The most popular these days is the Red Top 06E905115E coils.
These coils are said to be more powerful, better for high boost, better for larger plug gaps, and of course they are red so they make your car faster...
They are longer than the traditional 1.8T coils. There are endless adapters available from your favorite aftermarket parts provider, although I have never used them. I simply remove the rubber boots from the stock 1.8T coils and "double stack" them with the ones that are on the FSI ones. The fit is nice and I have never had one come loose.
Reliability...
There is a common theme with these coils. Premature failure
This is thought to have been related to back coil wiring harness, bad plugs, bad ECU, too large plug gaps etc etc etc..
I myself have lost a few 2.0T GTI black top coils and when I bought a set of the new best thing red tops I wanted to see what was going on before I installed them.
Doing some research I found a lot of talk of DWELL.
DWELL or "tsrldyn" is the acronym Bosch uses
tsrldyn {Last- und Dynamikkorrigierte Schließzeit}
tsrldyn { Load and dynamic Corrected closing time }
Its how long the ECU charges the coil in Milliseconds
There is basically 4 "MAPS" that need to be grafted over from the 2.0T ECU to the 1.8t/2.7t/ whatever standard coil engine you are swapping to. I cannot take credit for figuring this out. Some of the guys over at nefmoto have been debating about this long before I started to even think about dwell.
I used a 2010 FSI ECU to get the settings for the 2.0T coil maps and then compared and altered my 2.7T BEL ECU to use the settings from the 2.0T.
There are endless combinations of calculations the ECU uses to set the charge time at any given moment. These 4 maps are what is referenced to calculate it depending on conditions.
The "traditional" coils seem to like around 2.5-3.0MS and can go up to 3.5MS from what I have seen.
The "FSI" coils seem to like 2.0-2.5MS and the highest I have seen is 2.8MS.
It seems overcharging these to 3.5MS can cause them to fail, as seem quite regularly.
The maps are:
-KFTSRL
-FSWTM
-KFSZDUB
-FTSDRLW
2.0T Coil DWELL MAPS
kftsrl
3.00 3.00 3.00 3.00 3.00 3.00 3.00 3.00 3.00 3.00
2.60 2.30 2.30 2.40 2.40 2.60 2.70 2.90 3.00 3.00
2.40 2.20 2.30 2.30 2.40 2.60 2.70 2.80 2.90 2.90
2.10 2.00 2.10 2.10 2.20 2.50 2.60 2.80 2.90 2.90
1.90 1.80 1.90 2.00 2.10 2.30 2.50 2.70 2.80 2.80
1.60 1.70 1.80 1.80 1.90 2.10 2.30 2.50 2.70 2.70
1.50 1.60 1.70 1.70 1.80 1.90 2.10 2.30 2.50 2.50
1.50 1.50 1.60 1.60 1.70 1.80 1.90 2.10 2.30 2.30
fswtm
1.00
1.00
1.00
1.00
1.00
kfszdub
3.25 3.56 3.84 4.88 5.88 6.25 5.91 5.56 5.00 4.56 4.38 4.16 4.00 3.34 3.19 2.78
1.88 1.91 1.94 2.00 2.03 2.19 2.28 2.38 2.69 3.28 3.31 3.34 3.22 2.66 2.53 2.22
1.25 1.28 1.28 1.28 1.28 1.31 1.34 1.34 1.38 1.41 1.44 1.47 1.50 1.72 1.66 1.44
1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00
0.97 0.94 0.94 0.94 0.94 0.94 0.94 0.94 0.94 0.94 0.94 0.94 0.94 0.94 0.94 0.94
0.91 0.91 0.88 0.88 0.88 0.88 0.88 0.88 0.88 0.88 0.88 0.88 0.88 0.88 0.88 0.88
