Results 1 to 40 of 40
    Veteran Member Three Rings Markie93's Avatar
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    Adding Bluetooth audio(preferred) or aux in to 2G MMI in 05 A6 C6
    Hey Guys,
    I have a 2005 Audi A6 with bluetooth for the phone but not audio streaming.
    I have been doing some research to see what options are out there to add bluetooth streaming, or an aux in if bluetooth streaming doesn't work well.
    I'm looking for something:
    - to be able to play Pandora over the Bose sound system with good sound quality
    - not outrageously expensive (under $100),
    - and easy/quick to install (I don't want to splice into factory wiring)
    Does anyone have any new suggestions? I would be willing to delete the CD changer to get bluetooth or aux but wondering if anyone had suggestions of brands or methods.
    Thanks,
    Jake
    Senior Member Three Rings skylinrcr01's Avatar
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    I have heavily reserarched this. You have 2 options.
    - FISCON bluetooth system
    - AMI with ipod cable and TUNE2AIR module.
    Fiscon integrates with what you have in your MOST loop currently, and is a module that you are adding. It's around $450 http://www.fiscon-mobile.eu/products/pro_mmi_lwl.php
    AMI is audi's solution and new was outrageously expensive. Good news though, becuase you can pull one from an a6 or a8 with mmi 2g. The part number is 4E0 035 785 X (X is any revision number). This website helps a lot. http://a6retrofit.com/ami-retrofit-a...sic-interface/
    The ipod cable can be fitted with this http://www.amazon.com/ViseeO-Tune2ai.../dp/B00B52LLJ6, which will allow A2DP streaming. Hope this helped.
    Tyler
    http://i.imgur.com/KPi8p89.jpg
    2004 Mercedes E55 AMG
    2005 A6 Quattro 3.2 (Sold)
    2005 BMW K1200S
    Feb 06 2013
    CA
    There is another option: Dension 500 in combination with a tune2air A2DP
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    I have an android phone. Not an iPhone. Do you think it'll still work with an android??
    Feb 06 2013
    CA
    I have a windows phone and Android and it works fine for both
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    Oh duh, Denison not fiscon. My bad.
    2005 BMW K1200S
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    skylinrcr01, I must have missed your post from earlier. Thank you for the responce. I will check those out.
    Also, I just saw on ebay you have a satellite radio receiver on there. Me too! small world
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    So to me, the Dension options seems a bit to pricy at $400+. The AMI looks to be cheaper and more factory looking if I am correct.
    Please let me know if I am reading this correctly:
    If I do the AMI option, the AMI is basically a box that take place of the CD changer from the wiring to the physical location of the CD changer, correct? By installing the AMI box, this allows me to directly plug in an ipod of some sort. But I would need the "Tune2air" box that basically plugs into the ipod connection and make it bluetooth capable, allowing it to work with my android device? and by using AMI, if I had an actual Ipod, would I be able to control it through the Factory MMI?
    The A6 Retrofit website was very helpful but just want to make sure I understand what i am getting myself into.
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    Yea, that's pretty spot on. The only advice I would give is that you don't need to remove the whole glove box. There is a panel twords the back of the passenger foot well to get to the cabin filters, and you can access the MOST connector and the power line from there. Also buy the changer removal tools, I really mangaled my changer getting it out of there.
    AMI is the route I took as well, can't go wrong with factory! Make sure you get the correct AMI, there is one that will only fit the a4 and a3, they are way cheaper but use a different data transmission method and won't work on our cars.
    Tyler
    2005 BMW K1200S
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    I came across this as well, looks like it does the same thing as tune2air, just cheaper.
    http://www.amazon.com/gp/product/B00...f_rd_i=desktop
    2005 BMW K1200S
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    That is awesome :)
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    Any idea which AMI will work on our A6's? I've been looking on amazon. Should I be shopping somewhere else?
    Established Member Two Rings -A6-'s Avatar
    Feb 03 2014
    Woodland Hills CA
    Quote Originally Posted by Markie93 View Post
    Plus one this
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    4E0 035 785 X is the part number you need (where X is the revision letter), you are going to have the best luck on eBay. If you are patient, you should be able to snag one for ~$200. It needs to be the one with the MOST connection on the back (optical).
