Had a really weird thing happen tonight, I had backed my car out of the driveway this afternoon to get another car out of the garage. Then pulled my car back into the driveway. All seemed good.
I jumped in my car tonight and almost immediately the car started running really rough, making a terrible noise, like a whak, chug, chug, chug
It is obviously misfiring and the codes below support that so I was hoping it was just a bad coil, replaced all the coils with a spare set I have and tried starting it, again, the engine is running rough as before. No change with the new coils.
It seems to be much more of a violent misfire than when coils have failed in the past and it definitely made a very bad noise right after idling rough for a few seconds and right before throwing codes.
Thoughts? What's the process to check diagnose the misfires? Plugs are only about a month old. I'll pull them tomorrow to check but doubt it's plugs. Seem to have ruled out coils, what's next to check?
3 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 153918 km
Time Indication: 0
Freeze Frame:
RPM: 1560 /min
Load: 42.3 %
Speed: 0.0 km/h
Temperature: -7.0°C
Temperature: -8.0°C
Absolute Pres.: 860.0 mbar
Voltage: 14.351 V
000771 - Cylinder 3
P0303 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 153918 km
Time Indication: 0
Freeze Frame:
RPM: 880 /min
Load: 51.7 %
Speed: 0.0 km/h
Temperature: 0.0°C
Temperature: -8.0°C
Voltage: 13.970 V
000772 - Cylinder 4
P0304 - 001 - Misfire Detected
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 153918 km
Time Indication: 0
Freeze Frame:
RPM: 2573 /min
Load: 58.0 %
Speed: 0.0 km/h
Temperature: 3.0°C
Temperature: -8.0°C
Absolute Pres.: 850.0 mbar
Voltage: 13.970 V
Readiness: 0000 0000
