Page 48 of 60 FirstFirst ... 38464748495058 ... LastLast
Results 1,881 to 1,920 of 2376
  1. #1881
    Nov 13 2009
    the OC, SOCAL
    Quote Originally Posted by dpmotley View Post
    Yeah, I know the reason to why they do it. They don't want to be sued for every speeding ticket. My question was if you increased the wheel circumference with bigger wheels, for instance 245/35/19 instead of 235/35/19 or 225/40/18, the speedo would show a speed closer to the real one. Does yours?
    i see. sorry i cant be more help with the actual wheel question you have. havent experienced this yet.
    i did once find the option in vcds to calibrate the speedo when the mnfg changes the wheel circumference. just cant change it. probably need the right security code or procedure. at times certain changes require some constraint to be met before changing an option. you can definitely find the option in there for wheel circum, they didnt hide it. as it makes sense when there are a few different options for wheels from the audi.
  2. #1882
    Jan 12 2015
    Columbus/OH
    Cool
    new summer wheelset...
    Advan Racing TC-4 18x8.5 et45
    Bridgestone Potenza RE760 Sport 255/40/r18
    12mm BFI spacers all around
    Tight fit super flush, no rub in front but some in the rear only when vehicle is forced downwards abruptly (going over large speed bumps faster than necessary). Will get some 10mm spacers for the rear this week and try again.
  3. #1883
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Quote Originally Posted by EROtero View Post
    That's odd- doesn't look flush, looks like the rims stick out an inch from the bodywork (not the tire). I'm running 18x9 ET30 with 255 and don't have that kind of poke. Didn't think my camber plates made that much difference. BTW, 255/40 is a taller tire than stock - was that on purpose? (I ran that same size before the current set as they were takeoffs from my bug)
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
  4. #1884
    Veteran Member Four Rings Grey3's Avatar
    Mar 14 2018
    B8 S4, mk6 Jetta, 2 mustangs
    Sherrills Ford NC
    That's alotta tire....love the wheels though
    Sent from my phone using Tapatalk
  5. #1885
    Veteran Member Four Rings ralphie_43's Avatar
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Quote Originally Posted by Spinnetti View Post
    +1 I ran 18x9 et30 245/40r18 on my 15 A3 Quattro and didn't have that kind of poke. Mine was very flush, I didn't run camber plates.20180128_112839.jpeg20180202_172025.jpeg
    Sent from my SM-G930V using Audizine mobile app
  6. #1886
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Vmr V810 19x9.5 et40, 245-35 R19.
    https://youtu.be/MOglyI9vVKg
    -cW
    Sent from my SM-G965U using Tapatalk
    2023 X3 M40i Alpine White
  7. #1887
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Quote Originally Posted by ralphie_43 View Post
    Ha.. running those same wheels on my S3 with 255/35. They are slightly smaller diameter than stock which helps acceleration.
  8. #1888
    Nov 13 2009
    the OC, SOCAL
    Quote Originally Posted by Grey3 View Post
    +1
    but he might have bad roads where he is at.
  9. #1889
    Jan 12 2015
    Columbus/OH
    Wheel is flush but tire sticks out about ⅛". I will have alignment done on Friday and the 10mm spacers are coming on Friday as well. I will take a picture of the car from behind to show the wheel flush soon and post it here.
    As for tire size, I really wanted 255/35 but the 255/40 were half price on clearance and I couldn't pass on that. Next tire change I am definitely going either 255/35 or 245/40 do not to rub at all.
  10. #1890
    Jan 12 2015
    Columbus/OH
    Quote Originally Posted by 949 View Post
    +1
    but he might have bad roads where is at.
    Columbus, OH... so yeah roads here are not the autobahn for sure, specially after winter season.
  11. #1891
    Nov 13 2009
    the OC, SOCAL
    can you post more photos from different angles. maybe even some with up close angles. very curious about the 18 inches
  12. #1892
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    I have this one I'll have to find my other sd card that has other. Cant take new ones as I no longer have that car 20180901_150707.jpeg
  13. #1893
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Will 18x9.5 et 35 255/35 fit on an s3 lowered on h&r super sport springs?
  14. #1894
    Dec 10 2004
    R8_LS400
    Dallas, TX
    It might, but I don't think I'd try it without camber plates up front. 9.5 is wider than optimal for 255 though.
  15. #1895
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    I was thinking 265 but i don't want it to not fit
  16. #1896
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Put on some camber plates (I'm using 034) and will be plenty of room for 265.. Pretty sure 275 will fit with room to spare on 9" ET30 which should be similar to 9.5 ET35
  17. #1897
    Jan 12 2015
    Columbus/OH
    Still with 12mm spacers and no alignment. We'll see after alignment if I go with the 10mm spacers or not.
  18. #1898
    Established Member Two Rings sub-zero's Avatar
    Jan 25 2016
    Cleveland, OH
    19x8.5 +40mm with 5mm spacer on rear. Pilot Sport 4S 235/35/19, ED Springs, No Mag Ride
  19. #1899
    Senior Member Two Rings unitzero's Avatar
    Nov 09 2011
    UK
    OEM
    SPEEDLINE / BBS
    19x9J ET32 225/35
    A little too aggressive for my low static set up here IMHO
    Bagged Daytona B9 Avant
    instagram :@_baz
  20. #1900
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Quote Originally Posted by Kookie View Post
    It is. Guess we'll see when I lower it. If they contact a tiny bit, I'll roll the stock ones until i find another wheel
    Did you ever experience any rubbing at all? Looking into a set of 18x9.5 et 35
  21. #1901
    Established Member Two Rings s3dro's Avatar
    Apr 30 2019
    Los Angeles, California
    Quote Originally Posted by sub-zero View Post
    Hooollllyyyyy shit, that looks good! Nice job!
