Had my fuel pump replaced at a local shop and got it back with the fuel light flashing in the display. The gauge was also reading incorrectly, and when filled up it only reads around half. I read the code via vagcom and here are the results...
1 Fault Found:
00771 - Fuel Level Sensor (G)
30-00 - Open or Short to Plus
I pulled the rear seat and removed the cover. It looked like everything was hooked up fine....
Do I need to recali the fuel level sender?
