Results 1 to 40 of 51
    Established Member Two Rings euroenvy's Avatar
    Nov 10 2013
    2000 Dodge 2500 Cummins w/bolt ons- 2007 Yukon Denali w/colda air intake, magnaflow exhaust and chip
    Dallas, TX
    B7 S4 Tip Tronic Transmission Blew! 6 Speed Swap possibilities?
    Ok guys so long story short the transmission went out on my 05' B7 after racing an AMG Benz going 150+. Yes I beat him, but ended up having the car towed at a friends parking garage shortly after It's at a shop right now and they are quoting me $3,200 for another tip tronic. Talked to one of the guys at JHM and said that doing a 6 speed swap would be about the same as getting another automatic transmission. I already went to Audis4parts.com but don't have anything currently for the B7.
    Also what parts would I need for a 6 speed swap? If it is unlikely to go through with the swap, where do ya'll recommend getting an automatic transmission? Lower miles would be great. Thanks in advance.
    May 20 2010
    If you can do it, do it. Otherwise, you could get a used tiptronic transmission for less and have it built up to be bulletproof by companies like Level10 (I forget the other companies offhand).
    For starters, you'd need a new subframe (mount positions are different, i think), the 6MT, axles, drivershaft, rear diff, slave cylinder, clutch pedal assembly, ECU/TCU change for 6MT, shifter, update on cluster... I'm sure there's more I'm forgetting.
    Nov 30 2008
    05 S4, 02 A4
    Raleigh, NC
    Curious what sort of symptoms/issue you are experiencing with your "blown" transmission? Typically they are pretty bulletproof.
    Kool-aid red B6 S4 Avant. JHM NAWZZZ kit, JHM headers, FI cat-back, JHM tune, JHM IM, LWCP, LW rotors.
    Senior Member Three Rings blocke's Avatar
    Jul 26 2013
    1990 BMW 325i (sold), 2006 VW GTI (sold), 2006 A4 S-line (sold), 2014 Jetta SportWagen TDI
    Temecula, CA
    Quote Originally Posted by WolfS4 View Post
    Interested to hear this as well.
    Performance: Fast Intentions 12" resonated cat back, ECS Snub Mount, JHM LTW Crank Pulley, JHM IM spacers, Optima Red Top, Dimple Oil drain magnet, 034 engine mounts,
    Suspension/Brakes: JHM LTW rotors front & Rear, Hawk HPS Pads, VMR V708's, H&R Sport springs, 034 strut mounts.
    Visual: Lamin-X on headlights, 20% tint , ZIZA city LEDs, Ziza License place LEDS, Interior LED conversion, R8 oil cap, 996 coolant cap
    Instagram: lockebrian
    Nov 10 2013
    Dallas, TX
    Audibot;10351281]If you can do it, do it. Otherwise, you could get a used tiptronic transmission for less and have it built up to be bulletproof by companies like Level10 (I forget the other companies offhand).
    Seems like it may be more expensive to do the 6 speed swap. But the other option was to get another tip tronic and upgrading it.
    May 20 2010
    Quote Originally Posted by euroenvy View Post
    Agree. Cost-wise, I know they'll ship you a bulletproof transmission for like $5k, without having to turn yours in. If you send it to them, it's obviously less. I think 507 is another company I am remembering offhand. But yeah, it's all up to what OP wants to do.
    Scotty from Advanced can probably give you more info as to what a swap would entail. He also probably has some good deals on a used transmission, if yours cannot be salvaged.
    Nov 10 2013
    Dallas, TX
    3rd gear is completely destroyed. Lost all power shortly after the race. Pulled over let it sit for 5 min and tried to drive away, 1st and 2nd go in fine but when you push to third it's like nothing is there, you can't feel any power. It will not make it to 4th even with tip tronic. Reverse for some reason does not go in either.
    Veteran Member Three Rings SprintBlueWorld's Avatar
    Sep 16 2013
    08 Hemi Big Horn, 08 Honda civic, 08 Audi S4 Cab MT6
    Pa
    http://m.ebay.com/itm/291328354205?cmd=VISPEC
    If you get this car let me get a coupla parts ;)
    Oem RS4 Reps, RS4 Pedals, KN Air Filter, JHM 93 tune, JHM Intake Spacers, Rear Stoptech Slots & SS Brake lines, JHM 6-Rib Pullys, 034 Snubby Bracket, Dimple/ECS Oil & Diff Magnetic Drain plugs, Apikol Diff Mount, 034 Carrier Mount Inserts, Corsa RSC Cat-Back, 034 Sway Bar & End Links, Piggies in a Blanket, Front JHM LW Rotors, Hawk HPS pads, 13mm Spacers
    Veteran Member Four Rings dsgray16's Avatar
    Jun 11 2013
    How did you blow 3rd gear going 150?