    2015 Audi s3
    Injen Intake, Turbo inlet piping, Turbo outlet piping, Throttle body piping
    CTS Intercooler, CTS downpipe, CTS catback exhaust, APR Stage 2 tune
    Volk TE37 Bronze 19 x 8.5 +30 offset all around
    Nitto Motivo Tires 245/35/19
    TTRS Big Brake Kit, H&R Sport Springs
    RS3 Ignition Coils, RS7 Spark Plugs
    Carbon Fiber rear spoiler
  22. #1902
    Established Member Two Rings S23brian's Avatar
    Jun 20 2017
    San Francisco
    Quote Originally Posted by dcohen5 View Post
    Are those Yokohama AD08r's?
    Bridgestone RE71R
  23. #1903
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Quote Originally Posted by S3BURPS View Post
    No rub 19x9.5ET40 w/ 245/35/19.
    What springs?
  24. #1904
    Established Member Two Rings naudinate's Avatar
    Jan 28 2014
    Palm Bay, FL
    Just an A3, 18x9 et35 245/35/18
    Insta: @N8V_A3
  25. #1905
    Mar 14 2018
    Sherrills Ford NC
    Quote Originally Posted by naudinate View Post
    Nice wheels. What kind are they?
  26. #1906
    Jan 28 2014
    Palm Bay, FL
    Enkei PF01
    Insta: @N8V_A3
  27. #1907
    Jan 25 2016
    Cleveland, OH
    Quote Originally Posted by s3dro View Post
    Thanks! Just a bunch of subtle mods
  28. #1908
    Established Member Two Rings Hard-Knocks's Avatar
    Jan 04 2017
    Raleigh, North Carolina
    Switched out the OEM rims with BC Forged RS41s (19x8.5 ET 42). No spacers and on OEM mag ride. Tires are Michelin Pilot Sports 4S (235/35/19).
  29. #1909
    Nov 13 2009
    the OC, SOCAL
    can you take more photos from different angles. this is the closest to what im thinking of doing but with et25. so im very curious if the wheels look too small and do they pop out too much?
  30. #1910
    Jan 28 2014
    Palm Bay, FL
    Et25?! With what width of wheel?
    Insta: @N8V_A3
  31. #1911
    Nov 13 2009
    the OC, SOCAL
    thanks for the pics. im still doing a lot more researching for now.
    et25 was not my first choice as i would prefer to do et35 on a 9inch width which is about 0.40 inches movement. its not a huge difference but any amount will still help bring it back under the fender and be more compliant with daily driving.
    the wheel im looking into only has et49 or et25 (has a deeper look) for that deep concavity appearance. there are some tricks i know of that will bring that back into alignment but it can only go so far.
  32. #1912
    Jan 28 2014
    Palm Bay, FL
    It won’t fit! I am running -3° up front and -1° out back for track purposes. Et25 will Be way out of the fender. Unless you wanna look like those honda boys with massive camber.
    Insta: @N8V_A3
  33. #1913
    Nov 13 2009
    the OC, SOCAL
    that bad huh. dang. the front i can bring 1 inch but the back is gonna be harder to work on.
  34. #1914
    Jun 05 2019
    United States
    Hi!! I bought a new set of wheels for my 2016 A3 and wonders if a 19x8.5 et35 running on 245/35/19 tires set up would be safe with no rubbing; wants to be sure it’s good to go before I bring it in for powder coating. I don’t really want to roll or do any modifications. Just looking for that clean fitment with a little poke from the fenders. Also planning to lower the car as well. I have a few options but don’t know if I should go coilovers (if so what coilovers would you recommend for a reasonable price) or lowering springs (EMD, H&R, or Eibach). And would I rub if I lower the car?
  35. #1915
    Junior Member Two Rings Tap053's Avatar
    Feb 22 2019
    Pittsburgh, PA
    At stock ride height ('17 sedan) can I run 19x8.5+32 with 245/35r19s with no rubbing & no fender mods.?
  36. #1916
    Dec 19 2017
    So. Cal
    Quote Originally Posted by Tap053 View Post
    Yes.
    Sent from my LM-G710 using Tapatalk
  37. #1917
    Feb 22 2019
    Pittsburgh, PA
    Quote Originally Posted by stevwang View Post
    Yes.
    Thanks for the fast reply
  38. #1918
    Jan 24 2013
    Stock height yes. Be careful if you ever lower it tho. Depending on the tire brand and ride height it could rub.
    Email: [email protected]
    Call or Text: 914-243-1993
  39. #1919
    Feb 22 2019
    Pittsburgh, PA
    Quote Originally Posted by Paul@SupremePower View Post
    I'm between
    BBS CH-Rs @ 19x8.5+40
    TSW Nurburgrings @ 19x8.5+32
    Being that I'd like to run a 245 tire I want to make the safe play with the BBSs but I like the design and light weight of the TSWs; on the other hand I definitely see subtle lowering in my future so I'm thinking play it safe with the +40s and maybe throw some spacers in if I want them more aggressive...
  40. #1920
    Veteran Member Three Rings Chaoscreature's Avatar
    May 26 2018
    2018 A3 Quattro, 1995 Porsche 993 C2, 2006 Jetta TDI Special Edition, 1956 Willy CJ5
    Vista, CA
    I'm between
    The Nurburgring is a fantastic looking wheel IMO. If I had the budget, Nurburgring's in a 17x8 would be on my car already :)
