Results 1 to 40 of 41
    Dec 30 2014
    Buell 1125r Yamaha Fz1 KTM 250xc
    Charlotte, NC
    Thumbs up MMI 2G Update Software
    Hey guys, new to the forum. Been doing a lot of reading but never did register until now.
    I bought a 06 Avant and love it. My biggest gripe so far is the fact that I can't stream music via bluetooth especially when the car has bluetooth capabilities with the phone!!! (makes no sense to me)I wanted to do the MMI update and get the AMI bluetooth kit so I can stream from my iPhone. First thing in my task was to get the MMI from version 11.9.0 to 46.1.0
    It took me a while to source the ISO files.
    My goal with this post is to make the files easily accessed for others. Here is a link to the files on my Google Drive.
    CD1: https://drive.google.com/file/d/0B-0...ew?usp=sharing
    CD2: https://drive.google.com/file/d/0B-0...ew?usp=sharing
    CD1 is the bluetooth update. I had to run the update twice to get the phone bluetooth to work. After I did it once, it said that "The telephone is not installed." After the 2nd update everything worked fine.
    CD2 is the actual MMI update. I used it to go straight from 1190 to 4610. Everything worked great.
    Hope this is helpful to someone out there trying to do the update.
    FYI: I am a Mac user. I could not burn the ISO files to a disc with my MacBook Pro. I had to use a Windows based machine to burn the discs!!!!! Hopefully this saves someone from some frustration like it caused me.
    Mere is my Avant. Its has been raining ever since I bought it, so i've had no opportunities to snap some good photos of it.
    Sep 11 2014
    Phoenix
    Wow this is great. So do I need to burn these files onto a CD-R and then just "play" it through the MMI? And what is the AMI Bluetooth kit? Thanks so much!
    Current DD - 2015 Golf R #333
    Prior - 1990 Volvo 740, 1996 Volvo 850, 2004 Volvo S40, 2004 Volvo V70R, 2007 Volkswagen GLI, 2010 A6 Avant 3.0T, 2014 Subaru Forester XT
    Dec 30 2014
    Charlotte, NC
    Download the files to your computer. Burn them to a CD-R using a .ISO mounting program ( http://windows.microsoft.com/en-us/w...om-an-iso-file ) The .ISO file contains many other files. It has to be burnt properly for the MMI to be able to read the disc.
    I used this link to get a good idea of step by step instructions on the process:
    http://uberlame.com/a6_tsb/MMI/MMI%2...0procedure.pdf
    The reason I had to do the update is that within the hidden menu, I could not activate the AUX at the software version 1190, the option was not there.
    Now I just need to figure out which device i want to get so that I can stream music from my phone via Pandora or Slacker.
    Oct 18 2014
    Sherman Oaks
    I have 4610 and couldn't stream from my iPhone (I have bluetooth enabled). Weird.
    Any idea if this works with Android? Any other accessories needed?
    Dec 30 2014
    Charlotte, NC
    4610 does not give you the ability to stream. What it did for me was that it allowed me to enable the AUX within the hidden menu. That way when I get around to installing the AMI parts, I will be able to get everything working.
    Oct 18 2014
    Sherman Oaks
    Quote Originally Posted by InfamousAvant View Post
    Gotcha, so I need the parts then.
    Could you list what AMI parts those are? The one thing I do miss is Pandora and would love to be able to get that back without having to tool around with a 3.5' aux cord.
    Feb 06 2013
    CA
    Quote Originally Posted by Smeag OL' View Post
    Lots of threads on this and in fact there are other options besides AMI. I have a Dension 500 installed with a tune2air module to allow A2DP Bluetooth streaming. Also search for xcarlink.
    Veteran Member Four Rings Quattrocentric's Avatar
    Oct 19 2013
    Another Audi, what else?
    Silver Spring, Md
    Welcome to another avant driver! Looking good!
    Established Member Two Rings meatalking's Avatar
    Feb 26 2015
    2005 Audi A6 C6 Quatro / 2007 Hummer H3X
    Phoenix,Az
    kinda late to this thread but will i loose some functions in my mmi if i update it
    I wanna go fast !!!
    Senior Member Three Rings FormulaElement's Avatar
    Jul 02 2013
    406, MT
    No, it might disable the climate controls appearing on the screen and the battery meter. But those can be brought back easily after the update.