    So this one would work. Although it is a bit expensive. And he/she didn't cover the connectors which are optical, so if dust gets in there it can ruin them.
    http://www.ebay.com/itm/2007-2008-20...21b3bc&vxp=mtr
    2005 BMW K1200S
    Feb 03 2014
    Woodland Hills CA
    thank you! I was looking at that one but I dont want to spend that much on it lol and good info on the connectors ill watch for that.
    Senior Member Three Rings A4DK's Avatar
    May 13 2009
    Larkspur, CA
    Bought this and it works with Android.
    http://a2dp4audi.netmagi.com/
    Sometimes it does seem like it doesnt power back on if you turn off the car for a few minutes. Going to reach out the vendor and ask.
    The only way to get rid of a temptation is to yield to it. - Oscar Wilde
    2019 Q8 Prestige - Year 1 - Adaptive Chassis - Luxury - Navarra Blue
    Gone but not forgotten.
    2011 A6 3.0T - Prestige - S-line - Sport
    2011 S5 6MT - Prestige - Sports diff - Brilliant Red
    2009 A4 2.0TQ - P+ - Sport - Aruba Blue
    2002 A4 1.8T - Executive - Brilliant Black
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    Quote Originally Posted by -A6- View Post
    No worries. It took me around 2 months to find one for the right price, lol. It's a good idea to set up an eBay search alert on keywords like AMI a6 or a8.
    2005 BMW K1200S
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    Sweet. Thank you guys for your responces.
    When I was asking about the right AMI, I was actually refereing to the cord. I managed to pick one up on ebay (Just the metal thing, no plastic) for $185, which I though was decent.
    I might buy both bluetooth options (tune2air and the little dongle) but want to make sure I get a good enough cord. would have to go through all this trouble just to have the cord be the issue. Anyone have good suggestions on cords?
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    This was the AMI receiver that I purchased for $185
    http://www.ebay.com/itm/261659866109...%3AMEBIDX%3AIT
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    I've never seen one without the housing, I hope you can find the cable that goes into the side of it, because it doesn't look like the standard AMI cable.
    2005 BMW K1200S
    Feb 03 2014
    Woodland Hills CA
    So i found one with Same part number but a letter B at end instead of X would that work still? Its pulled from a 08 a5 n is just missing sliding part of tray
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    The X is just a variable standing in for the revision letter. Mine is an F. You need the tray enclosure though, as it has a cable adapter thing. The sliding part shouldn't matter though.
    2005 BMW K1200S
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    So, I bought it and hooked it up, plug and play.
    Only problem is, is just displays this:
    Do I need to enable anything in the hidden menu? Do I need to update my software or anything?
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    Is anything plugged into it? Or did you just throw the box in there?
    2005 BMW K1200S
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    Haha I plugged in the most cable (optical cable) and he other power cable (like 4-5).
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    Do I need to update my software to include the AMI?
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    If you are on the most current version, then no. Try plugging a flash drive formatted in FAT32 into it, I think it's 'initializing' because it has no input.
    2005 BMW K1200S
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    I may not be on the most current version, haven't had much luck trying to update it.
    I had the tune2air think plugged into my AMI and had my phone connected to it
    Junior Member Two Rings Alphapenguin's Avatar
    Mar 09 2004
    SAT/SEA
    Forget old school hard wire AMI and go wireless for streaming music from your iPhone
    There is absolutely no need for a hard wire AMI connection. My 2011 A6 Avant Prestige has Bose Surround Sound. It has a radio. I plug my Gogroove FlexSmart X2 bluetooth receiver/FM transmitter into a 12v outlet (cigar lighter) link it via bluetooth to my iPhone 6Plus (which is also linked by bluetooth to the Audi MMI for phone conversations), locate an unused FM frequency to which the FlexSmart can transmit, and I can stream through the radio from my iPhone any online content I choose, e.g., internet radio, Pandora, Apple Radio, my iPhone music library etc. The sound is stunningly clear, as good as a hard wired connection. Why complicate the issue when you can buy my FlexSmart for $50 on Amazon, or pay more for a newer, but no better, version of the FlexSmart? Added bonus, the FlexSmart has a USB port that will enable one to charge the iPhone battery, and I can easily move it from one car to any of my others.
