Results 1 to 15 of 15
    Nov 17 2014
    Spokane
    replace clutch bolts?
    so im waiting on my stage 3 ebay clutch kit and my car buddy was saying i should replace my clutch bolts because they get stripped? the kit i ordered didnt come with any, would i be screwed if i dont replace them?
    Dec 05 2007
    Always replace your clutch component bolts. They are stretch bolts and one time use.
    Veteran Member Three Rings Rodgman15's Avatar
    Jan 12 2014
    Fargo, ND
    Oof, eBay clutch kit. You are a brave soul.
    Dec 05 2007
    Wow, don't know how I really missed that part. Saw Spec or SB when I read it. Valeo singly mass replacement kit is favored for OEM replacement with a little more grab than stock. What brand name ebay kit? They do have reliable kits on there.
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    I've read those bolts can be had from the dealer for a few dollars each.
    Nov 17 2014
    Spokane
    okay sweet thats what i thought, my mechanic told me to buy it so im trusting his word even tho hes more of a subaru guy
    Jan 12 2014
    Fargo, ND
    When I see "ebay clutch kit" together I assume the worst lol. A Valeo kit would be a fine replacement.
    Jun 30 2008
    Erie, Pennsylvania
    I'm rocking all re-used fasteners on my clutch. (I 'rock' all my fasteners, btw.) I think the flywheel bolts are actually on their 3rd go-round.
    But my car makes like 8 horsepowers, so it's all good.
    Veteran Member Four Rings BaseDrifter's Avatar
    May 18 2010
    The cost-benefit analysis is pretty simple to me.
    What do you gain by not replacing the flywheel and pressure plate bolts?
    - You save $25 by not buying new hardware.
    - You save time by not waiting for the hardware to arrive (this can be completely negated by ordering new hardware with the clutch.)
    What do you potentially lose by not replacing the flywheel and pressure plate bolts?
    - At a minimum, if there is a problem with the bolts backing out or breaking you have to pull the transmission (or motor) to address the issue. This alone is enough reason for me to spend the $25 on new hardware to eliminate this concern.
    - If the flywheel bolts back out they could end up ruining the flywheel (egged holes) or the clutch.
    - If the pressure plate bolts back out it could cause a misalignment with the throwout bearing or pressure plate fingers.
    Now, the $25 savings are guaranteed by not replacing the bolts. And as Walky has shown, having a problem with the bolts is not guaranteed. So now it becomes a risk profile question. How risky do you want to be? What is the percent chance that something will go wrong? Unfortunately that question is impossible to answer, every car is different (and so are the bolts.)
    In any case, if there is ever a problem with the bolts, you're gonna have to open it up again. Spend the $25 on new hardware and eliminate a costly and time consuming potential failure point.
    | Update thread / Youtube Channel |
    97 A4 1.8TQM: Frankenturbo|TyrolSport SMIC|034 HFC|Borla catback|Carbonio/007 DV|Vogtland GT3|034 RSB|Apikol Bushings|034 SD motor/tranny/strut mounts|A8 brakes/SS lines|JHM trio|Meyle HD CA/TREs|
    01 S4 2.7T: Stock
    Jun 30 2008
    Erie, Pennsylvania
    From experience, I know I won't have problems. I don't really recommend it to other people though. If something happens, I can just fix it. That may not be their situation.
    The benefit is that I get to tell people that 5-speed swapping my A4 "only cost me 100 bucks". 125 just doesn't sound as cool.
    Aug 10 2014
    Ohio
    I'd totally go new hardware. 1) It looks better 2) The Haynes manual pretty much says to replace every bolt in the damn car whenever you so much as adjust the mirror. 3) You always put new gas in the car, right? Why should nuts and bolts be any different?
    Any bolts I do reuse always get wire wheeled to a mirror shine.
    May 18 2010
    Of course you can, but the point is that for a measly $25 you should never have to.
    We're not talking about dropping $500 on a maintenance item that doesn't need to be replaced, nor are we talking about bolts that are easy to get to. It's 25 bucks to NOT have to go back in to fix a problem if one occurs because you reused the bolts.
    Ask Grapebandit about when someone reused old flywheel bolts on his car.
    It's really a no-brainer to me. But to each their own, some people are masochists. ;)
    01 S4 2.7T: Stock
    Veteran Member Four Rings vrmm's Avatar
    Nov 14 2011
    NW
    Make sure you torque them bitches correctly! 18ft lb's is what the manual states. None of this 15 ft lb's bs some s4 owners are spewing. I torqued mine to 25ft lbs after they backed out with blue loctite. Why do you need a stage 3 clutch?
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    clutch bolts? you mean flywheel or pressure plate bolts? you can reuse flywheel bolts even though they are stretch, many ppl have will no ill effects. I have done so myself when I needed to get a car back together. audi dealership never puts new flywheel bolts.
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Jun 30 2008
    Erie, Pennsylvania
    Indeed. They do not generally hit their stretch limit after just one use. The same with head bolts, too. Some manufacturers actually give a spec so you can check the bolt length to make sure they are good to use again. Most would rather not publish the spec and just sell you new bolts every time.
