    Veteran Member Three Rings Let it snow's Avatar
    Aug 24 2014
    02 1.8TQ Sport 5 speed, 05 1.8TQ 6 speed
    Vermont
    Defrost on = Poor radio reception
    Hello all. I have had this problem for a while now. I searched but could find no answer. As stated When i turn on the rear defroster, the radio reception turns to static. Usually the radio reception is Okay. I do have the infamous cracked amplifier board. I followed the ionicswing DIY hoping this would help. Unfortunately it did not. Like I said radio reception is usually fine even before i did the DIY. Just wondering if it has happened to anyone else. 02 sedan with stock radio. Thanks.
    DIY that I followed http://www.audizine.com/forum/showth...-Fob-Reception
    Senior Member Two Rings Jokergod2000's Avatar
    Apr 18 2010
    Calgary, AB
    I had the same thing on my 2005.5 S4. It was a minor annoyance so I did not try to solve it.
    2015 Audi RS7, Sepang Blue, Carbon Optic Package, Performance Package, Driver Assistant Plus Package, Black Alcantara Headliner
    2015 Audi A3, Glut Orange, 2.0 TFSI Technik, S Line Package - Wife's
    2006 Audi S4, Sprint Blue Pearl, 6 Speed Manual Transmission, Navigation - SOLD
    Veteran Member Four Rings FromS60toB61.8t's Avatar
    Aug 26 2007
    07 Fahrenheit GTi, 09 S8, 17 GSW S 4-Motion, 19 S4 Black Optics
    i have the same issue, but my tab that the cable connects to the amplifier is snapped off of the board. im guessing that's my problem, since im guessing thats a ground.
    that would be my best guess is a bad ground somewhere.
    to clarify the one wire that connects to the flat connector not the circle connectors
    19' Glacier S4 Black Optics
    Aug 24 2014
    Vermont
    I never thought about the ground. I will clean the grounding point and connection and see how it goes. Thanks for the info.
    Veteran Member Four Rings drjonez's Avatar
    Oct 27 2009
    2011 Q7 TDI Prestige, '72 Nova
    The Cheese State
    Broadband noise generated by the blower motor is wiping out your radio reception. Chasing bad grounds is the best place to start.
    '11 Q7 TDI Prestige
    Function > Form