    Feb 26 2015
    Phoenix,Az
    I need vcds for that tho right I think I'm at 3360 now I don't have the batt meter now also is it worth it ? since i already have 3360 also i dont have the hidden menu ppl speak of
    I wanna go fast !!!
    Established Member Two Rings geekinc's Avatar
    Feb 12 2011
    az
    You can use Disk Utility on Mac to burn .iso's and thanks for the info and links!
    --geekinc
    2008 A4 2.0T Quattro 6MT Ibis/Black SLine APR TUNED
    Oct 27 2014
    Birmingham, UK
    Sorry fairly new to the forum, so if I update my MMI software (like shown above) will I be able to stream music via bluetooth or would I need some additional hardware etc.
    Thanks
    Jul 02 2013
    406, MT
    No. You need additional hardware because the A2DP bluetooth codec wasn't around back when this MMI system was made.
    Active Member Two Rings Toppatop55's Avatar
    Mar 14 2015
    New Britain, CT
    probably a stupid question, but what software version should my 08 A6 have and do dealers charge to upgrade the mmi software?
    Jul 02 2013
    406, MT
    Quote Originally Posted by Toppatop55 View Post
    Most of the time dealers charge to upgrade it. The latest North America software version is 46.1.0. See the third picture from the top of this thread.
    Mar 14 2015
    New Britain, CT
    I followed the directions as written but at the end of the CD2 I get SRFPO "Not OK" it is still at version 16 instead of updating to version 17. Any ideas?
    ~Life Is Good~
    Mar 14 2015
    New Britain, CT
    I think something went wrong. My XM RADIO IS NOW GRAYED OUT. says "not installed contact dealer." Any ideas please help.
    ~Life Is Good~
    Jul 02 2013
    406, MT
    Try updating again with both CD's. If it doesn't work, unplug your battery for a half hour then try the updates again.
    If it still doesn't work, then your XM module is bricked...
    Mar 14 2015
    New Britain, CT
    Should I redo both cd even if the issue was with the 2nd cd? I also have a new menue for "window" that is grated out. Any idea on how to ungray it?
    ~Life Is Good~
    Mar 14 2015
    New Britain, CT
    I just tried redoing the updates but I get "no device is selected for update" any thoughts?
    ~Life Is Good~
    Mar 14 2015
    New Britain, CT
    [IMG][/IMG]
    [IMG] [/IMG]
    ~Life Is Good~
    Mar 14 2015
    New Britain, CT
    I must say, after 24 hours of posting the pics, I still have not gotten any response or impute. I'm assuming its because its the weekend. ......way too quiet in here
    ~Life Is Good~
    Jul 02 2013
    406, MT
    Wish I could help but i don't know anything about that, and no one i've heard of has had the same problem. Did you disrupt the update or did something happen during it?
    If you get the hidden menu active in the MMI I'm pretty sure you can manually start the boot loader and override any software version from one to another without going through the SW update. That might be worth a try.
    Also a VCDS scan of that module would be helpful.
    Nov 19 2012
    Mankato, MN
    You probably haven't gotten any replies because its A. The weekend, and B. People are still trying to figure out what is going on.
    But you're the first person to encounter that issue so I'm not sure exactly what is going on. For most of us the update has been fairly smooth sailing.
    A VCDS scan should be the first thing you try though to see if you might be having a problem with a module or something.
    Also regarding what FormulaElement said: Aren't we not supposed to start the bootloader from the hidden menu?
    Jul 02 2013
    406, MT
    Not really because from what i've found it starts a boot loader that can install a earlier version of the software that might not play nicely with a different modules newer software. You're supposed to start the update it by holding return and setup i think? (instead of car and setup which is the hidden menu)
    Mar 14 2015
    New Britain, CT
    I would purchase the vag com and do a vid scan but this is all new to me and I don't want to fudge anything up more than it already is. I am trying to find a zine member from CT who can assist me with a vag com. It's either that or I visit the stealers hip so thy an charge me $125 to tell me wh I already know.
    ~Life Is Good~
    Senior Member Two Rings Baudi18t's Avatar
    Aug 10 2007
    '08 a6 3.2q, '14 Accord spt, '91 Toyota Mr2
    Queens, NY
    I love the idea of the front end on your avant, anymore garage shots of that?
