Page 49 of 60 FirstFirst ... 39474849505159 ... LastLast
Results 1,921 to 1,960 of 2376
  1. #1921
    Jan 24 2013
    Quote Originally Posted by Tap053 View Post
    I'm between
    BBS CH-Rs @ 19x8.5+40
    TSW Nurburgrings @ 19x8.5+32
    Being that I'd like to run a 245 tire I want to make the safe play with the BBSs but I like the design and light weight of the TSWs; on the other hand I definitely see subtle lowering in my future so I'm thinking play it safe with the +40s and maybe throw some spacers in if I want them more aggressive...
    I love the CH-R. That’s be my choice.
    Email: [email protected]
    Call or Text: 914-243-1993
  2. #1922
    Jun 05 2019
    United States
    Does anyone know which spacers to run on the rear? I’m going 19x8.5 et35 with 245/35/19 tires and the front pokes out more than rear but I want that even flush look to match the front.
  3. #1923
    Senior Member Two Rings billk1967's Avatar
    Nov 27 2018
    Vancouver
    Quote Originally Posted by Auditree View Post
    ECS OEM wheel flush kit for S3's has a 10mm spacer for the front and a 17.5mm for the back so based on this I would say a 7.5mm spacer should do the trick if you are running a square setup all the way around.
    2018 Panther Black TT RS
  4. #1924
    May 03 2019
    1994 Turbo Civic, 2004 Corolla
    Ludowici, GA
    Been checking several pages before and still not 100% clear on how flush this fitment would be. This whole offset thing is almost like algebra. Im lowered on normal H&Rs with mag ride. Trying to run flush with 245 and 255s in the back.
    OFFSET: Front:+45mm,Rear:+48mm
  5. #1925
    Veteran Member Four Rings MerlinS3's Avatar
    Aug 04 2010
    2023 SQ7, 2021 Exclusive SQ5, 2022 Exclusive RS6
    Frisco, Tx
    Just throwing it out for anyone wanting aggressive fitment.
    My 18x10 et35 Zito ZF01 are still for sale/trade for stock S/RS3 wheels in San Antonio!
    [CENTER]CURRENT | RS6 Avant | Audi Exclusive | Uni Stage 2
    CURRENT | 2021 SQ5 Prestige | Exclusive Paint | Sport Exhaust | Black Optic | Dynamic Steering | Sport Package | BC Forged
    CURRENT | 2023 SQ7 | Stealth PPF | Lowered |
  6. #1926
    Veteran Member Four Rings Gberg888's Avatar
    Jun 16 2011
    996tt
    MA
    19x9.5 Et45 with a 265/35/19 tire?
    Will they fit?
    Garage:
    04 996TT X50, 06 Boxster S, 88 911 Targa, 16 S3
  7. #1927
    Jan 24 2013
    Quote Originally Posted by ZeroMech63 View Post
    Rear would be flush. Front would sit 10mm more inboard compared to the front. Not a good match imo.
    You’d be better off doing 9.5 +48 square
  8. #1928
    May 03 2019
    Ludowici, GA
    Quote Originally Posted by Paul@SupremePower View Post
    I already have 10mm spacer if that's all it needs to be flush. So with the set up you're talking about would I be able to get away with 255 all around? Plus I thought the front needs less offset then rear.
    Sent from my SM-G950U using Audizine mobile app
  9. #1929
    Jun 16 2011
    996tt
    MA
    Will they fit?
    Garage:
  10. #1930
    Veteran Member Four Rings Grey3's Avatar
    Mar 14 2018
    B8 S4, mk6 Jetta, 2 mustangs
    Sherrills Ford NC
    Quote Originally Posted by Gberg888 View Post
    Will they fit?
    265 may be too large...stock sport suspension?
    Sent from my phone using Tapatalk
  11. #1931
    Jun 16 2011
    996tt
    MA
    Stock for now...
    When I get the car ill test fit. Worst case, the tires that come on the car can be swapped over hopefully.
