Results 1 to 21 of 21
    Sep 11 2014
    Australia
    Your Fuel Consumption for the A5 Coupe 2.0t Quattro
    Me personally i get around 12-13l/100km(19.602-18.094 mpg) combined. Is this normal? Sometimes i like to floor the car but normally i just go 2-3k revs and it changes gears. Online it says it should get around 7.6l/100km(30.95mpg) which is way off to what i get. What about you guys?
    Aug 04 2010
    Queenz/Westchester
    Depends on what your combined driving is. If mostly city then expect a lower combined MPG. If more highway then expect higher. In my A5 I used to get anywhere from 18-26mpg combined depending on if I was stuck in City traffic or driving in the suburbs. The combined 30mpg is unrealistic unless you were driving CVT with mild acceleration and never going above 65mph. I used to get 32-33 highway only when traveling steadily at 80mph. the best I got was 36 when driving at a steady 60mph on highway only.
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    That sounds about right and where my consumption is also. Your mpg will take a hit also if you have more ethanol in the mix. Most places by me show 10% mixed in.
    -cW
    2023 X3 M40i Alpine White
    Sep 11 2014
    Australia
    well i live in a residential area where there are alot of traffic lights and speed bumps so that affects it also, on highway i get around 30mpg as well, depends how fast i am going
    in aus i put in 98 oct so i dont know how much ethanol that has
    May 04 2010
    Palo Alto, CA.
    Honestly, my record was 41 MPG... but that was coming out of Tahoe... it was cold and slight down-hill... but it did sustain for quite some time (I truly should have taken a photo as no one believes it's possible).
    The mileage I get varies on the fuel map setting I use. If I use 91, I get in the mid-30's... but if I use the 100, I get in the mid-20's.
    For completeness, I have a manual and also an HFC (which really helps).
    As noted by dejangcool, if you're using E85 or a higher ethanol blend... you can expect your mileage to be in the mid-20's.
    Additionally, if you're driving in a warmer climate, you can expect mileage to drop.
    Lastly, mileage is a reflection of the weight you're hauling around so... ditch that spare and anything else you might have loitering in the trunk.
    Sep 11 2014
    Australia
    how much ethanol does 98 octane have? the highest mpg i got was 35 cruising on the highaway at like 1.5k revs in 7th gear, but normally i cant do that as im driving over speed bumps ,traffic lights etc
    Senior Member Three Rings jrabakker's Avatar
    Feb 27 2014
    Quote Originally Posted by dejangcool View Post
    No idea if it is normal, but in my opinion that's pretty bad for a 2.0. My 3.0 supercharged S5 has an average of 18.9mpg over 12,700miles (independently calculated by fuel amounts bought, divided by mileage). And I drive with a pretty heavy foot.....
    2014 S5 | Premium Plus | Estoril Blue | Black Napa Interior | Sports Diff | Adaptive Damping | Side Assist | Supercharged badges | HR OE springs | 10/15 mm spacers fwd/aft | APR stage 2 | AG M510 - 20x10 - 275/30/20 |
    1st Car | 1988 80 B4 | Blue
    2nd Car | 1998 A3 1.8T | Sport Green
    Sep 11 2014
    Australia
    maybe ive got some problem with my engine, it does 0-62mpg in 7.7 seconds.. best time ive got, yet it claims 6.5
    Sep 11 2014
    Australia
    plus it uses 1l of oil every 700km or so
    Jan 07 2011
    2013 C300 4Matic
    its normal considering you live in a residential area
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Sep 11 2014
    Australia
    pre stupid that they claim 37mpg combined.... im surpised a 2l turbo can use this much fuel anyway, how does the 3.2 compare?
    Nov 10 2014
    Apex, NC
    30 - 35 mpg
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Quote Originally Posted by jrabakker View Post
    I noticed that my S4/A4/A5 all had about similar MPG even though one was a V6.
    So I'd say it has more to do with your driving style and the local roads/fuel than just the engine.
    -cW
    Veteran Member Three Rings Nastybutler's Avatar
    Apr 07 2014
    2010 C6 A6 (Wife's); 2012 Triumph Street Triple R (Phantom Black)
    United States
    I went from around 20 mpg to 24 mpg (all city driving) by installing a test pipe and stage 2 tune. This is as measured by the ECU, not actual mpgs. Of course I'm on 90 octane with no ethanol and my average ambient temps have also dropped to the mid 20s, so that helps as well. I'll have to see what I get in the summer when temps go up and my gas peddle is depressed to the floor for short bursts on a regular basis.
    For Sale: 2014 A5 2.0T (Scuba Blue) | APR Stage 2 v2.0 | 8spd Tiptronic | MMI 3G+ w/Nav | Advanced Key | B&O (w/ upgraded sub) | park assist | heated memory seats & mirrors |
    1/4 Mile: 13.39 @ 100.74 mph on fake 93 octane (90 + Lucas booster)
    Mods can be found in my Build Thread
    Senior Member Three Rings laurenfrotch's Avatar
    Sep 02 2014
    Edmonton, Alberta
    My 2.0T 6MT in the city I average 10L/100km. When I really give it a bit 12-14l/100km.
    took highway once, uphill-ish for 300km, I was at 7.5L/100km and on the way back (downhill ish) it was at 6.8L/100km ish.
    Since then I've been sitting at 9.1L/100km.
    2010 Meteor Grey A5 S-Line 6MT #TeamUprising
    twitter @laurenfrotch instagram @laurenfrotchh
    Jul 25 2011
    Now is the time for a v8 considering the gas prices!
    Feb 27 2014
    -cW
    Well if the mpg's are the same, I'll have the V6 please!
    Sep 11 2014
    Australia
    Quote Originally Posted by laurenfrotch View Post
    yeah thats me as well, if i dont go over 2k revs i can manage 10l, but im not that picky that i have to press the throttle like 5% especially at 1st gear so i get good mpg
    Nov 19 2012
    Irvine, CA
    so like on my 14' A5 with E85 im getting like 16-18 MPG o_o But I drive pretty hard as in BRAKE AND GO.... LOL
    Current Vehicle:
    2013 Audi RS5
    Daytona Grey | Carbon Ceramic Brakes | Bilstein PSS10 Coilover | Custom Sport Exhaust | Eurocode Sway Bars Eurocode End Links | LYKT Sport Control Arms
    Sponsors: Bilstein US | Eurocode
    Past Vehicle:
    2014 Audi A5 S-Line Ibis White
    2008 Audi TT V6 Ibis White
    Veteran Member Four Rings fasteddy91's Avatar
    Jan 04 2013
    1991 Toyota MR2 Turbo
    Concord CA
    I get around 21 mpg with 80% city driving. Im really easy on the throttle with very little WOT opportunities. I do live around hills and I think that kills my gas mileage. I just got an APR stage 1 flash...we'll see what happens with my gas mileage shortly.
    2014 Misano red A5. S line Competition Package 6spd manual.
    2015 Brilliant Red R8 V8 6 spd manual.
    Active Member One Ring jwhite0254's Avatar
    Nov 02 2013
    Long Island
    When I commute to my job I get about 28-32 mpg but that's strictly highway. Around town I get about 22mpg. 2010 A5 2.0t