    Veteran Member Four Rings c@@kieMonsta's Avatar
    May 17 2009
    Idaho
    Did you do this with a battery maintainer?
    Current:
    2019 Ford Expedition
    2009 3.0T A6 Avant w/Prestige package, Side Assist, and Cold Weather package
    2016 2.7 EcoBoost Ford F-150 XLT SCREW
    2007 3.2 A4 Deep Sea Blue Avant
    2006 A6 Arctic White Avant
    2002 1.8t A4 Sedan
    Apr 07 2015
    FL
    i recently updated mine. Did it with the car running, outside. Took about 45 minutes. no issues
    May 17 2009
    Idaho
    Ok so I updated my MMI software successfully...for the most part. It failed on part of the DSP update, and re-running it causes it to fail again. I'm not sure yet what impact this will have, but so far everything is working. Also, did anyone do the 45 minute phone preparation update?
    Current:
    2002 1.8t A4 Sedan
    Established Member Two Rings audi786's Avatar
    Jul 22 2014
    2015 Audi Q7 TDI Prestige S-line
    Houston, TX
    Quote Originally Posted by FormulaElement View Post
    How do I go about re-enabling this? I do not have the climate controls or battery meter anymore after the update
    Feb 26 2015
    Phoenix,Az
    Quote Originally Posted by audi786 View Post
    Use carista it's the easiest and most cost-effective
    I wanna go fast !!!
    Jul 22 2014
    Houston, TX
    Quote Originally Posted by meatalking View Post
    i have a Vag-Com, I figured it out by searching at Ross-Tech for someone with similar problem. This is what I did:
    ***As VCDS always directs, write down any previous values before changing anything so you can get back to where you were in case something doesn't work. The steps below worked for me. Your results may vary.***
    Go to [07] - Control Head (in the Control Module)
    - Go to Adaptation
    - Go to Channel 11, then click Read
    - Add +32 to existing value of what ever number is yours, in my case it was #4 so that would be value of 36 (VAG–COM provides a pop–up with the options)
    - Test and save
    -There will be a "do you really want to do this?" type warning. Click OK.
    - Reset MMI by pressing these 3 buttons.
    Pressing SETUP, BIG Center Knob, and top right soft button together, now all you have to do is release you fingers and it will reboot.
    As for the batttery status that also went away:
    TURNING BATTERY STATUS BACK ON:
    - Go to Adaptation
    -Go to Channel 02, then click Read
    -At this point, a value of 3 was shown on mine. Yours may vary so adjust your numbers accordingly.
    - +00032 is the Battery Status so you add 32 to the 3 for a total of 35.
    -Thus instead of 3, input 35 in the New Value field.
    -Click TEST.
    -If 35 shows up in the Test Field, click SAVE.
    Got my Climate control interface and battery status back now!
    Established Member Two Rings corrado-correr's Avatar
    May 28 2015
    Royal Oak, MI
    I have an early build 2005 C6 A6 so the MMI softare is a bit older than what most people on here have. Has anyone been successful at locating an .iso (Zug 317) download to go from 0750 -> 1070?
    Per the TSD linked above this is required as an interim step before loading "4F0998961_cd2.iso" (part of Zug 864).
    Side note: I was able to do the bluetooth update using "4F0998961_cd1.iso" and I've got bluetooth calling now, which is great, but I want to get an AMI working as well. Which isnt working yet without the "4F0998961_cd2.iso" (part of Zug 864) update.
    Pics of current SW level:
    2015-09-21_08-39-22 by Raven, on Flickr
    Error message if I try to run "4F0998961_cd2.iso" without doing the interim .iso (Zug 317) update to go from 0750 -> 1070.
    2015-09-21_08-48-42 by Raven, on Flickr
    Raven
    Apr 10 2015
    Glendale, Arizona
    When i download the files it wont let me use windows disk burner to burn the disk
    May 28 2015
    Royal Oak, MI
    Quote Originally Posted by corrado-correr View Post
    anyone?
    Raven
    Apr 10 2015
    Glendale, Arizona
    How strong should the battery charger/maintainer be?
    May 28 2015
    Royal Oak, MI
    Quote Originally Posted by nyquetinp94 View Post
    30 amp minimum.
    Raven
    Apr 10 2015
    Glendale, Arizona
    Any Suggestions on which charger to buy?
    30 amp minimum.
