil...=oil+extractor
    2010 A4 Quartz Grey (click) | APR | Eurocode | GFB | 034 Motorsports | Eibach | H&R | VMR | P3Cars | aFe
    Sep 14 2006
    I bought a Motive extractor from ECStuning, but I prefer using my Fumoto valve and inspecting everything under the engine every oil change. If someone want's to buy my Motive extractor, it's for sale :)
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Oct 30 2011
    Urbana, IL
    I also use an oil extractor. It is important to have the car up to operating temperature before extracting the oil. I change my oil and filter on my 2009 A4 every 7500 miles . I usually do some errands, shut the engine off and open the hood. By the time I get the extractor ready, oil and drop cloths arranged, in about 10 min, I begin the extraction. That way the oil has cooled down just a bit. I run the extractor. Then I pull the oil filter, and pump the oil extractor again to get the remaining oil. This is the way the oil is removed by the Audi dealers. I save the oil in a plastic jug and dispose of it at an Advanced Auto Parts store. I have used the same all metal extractor that I bought from Northern Tools in 2009 and it works great. Just be sure not to kink the hose as you gently push it through the dip stick tube. I add the new oil (Mobil 1 synthetic, 0W 40), just 3 quarts and check it with my dipstick. I then add the remaining oil until I reach the correct mark on my dipstick. Then I check the oil the next day to make sure it is at the correct level and adjust. I am good to go for the next 7500 miles. In June 2012 had the Stage-1 oil fix and that corrected my oil consumption problem and I do not get a warning light throughout this mileage. So the extractor method is great and it ensures that I do not postpone my oil changes.
    Jan 03 2013
    Baltimore
    Sounds like everyone uses the extractor method. Mine arrives tomorrow and then my oil should be here by the end of the week. What are your preferred oil change intervals? I find that the 10k that Audi suggests is too much and have been changing every 5k. Thoughts?
    Feb 07 2012
    Quote Originally Posted by elscotto80 View Post
    I go every 5k as well. That's about when I lose one quart...
    Veteran Member Four Rings kwbdc's Avatar
    Mar 29 2012
    2006 Mazdaspeed6 RIP
    Seattle/WA/United States
    Every 5k is when I do it. Since I have Audi Care they do a few I do a few.
    2012 Audi A4 Premium +MT, Quattro, Xpel bra, SLine BBS CI-R 20x8.5 ET 32
    Mods: APR HFC/DP, APR K04, Bilstein PSS10 Coilovers, Okada Coilpacks, AWE Boost Gauge, Eurocode SSK, OSIR CF Spoiler, APR Carbonio Intake, AWE Exhaust, OSIR CF valence, ÜSS Adjustable Stabilizer set, Alu Kreuz, RS4 grille, Fluidampr,Apikol differential, folding mirrors,Brembo GT BBK, Deval CF splitter,ECS skid plate, RS4 rear brakes, Snow performance Stage3
    Jan 06 2013
    MidWest
    How do you fellows reset service reminder after oil change? I do not have Viacom (I hope I spelled it correctly) and do not plan to get into tuning. I am just regular driver.
    Thanks,
    Feb 07 2012
    I reset it via vagcom It is a great tool even if you are only using it for maintenance and diagnostics. Plus they hold their value really well so you can sell it for almost what you buy it for.
    Established Member Two Rings AOW162435's Avatar
    Jul 15 2013
    Ellicott City, MD
    Old skool here, every 3k miles: ramps, ECS magnetic drain plug, Audi filter & 4.9 qts of 0W40 Mobil1.
    Andreas
    2014 Audi A4, Monsoon Gray / Black
    2002 Toyota 4Runner, Dorado Gold
    2001 Toyota 4Runner, Dorado Gold, 575,XXX 1-owner miles :)
    1998 Toyota 4Runner, Oxidized, 5-speed
    1995 Porsche 993, Polar Silver
    Veteran Member Three Rings schaefer921's Avatar
    Nov 25 2009
    2008 RS4 Daytona Grey Ti
    Westchester NY
    Quote Originally Posted by AOW162435 View Post
    Same exact thing for me
    Senior Member Three Rings vdubtx's Avatar
    Nov 24 2014
    Rockwall, TX
    Wanting so badly to get back into my own house. Sold it back in September in 5 days(was not expecting to sell so fast) while we are building a new one which is taking 2 months longer than initially told.
    Will start going the extractor route once back in my own garage. Will have 3 vehicles to do changes for, so should save some much needed money for home projects.
    2018 S4 Prestige, Daytona Gray Pearl, Black Optic, S Sport, Napa Leather
    2012 A4 Premium Plus, Monsoon Gray, Quattro, Navi, Push Start. VCDS mods needle sweep, windows up/down with fob, no wink turns, fogs as cornering lights.
