Results 1 to 28 of 28
    Jan 24 2010
    Paramus,NJ USA
    Question Aftermarket Rods?I beam vs H beam??
    So its a proven fact that I beam rods are superior in strength compared to H beam rods.Im just wondering if anyone here has tried RPM I beam rods??They are listed as lightweight but truth be told they are in fact heavier and stronger.All the builds I see,everyone is using h beam rods.Just looking to see if anyone is using RPM's I beam rods and how are they holding up.
    Ziddy Autowerks
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    When I poured over RPM's website I saw that the I-beams were not listed for the 2.7t but just about every other import platform.
    Unless they just added them recently.
    Jan 24 2010
    Paramus,NJ USA
    under sport compact they are listed under vw.
    VW 2.7L ULTRA-LIGHT I-BEAM ROD 6.063" B/E 2.269" 6PC/SET
    I would like to know if they are indeed lighter or not.Same dimensions as the h beam rods.I-beam rods are normally stronger than h beam rods but also heavier.This is why im wondering about these i-beam rods.I-beam rods in general are far superior to h-beam rods.I am wondering if anyoen has run these and is this indeed the case??
    Quote Originally Posted by landfill View Post
    Ziddy Autowerks
    Nov 14 2013
    From all the threads I've read on here the majority use their H-beam design.
    Hopefully someone else chimes in with the info your looking for. Also just FYI
    if you don't mind spending a little extra money IE just released their tuscan
    I-beam rods.
    Jan 24 2010
    Paramus,NJ USA
    Anyone?
    Ziddy Autowerks
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Id be more worried about the strength of the block than the strength of the rods.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Nov 10 2011
    Ontario
    ^^^ You'll never reach the limit of either rod before the engine block cracks, so it doesn't matter.
    Senior Member Three Rings haggard69er's Avatar
    May 20 2007
    Alligators
    pittsburgh
    Veteran Member Three Rings spd579's Avatar
    Jun 04 2012
    05 s2000, 2001 Mazda Miata with SR20deT(GT2871) swap, 1990 Mazda Miata(Tme attack(500whp))
    Charlotte, NC
    I have them, they are indeed lighter than the H beams, not sure about stronger but the 1.8t's put out 600 whp on these rods. that's 150 per rod so for us that would be 900.....don't think anyone here will push that limit..
    Active Member Four Rings martin0079's Avatar
    Mar 09 2011
    2001 Audi S4
    Plainfield, CT
    Quote Originally Posted by EuroxS4 View Post
    You have it backwards I beam rods are usually lighter than H beam.
    Nov 14 2013
    Yea I was wondering why he was saying I beam are heavier. They reduce weight from your rotating assembly.
    As far as the I vs. H beam I think the H-beams will outlast your motor from what I've seen on here.
    May 18 2012
    2005 S4
    Portland, OR
    The reason I-beams are lighter is simple physics. The I-beam design is far superior for resisting shearing and bending around the x-axis than an H-beam. It's why they use steel I-beams in construction but you don't see them being turned 90 degrees and used as H-beams. To achieve the same degree of strength in an H-beam, more material has to be used, resulting in higher weight. I'm really not sure why aftermarket companies are making H-beams unless it's simply an easier and less expensive shape to manufacture. However, the H-beams that are available for the 2.7T are all very strong. It just makes more sense to get an I-beam if you are willing to pay extra because it will be lighter for the same increase in strength (notice how OEM rods are all I-beams).
    Nov 14 2013
    From what I've seen you are correct. The H-beam design is considerably cheaper to manufacture. That's probably why they are still
    being mass produced.
    Veteran Member Four Rings PwrWgn's Avatar
    Sep 14 2013
    I think the real question here is wtf is Pauter smoking?
    Jan 24 2010
    Paramus,NJ USA
    Thanks for the input guys I do appreciate it.I have a BEL engine out of a a6 supposed to be stronger than apb.I believe the strongest is the diesel block from Europe.
    I believe the casting are different internally.but I think BEL should be enough for me.
    Ziddy Autowerks
    Jun 04 2012
    Charlotte, NC
    This guy^ didn't read the thread topic Posted about blocks in his rod thread.
    Mar 22 2013
    AK
    Quote Originally Posted by PwrWgn View Post
    American made with superb metallurgy and quality control ?
    Sep 14 2013
    Quote Originally Posted by Drehmoment View Post
    Easy killer. Wasn't a jab at Pauter. Just commenting on their unconventional design. Kind of like the topic of the thread, ya know?
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    So what is the consensus? The RPM I and H beam rods are essentially the same price.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Lake Lanier, GA
    What's the weight difference? Without balancing i'd probably stay with the H beams probably. If the I beams are significantly lighter then maybe they aren't worth it for just a rod swap.
    Mar 09 2011
    2001 Audi S4
    Plainfield, CT
    Quote Originally Posted by spd579 View Post
    Isn't that the op? I think he can change the topic of his thread whenever.
    Jun 04 2012
    Charlotte, NC
    I chose the I beams because they're lighter.....no one ever bends aftermarket rods so the lighter the better IMO and less rotating mass to crack my block.
    Jan 24 2010
    Paramus,NJ USA
    Agreed to me the lighter the better if they are stronger that's just another reason to get them.The price isn't a whole lot more so why not.
    Ziddy Autowerks
    Dec 10 2011
    CLT | MKE
    That's my thinking, I just hadn't seen anyone running the RPM I-Beams which is why I was curious.
    -Hayden
    Jan 24 2010
    Paramus,NJ USA
    Quote Originally Posted by LINDW4LL View Post
    Same here.
    Ziddy Autowerks
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    Can anyone answer what the actual weight difference is between the RPM I vs H? Sorry for the bump, but it's the right place for it.
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    Aug 23 2016
    richmond VA
    I got RPM ultra light I beams they not installed yet !
    They 60 gramm lighter (per rod ) then OEM 2.7 rod
    They weight 525+_ 1 g with Arp bolts
    Apr 20 2005
    New Hartford, IA
    Excellent, thanks for the info.