    You sure there aren't other issues going on?
    Events: Time to register for Avantoberfest 2018!: www.avantoberfest.com
    Instagram: Audisport_Wagon
    Cars: Full B7 RS4 Avant swap http://www.audizine.com/forum/showth...S4-Avant-Build
    B7 RS4 sedan in Phantom Black - just a clean OEM+ daily driver
    Nov 30 2008
    05 S4, 02 A4
    Raleigh, NC
    Sounds pretty bad. Pulled the codes from the TCU as well? How many miles? Checked fluid levels? Personally, I would pick up a good used one if it really is toast.
    Nov 10 2013
    Dallas, TX
    Quote Originally Posted by dsgray16 View Post
    Around 3rd gear I heard and felt something really bad still went into 4th 5th 6th, when I slowed down to 60mph car was still driving fine. Was approaching downtown and slowed down for traffic once in 3rd gear I noticed the loss of power and RPM needle went down to idle RPM. The gear selection area on the dash then was highlighted in red.
    Jun 11 2013
    So it went into limp mode I guess.. How many miles? What mods?
    Nov 10 2013
    Dallas, TX
    120K and all stock was about to get a JHM Tune for Christmas...
    Veteran Member Four Rings Blackstallion's Avatar
    Sep 22 2009
    Hmmm were you able to run the car while the dash was lit up? I had my old s4 dash lite up and I couldn't even get it to turn over...this may be off but have you tried to un/re-plug the ecu
    Senior Member Two Rings viridia's Avatar
    Apr 13 2011
    ham best meat
    Actually, auto subframe is okay with a manual trans. My original rusted out and I've been running an automatic for awhile now. BTDT!
    87 4k, 90 f350, 91 v8, 93 v8, 04 s4, 0a3 transmission
    Jan 29 2010
    north ga
    I have a used Tiptronic trans from one of my part-cars if you were looking for another one to swap in. 65VetteC6 also had a complete 6 speed swap but he may have sold it already. I've also got a 6-spd trans but I don't have the rest of the pieces needed for the swap
    Veteran Member Four Rings SpoolBus's Avatar
    Aug 07 2013
    ATL/GA
    I'd personally go with the built auto, if you've ever ridden in a transmission built by say level10 (can't recall the company of the one I rode in) its nuts. It will shift hard if built which is something to consider (maybe different levels\packages)
    May 13 2008
    MQBs
    San Francisco
    Get it hooked up to VAGCOM and reset the TCM (not your ECU^^) - Happened in my 2006 Avant years back, this fixed it. So if it isn't mechanical, that should help. You probably overheated the trans and triggered limp mode, this is a damage prevention technique and isn't always an indication of ACTUAL damage.
    If it's mechanical, stop listening to what everyone tells about 'mounting points' etc.. this is Audi, they are German, they'll keep the vehicles as interchangeably modular as possible.
    The 2.7tt Subframe from the B5 has almost the same mounting points as the B6/7, and if you haven' t had them off yourself and looked at them, please don't make claims and waste the forum's time. Worst case scenario, you need a manual subframe from another B7. Not a very easy undertaking unless you have a lift/shop and the time/money. It can be done, but quite costly.
    I'd personally love a high revving V8 with an Auto Transmission that shifted properly(buitl).. the Tip in my 2006 was boring AF, hence my switching years later to a Manual Avant.
    Past: B7 S4 Avant | Glacier White 8V S3 Build ig: @harithalbadri
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    Close, 517
    http://www.517trans.com/
    OP, You can get a low mile used Trans for under $750. http://www.car-part.com/
    All depends on what you want to do.
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
    Nov 10 2013
    Dallas, TX
    Quote Originally Posted by Blackstallion View Post
    I never thought of unplugging the ECU. Would disconnecting the battery clear the ECU?
    Nov 10 2013
    Dallas, TX
    Car is currently at a shop, would they even consider clearing the TCU to see if it will work. This is my first time taking my car to this shop because it is too far to get it towed to the shop where I get all my maintenance work done. The shop is also recommended in this forum in the "Central" section for the Dallas area. But from what I explained to the shop of what happened that night, and what they diagnosed they say my 3rd gear is out and need a new transmission.