    2011 CPO A6 Avant 3.0T Prestige Quattro 4F55VL Oyster Gray Metallic, Amaretto/Black leather 67K miles
    2012 CPO MB E350 Sport Sedan Palladium Grey, grey leather 48K miles
    2006 BMW Z4M Roadster Interlagos Blue, black leather/carbon fibre, 18" Gunmetal CSL wheels 28K miles
    1969 MGB Roadster Pale Primrose
    1973 MGB-GT V8 conversion Jaguar Opalescent Dark Green
    1969 MGC-GT Downton-style conversion Mineral Blue
    Feb 03 2014
    Woodland Hills CA
    Quote Originally Posted by Alphapenguin View Post
    Ill have to try this! sounds too easy though lol why are more people not using it? how is the quality does it cut in and out or is it HD? thanks! I almost bought one from walmart the other day but couldn't find any reviews
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    In the past I have had no luck with FM transmitters. They usually have crappy quality, and yoy can't control them from the Audi MMI.
    I am still wondering what I should do to get the AMI working. Not sure if its a software thing or a hardware thing.
    Going to try to update the software and see if that does anything.
    Mar 09 2004
    SAT/SEA
    I didn't believe it until I tried it. I took a chance on it after reading user reviews on Amazon. The reason I tried it was because my BMW dealer wanted hundreds of dollars to retrofit an AUX connection in my roadster. When I next took it in for service with the flexsmart booming tunes from my iPhone my service advisor was blown away. I can speak only of the gogroove flexsmart x2. A newer model, the x3, is available but I'm happy with my x2. Read the reviews on amazon. I think you'll be surprised at the quality of the sound. It's near enough to cd quality that you'll be hard pressed to detect any difference at all.
    Senior Member Two Rings jmswashere's Avatar
    Jun 27 2013
    St. Augustine, FL
    I have the Viseo TUNE2AIR in my 08 S6 and I love it. There is not a noticeable difference in the sound.
    Current: 2023 Audi RS6 Avant - Daytona Grey; CCBs; Carbon Optics; AWE Exhaust; OEM RS6-P Bronze Wheels; APR Intake
    RIP: 2020 Ford Mustang Shelby GT350; 2017 SRT Jeep Grand Cherokee; 2014 Audi S4; 2015 Dodge Charger SRT 392; 2008 Audi S6; 2006 Nissan 350Z
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    Hmm, interesting. I'll botton the software update for the MMI. I'm going to try and update that tomorrow, and if that doesn't fix the problem. I'll probably end up selling everything I have and going with the FM transmitter on Amazon. Thanks for your review on that!
    I have the tune to air module but just have to get the AMI module working first
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    Hey Guys,
    Just an update. I was able to get it working!! I ordered a Software update kit from ebay and it seems to have fixed the issue. Audio quality is great from the TUNE2AIR Module.
    Thanks again for all your help!
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    Glad to hear man. What sort of iPod cable did you get? A generic one?
    2005 BMW K1200S
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    Well, as you may remember, I bought two AMI units. I bought a cable on Amazon and that worked great with virsion F, but did not work with version B. Here is the link, it had mixed reviews on amazon but most people were having issues when using it on an A5 or Q7. Plus it was only 12 bucks.
    http://www.amazon.com/gp/aw/d/B004XAZNAU
    Fortunately, Version B came with a cord that workers perfect (4F0 051 510 E).
    I ended up keeping version B since this one had the plastic housing. I currently have Version F for sale in the audizine classifieds including the brand new cable.
    Veteran Member Four Rings Quattrocentric's Avatar
    Oct 19 2013
    Another Audi, what else?
    Silver Spring, Md
    Hey markie93, I saw where you put the AMI module up for sale...how come? Are you going with the gogroove?
    Edit: okay, just read the post above.
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    Cool, thanks. I'll have to check which revision I have, I think mine is later.
    2005 BMW K1200S
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    Yeah I bought two of them. I thought I got a good deal on the first one, then found an even better deal on the second one. So I am selling the one I didn't use.
    Here is a chart I found, not sure how much I trust it though. FOund it on eBay:
    You can check you revision this way (Figured it out while doing the software update). If you press and hold the "setup" and "return" buttons at the same time fro 3-5 seconds, you'll get a different menu. In that menu you can click "AMI" and it will tell you the part number with the version as the last letter.
    Hope this helps
