Originally Posted by
timob
The Curt hitch bolts mostly to the floor of the trunk. That makes me edgy, but if you search you will fund many posts, people posting photos of towing boats, etc, In Europe they have a more elaborate mounting setup, you'll see chatter about that, too.
The Curt hitch doesn't mount to the floor, at least not in the Avant or Allroad. It bolts onto the frame rails that hold the rear bumper crash bar. Two of the bolts do go through the rails from inside the cargo area and two more are bolted from below. The Euro style hitch like the Westfalia, uses the same frame rails, but has two arms that slide into the tubular rails, replacing the crash bar that sits under the bumper.
The Curt hitch is a class 1, the lowest weight rating. Towing is no problem, but you do need to be aware of the approximate combined weight of the trailer and load.
The Euro style hitch is typically "hidden", using a detachable tow bar that clips onto the hitch from below like the one pictured above. I installed the Curt on my Avant and then replaced it with a Westfalia after two years. I have towed a 5x8 UHaul with the Curt, but only on one occasion. I installed it for use with a bike rack. I didn't really like the appearance so changed it for the Westfalia when I had the bumper off to swap the rear valance.
Wiring is no problem using the Curt connectors but you do of course need to splice into the car wiring. And the Westfalia hitch is more expensive.
