About a year ago or so when I was reading about oils, I noticed a couple of oil brands sporting titanium as anti wear additive in lieu of ZZDP. These oil came with excellent wear characteristic but the price at that time was pretty crazy for an oil change so I just poured Rotella T6 in.
I was browsing local walmart yesterday for my wife's oil change (nissan, so I didn't really care what to put into that) and I noticed new line of Castrol Edge oil with Titanium additive in them. What was pretty surprising was that they also had VW 502 and VW505 approved 0W40 with Titanium in 0w40 weight as well... That came as a shocker as I remember absence of VW approved oils up until recently.
That perked my interest so I went back home and did some searching on oils... which returned quite hair rising results regarding Rotella T6 oil... Couple of hours of reading material here:
MOTOR OIL “WEAR PROTECTION” RANKING LIST | 540RAT - Tech Facts, NOT Myths
Bottom line is he measured a lot of common oils at 230F and dynamic load until the metal surfaces meet. Result is a ranking list of oils arranged by decreasing number of PSIs it took to cause scarring on metal surfaces. Essentially it measures force needed to break the oil film and cause wear on engine.
Highest measured common oil was 5W30 Mobil 1 synthetic at 105,875 psi (position number 10, there are better oils or combos but hard or expensive to get). Rotella T6 ranked #114, 5W40 SHELL ROTELLA T6 Diesel Oil synthetic at 67,804 psi...
Interestingly enough, Castrol Syntec 0w30 aka "German Castrol" we all love tested similarly at 69,302 psi, Mobil 1 0w40 Synthetic Euro at 82,644 - to give you reference point.
Bottom line is Rotella has inferior protection against wear but so does GC... maybe it was top notch a while ago but new formulations far exceed them today.
I couldn't find the Castrol Edge 0w40 with titanium in the list (it is made in Germany BTW, they list older formulation of 0w40 without Titanium and that one was made in Belgium), but couple other variants tested far above Rotella, so I dumped Rotella for Edge last night.
Discuss...
