These are ready for a direct install. OEM S-Line sport suspension off a 2011 Audi A3 TDI with 50mm H&R lowering springs installed (no stock S-Line springs included). Shocks and struts have 40k commuter miles on them; H&R springs were installed by me at 35k (they have 5k miles on them). Everything is in excellent condition and I've cleaned up as much as I could before packing them up. The springs are progressive and the ride is as comfortable as stock, with a slight increase in stiffness/rebound (barely differentiable from the stock S-Line setup with 18" wheels on). A perfect drop that looks great but allows you to maintain an ease of mind, in my opinion.
I'm including 2 sets of rear spring pads; 1 set from an Audi TT (which I've used), and 1 brand new set for an Audi A3. The Audi TT pads are slightly thicker than the A3 pads, which raises the rear end just slightly. A few people comment about how the H&R springs have the slight appearance of negative rake (50mm drop all around), so the TT pads help in evening that out a little (50mm drop front/45mm drop rear).
I'm not 100% certain, but these should fit VW MK5/MK6 platforms as well. Please ensure that these will fit your vehicle properly because I will not be honoring returns. All relevant part numbers can be seen in the photos. Feel free to ask any and all questions before purchasing. Thanks!
List Date: 12/6/2014
For more info, click here to view the original listing: OEM Audi A3 8P S-Line Sport Suspension, 50mm H&R Lowering Springs
This item is no longer available.