    Garage:
  12. #1932
    Established Member Two Rings OnionKnight's Avatar
    Mar 13 2019
    Missouri
    Can stock wheels be aggressive if they're painted?
  13. #1933
    Jan 24 2013
    You could use a spacer up front I suppose but The 19x9.5 +48 square would give you a close to flush stance without one. 255/30 would work. Fronts can go a little lower on the offset to fill the fender better...maybe 3mm. But that’s definitely not what you had with 19x8.5 +45 on 245 front with 19x9.5 +48 on 255 rear. Besides, staggering the widths on Audi’s like that doesn’t help performance. They tend to be nose heavy as it is and doing it like that will only increase understeer.
    Your best bet is to go square in wheel and tire width.
    Side note, double check inner clearance to the strut in the rear. 9.5 at +48 could be an issue.
    You may need to come down to +45 to clear it.
  14. #1934
    Established Member Two Rings dpmotley's Avatar
    Mar 04 2017
    Denmark
    Quote Originally Posted by OnionKnight View Post
    Sure they can :) Just lower your car and add spacers, so everything is flush or a little poking ;) I guess "aggressive wheels" means the wheels are as close to the fender a possible, with just a little gap enough to avoid rubbing.
    Your ride looks great, btw.
    2019 Nano Grey A3 35TFSI Sportback S-line, Black optics, Eibach Pro, ASS, Hill hold assist, 70/45 tintet windows
    My car Instagram
    My dog Instagram
  15. #1935
    Jul 02 2019
    chester
    Hi All
    Does anyone know or has put 20x9.5 et 35 on their S3 preferably a saloon. fancy the new ISPIRI FFP1, They only do 8.5j or 9.5j .no 9j unfortunately.
    Any help will be greatly received.
  16. #1936
    Feb 04 2019
    Quebec
    Thanks to all the great info in this thread!
    I went with 3SDM Style .01 19x9.5 Et40 with red center caps. I'm really happy with how it turned out. I had almost brand new 235 tires on the car so I've kept them but I'll step up to 245 when they are done... 0 rubbing but on stock height.
  17. #1937
    Mar 03 2019
    New England
    Rays Gram Lights 57DR 18x9.5 +38 Gun Blue 2 redrilled from 5x114.3 to 5x112 by FM wheels in California. Tires are 265/35/18.
  18. #1938
    Nov 13 2009
    the OC, SOCAL
    Quote Originally Posted by Spinnetti View Post
    034 springs, 034 camber plates. its a couple degrees negative camber and lots of room both sides. There is never rubbing under any conditions. I removed the spare and tools, but don't think that would change anything from a bump perspective. I'm actually running less than stock camber in the back (for better handling balance), and tires and wheels are square up.
    I spent a bunch of time with wheel/tire calculators tonight, and I already bought wheels in 18x9 ET30, and I'll run 265/35 up front, and 245/40 in the back. This is slightly smaller diameter than stock, and slightly bigger around in the back than the front (like RS3 staggered setup). This should be about ideal (given size choices available) for the gearing and F/R balance I'm shooting for.
    Attachment 98680
    Attachment 98681
    is this the wheels that are 18x9 et30?
  19. #1939
    Aug 06 2012
    san diego
    [QUOTE=OnionKnight;13736557]Can stock wheels be aggressive if they're painted?
    Depends on your definition of aggressive. A lot of people put expensive clown wheels on their car and consider it aggressive. Most of the time their cool new aggressive wheels actually weigh more and perform worse than oem- is that aggressive?
    Do what you like. But in my opinion “aggressive” has a very different meaning in this thread.
  20. #1940
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Quote Originally Posted by 949 View Post
    No, those are 18x8.5 ET35 with 255/40 (taller than stock) tires.
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
  21. #1941
    Dec 10 2004
    R8_LS400
    Dallas, TX
    [QUOTE=markn1689;13784061]
    In this context, "aggressive" simply means "will it fit" not "will it perform better". If everybody wanted performance, we'd all be running 17" wheels on slicks.