    Nov 10 2013
    Dallas, TX
    Quote Originally Posted by BCsniper View Post
    Had a friend tell me about this website, I'll check it out. I might just end up getting one from here, preferably low mileage.
    Nov 10 2013
    Dallas, TX
    Close, 517
    I might just end up getting one from http://www.car-part.com/
    I have money aside for mods but with the transmission unexpectedly going out. I guess for now I'll just get it replaced and use whatever money that I have left over for mods. I plan on getting a JHM tune, LSD, and coilovers. Was going to get wheels but the money I had set aside for the wheels are now going to be used for the transmission.
    Senior Member Two Rings s4avanter's Avatar
    May 24 2011
    Mazda 5
    Washington%20DC
    Did ya try that TCU clearing?
    2017 SQ5
    Veteran Member Four Rings 65vetteC6's Avatar
    Jul 28 2007
    V8's
    In an Audi
    Subframe does not matter if going from auto to manual. Either do downpipes. You need a trans, tans brace, front axles, center drive shaft and rear diff, pedal assembly and that's about it. A little wiring, you can recode your ecu and abs. Probably easier to just replace the auto though.
    May 13 2008
    MQBs
    San Francisco
    Quote Originally Posted by 65vetteC6 View Post
    Thanks for the insight Alex - I was more making the point of interchangeability with the subframe comment.
    OP, Any updates? Did you reset the TCU to double check?
    Nov 10 2013
    Dallas, TX
    I'm just going to go ahead and replace the transmission, and ever since it messed up I haven't tried to mess with it. I'll try to talk to the shop and see what they say.
    Nov 10 2013
    Dallas, TX
    **UPDATE**
    Transmission got here this morning and car should be ready tomorrow afternoon. $750 for transmission and $700 for labor seems like a pretty good deal.
    Jan 29 2010
    north ga
    ....good to hear since that's what I'm asking for my transmissions and I'd think labor to replace should actually bye more like $300-500 depending on the shop and what all is getting done
    May 20 2010
    **UPDATE**
    Sounds like a great deal on the transmission. Labor varies--are you only replacing 3rd gear? I wonder if you could get some improved (hardened gears) and throw that in there. Maybe something crazy like a TDI 6th gear to boost fuel economy.
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    In a tip??
    Old Geezer, formerly known as Stud Muffin
    May 20 2010
    In the end it's all labor and gears.
    Jun 18 2010
    East of Cincinnati
    And what alternate ratios does Audi offer for their Tiptronic transmissions?
    May 20 2010
    Personally I have no idea b/c I've never done that. Might want to hit up some of the guys at Level10 or 507 to see if there are any options.
    Jun 18 2010
    East of Cincinnati
    I already have a .528 6th gear.
    May 20 2010
    Quote Originally Posted by QIKRNU View Post
    Nice! Must be a real sipper then! Slightly jealous, but not enough to rip apart my transmission.
    Nov 10 2013
    Dallas, TX
    Got the car back this morning! And the car drives better than ever. Thanks for everyone's suggestions on here. I would of ended up paying $2,600 for a transmission.
    Mar 04 2013
    05 Audi S4 Avant
    Central MA
    OP glad you got your car back and that it's now working great.
    Something doesn't add up though. Kookie suggested he had a similar situation and a TCU reset was all that was needed. Yet you chose not to even go down that route and just replace the whole transmission at a cost of $1500. What I am I missing here??? First rule of troubleshooting is to ALWAYS start with/eliminate the easy things first, then go from there. Why didn't you at least try the trans reset which would be diagnostics/scan fee (1 hrs labor?) instead of $1500 and car down for two plus weeks?
    Veteran Member Four Rings Axel-'s Avatar
    Jan 29 2011
    2006 JHM Stg 1 SC'd S4 Avant 6MT
    Toronto, CA
    And how old was this AMG that you beat as stock?
    Sprint Blue B7 S4 Avant 6MT - 421whp/350wtq - Review of all my mods
    JHM Stage 1 SC - JHM IM - JHM 5R clutch - JHM LWFW - Stoptech ST-60 BBK - KW v3 Coilovers - JHM shifter - Trexturk DP - Magnaflow CB - Hotchkis RSB - JHM IS - 034 Adj. FUCA - STE Gauges
    Oct 02 2005
    The Moon
    Quote Originally Posted by Axel- View Post
    Second
    Also, where's a good shop in DFW for German cars?
