But Im looking at some of these and I don't understand the differences..
17"x7.5" ET35 CB57.1 5x112 Hyper Silver and1 7x7.5" ET35 66.6CB 5x112. Hyper Silver
I get that they're 17x7.5 ET 35 5x112.
But the Center Bore...57.1mm and 66.6mm...
Key Features:
17"x7.5" - Set of Four
Offset: 35mm
Center Bore: 66.6mm
Bolt Pattern: 5x112
Includes Four 66.6mm to 57.1mm Hub Centric Rings
Hyper Silver Finish
Concave Face
TPMS Compatible
Includes Center Caps
Requires Conical Seat Lug Bolts
Weight: 22 lbs Each
Offset: 35mm
Center Bore: 66.6mm
Bolt Pattern: 5x112
Hyper Silver Finish
Concave Face
TPMS Compatible
Weight: 22 lbs Each
The other says.
17x7.5" ET35 wheel size
66.6 center bore
5x112 bolt pattern
Split spoke mesh wheel with a concave face
Hyper Silver in color
TPMS compatible
Conical Seat Lug Bolts Required
22lbs weight per wheel
66.6 center bore
5x112 bolt pattern
TPMS compatible
Which would put me in these
http://www.ecstuning.com/Search/Site...349/ES2713031/
I want 18" but I already have a full spare set of 17" Tires I'm not using..
Question is too...Will these wheels even clear my B5 S4 brakes.
Appears as though maybe not.
Research also shows B6 A4 Sport wheels weigh 26-27lbs/ea and these are 22lbs... Not a big savings..
Anyone know what the VMR V710's weigh?