    May 06 2013
    New Jersey
    Oil extractor here as well. Mityvac 7201 I believe. No complaints.
    2010 A4 P+ Sport Pkg(His)
    2009 TL SH-AWD Tech (Hers)
    Veteran Member Three Rings Nastybutler's Avatar
    Apr 07 2014
    2010 C6 A6 (Wife's); 2012 Triumph Street Triple R (Phantom Black)
    United States
    Andreas
    Holy, moley some of you guys sure like to waste money. Modern synthetic oil can easily last 10K miles with no issues. I can understand changing the filter every 5K miles or so, but the oil itself doesn't break down like conventional oil does. Some engineers I've seen in the Ford truck forums have special dual stage filter systems and have a lab test their oil after running it for 50K+ miles and it comes back as good as the oil coming out of a truck after 3K miles with a regular filter.
    For Sale: 2014 A5 2.0T (Scuba Blue) | APR Stage 2 v2.0 | 8spd Tiptronic | MMI 3G+ w/Nav | Advanced Key | B&O (w/ upgraded sub) | park assist | heated memory seats & mirrors |
    1/4 Mile: 13.39 @ 100.74 mph on fake 93 octane (90 + Lucas booster)
    Mods can be found in my Build Thread
    Veteran Member Four Rings JBAeroEngineer's Avatar
    Sep 19 2012
    Capitol Area
    people are not having issues with residue/particles when using an oil extractor?
    Feb 07 2012
    Quote Originally Posted by JBAeroEngineer View Post
    I didn't. It's how most dealers do it as well.
    Senior Member Two Rings Fox Fader's Avatar
    Nov 24 2014
    Columbus, GA
    I'm old skool, drain from the bottom.
    10 A4 quattro PP 18" Sport Package 6 spd manual 60k
    SOLD! :(
    10 Ford GT 401a 5sp 17k miles
    11 KLR 650
    07 Tuono Factory
    03 F150 STX Lightning replica
    11 Kia Sorento SX (wife's)
    Slammin Tunes
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Quote Originally Posted by avant-grd View Post
    Thanks,
    I reset mine using the settings under the CAR menu for oil changes. Don't think you need a vag-com. Press the CAR button then look for the Service Interval option then chose reset.
    I drain the oil by the plug method. Gives me an opportunity to look things over (under).
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
    Jan 03 2013
    Baltimore
    Quote Originally Posted by blbroo View Post
    You need vag-com to reset both the service and oil change interval.
    Sep 13 2009
    2010 A4 2.0T
    Mississauga, Ontario
    Is there a trick to the mityvac? I also have the mityvac 7201 (http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER) but I made the mistake of not allowing the oil to warm up before starting to pump it out.
    I had some trouble as I would put the hose in, pump the 10 times or whatever it calls for, and nothing. Even continuously pumping it felt like there was serious restriction going on. Switching the relief valve showed there was indeed some vac pressure in the mityvac reservoir. I noticed adjusting the hose a little (the amount I put in) would allow a nice flow, before cutting off again. Hard to determine if it's just that i'm putting too much hose in there or what....
    Apr 07 2014
    United States
    You might have a kink in the hose.
    Veteran Member Four Rings ItsDubC's Avatar
    May 26 2009
    Houston, TX
    Been using a Mityvac 7400 w/ no issues since 2010. Since I'm never 100% sure whether the tube opening is at the very bottom, I move the tube in and out a bit once it starts sucking air...
    I continue this until I can't get any more oil out.
    OEM+ '09 Meteor Gray A4 2.0T Tip Quattro Prem+ Sport Saloon
    All-Weather Mats • Hüper Optik Stark 30 • APR Stage I • A5 S-line Y-spokes • Hankook Ventus V12 evos • S-line Stone Guards • VAG-COM'd
    Bilstein PSS10s • Eurocode IC Pipe • Avant Dual Exhaust • StopTech Pads • Lamin-X'd • Smoked Ambers • Blesk 5000ks • 034 Trans Mount
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    VagCom is only needed for the Service Interval reset, not oil change interval.
    2011 A4 Avant
    Oct 26 2012
    St. Louis, MO
    Quote Originally Posted by jfo View Post
    Yep. Oil change can be done like this:
    Nov 24 2014
    Rockwall, TX
    Will be doing the oil extractor method this weekend. First time going this route. Will see how it compares to going under.
    Sep 19 2012
    Capitol Area
    Quote Originally Posted by vdubtx View Post
    how'd it go? about to pick one up from amazon