0.81 0.81 0.78 0.78 0.78 0.78 0.78 0.78 0.75 0.75 0.75 0.75 0.78 0.78 0.81 0.81
ftsdrlw
1.00
1.00
1.00
1.00
1.00
1.00
2.7T APB DWELL MAPS
kftsrl
3.00 2.90 2.60 2.50 2.50 2.50 2.40 2.90 3.00 3.00
2.60 2.40 2.10 2.00 2.00 2.10 2.20 2.50 2.90 3.00
1.80 1.80 1.80 1.80 1.80 2.00 2.10 2.40 2.90 3.00
1.40 1.60 1.70 1.70 1.80 2.00 2.10 2.40 2.90 3.00
1.40 1.50 1.60 1.70 1.80 2.00 2.10 2.40 3.00 3.00
1.40 1.40 1.50 1.60 1.70 1.80 2.10 2.40 3.00 3.00
1.40 1.40 1.40 1.50 1.60 1.70 1.90 2.10 2.40 2.50
fswtm
1.50
1.50
1.50
1.00
1.00
kfszdub
3.53 3.66 3.88 4.13 4.91 6.59 6.94 7.97 7.97 7.97 7.97 7.97 7.72 7.41 5.97 5.28
2.13 2.19 2.22 2.25 2.38 2.44 2.50 2.59 2.69 2.97 3.25 4.78 4.59 4.41 3.56 3.16
1.53 1.56 1.56 1.59 1.63 1.66 1.66 1.69 1.72 1.75 1.78 1.84 1.91 2.13 1.72 1.53
1.19 1.19 1.22 1.22 1.22 1.22 1.22 1.25 1.25 1.25 1.28 1.28 1.28 1.31 1.47 1.28
1.09 1.09 1.09 1.09 1.09 1.09 1.09 1.09 1.09 1.13 1.13 1.13 1.13 1.13 1.25 1.13
0.84 0.84 0.84 0.84 0.84 0.84 0.84 0.84 0.84 0.84 0.84 0.81 0.81 0.81 0.75 0.75
ftsdrlw
2.00
2.00
2.00
2.00
2.00
2.00
2.7T BEL DWELL MAPS
kftsrl
3.00 2.60 2.40 2.30 2.40 2.60 2.70 2.80 2.90 2.90
3.00 2.40 2.20 2.20 2.40 2.60 2.60 2.70 2.70 2.70
2.70 2.10 2.00 1.90 2.20 2.40 2.50 2.60 2.70 2.70
2.60 1.90 1.70 1.70 2.00 2.20 2.30 2.50 2.70 2.70
2.00 1.60 1.60 1.70 1.90 2.00 2.20 2.40 2.60 2.70
1.60 1.40 1.50 1.60 1.80 1.90 2.00 2.20 2.50 2.60
1.40 1.40 1.40 1.50 1.70 1.80 1.90 2.00 2.30 2.40
fswtm
1.50
1.50
1.50
1.00
1.00
kfszdub
2.94 3.06 3.25 3.84 5.88 6.25 5.56 5.00 4.56 4.16 3.84 3.56 3.34 3.03 2.78 2.50
1.81 1.81 1.88 1.94 2.03 2.19 2.38 2.69 3.28 3.34 3.09 2.88 2.66 2.41 2.22 2.00
1.22 1.22 1.25 1.28 1.28 1.31 1.34 1.38 1.41 1.47 1.53 1.75 1.72 1.59 1.44 1.31
0.91 0.91 0.91 0.88 0.88 0.88 0.88 0.88 0.88 0.88 0.88 0.88 0.88 0.88 0.88 0.91
0.84 0.81 0.81 0.78 0.78 0.78 0.78 0.75 0.75 0.75 0.78 0.78 0.78 0.81 0.81 0.81
0.63 0.59 0.59 0.59 0.56 0.56 0.56 0.53 0.53 0.53 0.53 0.56 0.59 0.63 0.66 0.69
ftsdrlw
3.00
3.00
3.00
3.00
3.00
3.00
STOCK 2.7T BEL LOG
2.0T DWELL MAPS GRAFTED TO 2.7T BEL
The idea is the same for any other ECU, you just have to find the maps, copy the changes over and correct the check-sum. Because every ECU part number has the maps in completely different addresses in the file it will be up to you/your tuner/a tuner friend to find the maps in your ECU for you to complete the changes.
Here is a log of my before and after. I did not do a 3rd gear from 3k to redline for a few reasons. I didn't have anyone to hold the laptop and star/stop the logger. second I wanted to see "an average" of the dwell during regular driving in all gears/loads/speeds.
The differences are small but so far I have had zero issues with my coils and under WOT I have zero misfires.
I'm using copper NGK BKRE7 @ .035" 21 PSI boost 2.7T BEL engine.
I will update this with the addresses for specific ECU's as they become available. If you have any please post them up for the others to use.
I'm not sure how technical this thread will get but lets see where it goes from here.