  22. #1942
    Mar 16 2017
    liang
    19 * 8.5 ET34 + Eibach pro kit
  23. #1943
    Dec 19 2014
    Virginia
    18x9.5 et 35 Cosmis racing
    18x9.5 et 35 Cosmis Racing Wheels 245 40 18
    16 s3 eurodyne stage 2 ecu/tcu
    Jb4 Methanol Intake exhaust
    2010 s4
    Epl stage 2 ,test pipes non res downpipes custom exhaust , intake , dual pulley setup torque monster .
    Gone:
    07 a3 , unitronics stage 2 , water meth .
  24. #1944
    Established Member Two Rings Dubstro's Avatar
    Jun 18 2019
    DFW
    Quote Originally Posted by Dudemans4 View Post
    I'm no expert but that engine bay pic doesn't look stage 2 to me!
    2016 Audi A3 Quattro Prem. S-Line
    2019 VW GSW 4motion S
  25. #1945
    Nov 13 2009
    the OC, SOCAL
    nice wheel setup. i like your stance the best also with the right wheel specs.
    is there a lot of poke? did you have to camber it a lot to get it under there?
  26. #1946
    Jun 26 2019
    North Carolina
    20x9 245/30r20
  27. #1947
    Nov 27 2018
    Vancouver
    Quote Originally Posted by PoonFlavordTang View Post
    20x9 245/30r20
    Very nice! Is that stock suspension or are you lowered? Also, can you provide the offsets for the wheels as I was looking to go 20's and like this setup. BTW, may I suggest wrapping the wing black, plastidipping the emblems black (or changing them out with black) and either taking off the chrome tip covers and having them powder coated black or changing the tips to black (this is what I just did on mine). That would compliment the black optics package even more and IMO make your car even more attractive than it is already.
  28. #1948
    Nov 27 2018
    Vancouver
    Quote Originally Posted by MikTip View Post
    Can someone explain why people post pics of their cars and have no center caps on their wheels?
    Thanks
    Which pic are you referring to?
  29. #1949
    Jun 26 2019
    North Carolina
    Quote Originally Posted by s3apr"d View Post
    I'm on stock suspension for now. That's the ext upgrade though. They are et36
  30. #1950
    Nov 27 2018
    Vancouver
    Excellent news as I am also on stock suspension. Now I can confidently start looking for similar specs knowing what the outcome will yield.
  31. #1951
    Established Member Two Rings Bayy613's Avatar
    Apr 20 2019
    Pittsburgh
    Just picked these up the other day, desperately need some springs.
  32. #1952
    Apr 20 2019
    Pittsburgh
    Didn’t read the entire thread and realized it’s for S3’s, my apologies!
  33. #1953
    Jun 18 2019
    DFW
    Quote Originally Posted by Bayy613 View Post
    I've looked through most of it and appears it evolved into all 8v. So you're good.
  34. #1954
    Veteran Member Three Rings XMetal's Avatar
    Nov 02 2017
    CA
    What am I missing?
    Thanks
    Some wheels (some Rays) don't support a center cap
    2018 Audi S3 Premium Plus
    Navarra Blue Metallic/Magma Red - Technology, Dynamic, S Sport, Black Optic, Resonator Delete, Unitronic Turbo Inlet, EQT Stage1 ECU/TCU
  35. #1955
    Jun 26 2019
    North Carolina
    Where in nc?
  36. #1956
    Dec 25 2004
    Earth
    Quote Originally Posted by XMetal View Post
    thanks
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
  37. #1957
    Veteran Member Four Rings ralphie_43's Avatar
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Could I get away with 18x9.5 et35 with 255/35 18?
  38. #1958
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Quote Originally Posted by ralphie_43 View Post
    Probably would be tight without camber changes both front and rear. I'm running 18x9 ET30 with 255 and there is plenty of room, but I have camber plates up front at -2.
  39. #1959
    Nov 13 2009
    the OC, SOCAL
    do you have any more photos of the stance?
    whats the camber measurements?
  40. #1960
    Mar 03 2019
    New England
    This is 18x9.5 et38 with 265/35/18’s
