Page 1 of 3 123 LastLast
Results 1 to 40 of 101
    Senior Member Three Rings sh!tmagnet's Avatar
    Apr 22 2014
    Kelowna
    Start/Stop Button "Press Clutch to Start Engine" Problem
    I swear, cars know when they've just gone out of warranty.
    Anyway, I searched around and can't seem to find a definite answer.
    So a couple days ago after driving back from a weekend away of drunken debauchery, I hopped in my car(PS its a 2011 S4), put the clutch in and hit the start button; needles swept but engine didn't crank. Tired a few times and finally started.
    Since then it's been doing it intermittently. It also displays the "Press clutch to start engine". So I've been making sure the clutch pedal is right to the floor(I swear if it went any lower it'd go through the firewall).
    From my searching I've heard everything from something tied in with the cruise control, to master/slave cylinder, to throw out bearing.
    I have a VCDS cable, but it's out on loan with a buddy, so I can't scan for codes yet(no CEL bwt).
    Has anyone else had this issue, and nailed down what is the cause?
    Thanks for the help.
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    my guess is your clutch pedal switch is going bad. Its not going to give an error code most likely. Your going to have to get in there and watch the data group its on and see if it changes when you put the clutch pedal in. If it doesn't change or is slow to change or only changes when you push the pedal all the way to the floor then its bad. Id put my money on that switch. Should be an easy replacement
    Apr 22 2014
    Kelowna
    Is the switch on or near the pedal or is it on the transmission? I don't have the Bentley manual yet.
    Oct 14 2012
    Empty...for now...
    SE PA
    My first thought is that it's the switch (or sensor I suppose) that detects the clutch pedal position as permissive to start the engine. I've never actually looked for it on the S4, although in my other car it's actually a plunger-style switch that the pedal arm depresses when the clutch pedal is pressed down.
    SOLD 2015 Daytona Gray S4
    Apr 22 2014
    Kelowna
    That was my thought but I read somewhere that on some model (maybe b7 or b6?) Its on the transmission
    Jan 14 2009
    pasadena md
    The clutch pedal switch should be on the pedal either you release it when you push it so its on the front side of the pedal. Or it depresses as you press the clutch pedal so its behind the pedal. I can check my manual later tonight and find it. It should be on the pedal. Just craw up under the pedal area with a flashlight and look around the pedal and brackets near the pedal and see what you can find. Should be a little box with a plunger
    Junior Member Two Rings
    Jul 10 2013
    Memphis, TN
    The clutch switch is mated to the clutch master cylinder
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by jrt03 View Post
    Oof. That's a shitty move by Audi.
    Apr 22 2014
    Kelowna
    So as in all one unit or a separate switch that plugs into the master cylinder?
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    Quote Originally Posted by sh!tmagnet View Post
    its separate, but a pita to get to, you need to remove the ecu box to get to it.
    i have a similar problem, where i need to press the clutch into the floor to get the car started, from what ive read its not the switch, but the clutch going out.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Jan 14 2009
    pasadena md
    Quote Originally Posted by infinkc View Post
    well i don't know the type of switch it is you can try unpluging it and see if it starts. If it doesn't then try jumping the harness and if it starts then its a normally open switch. which needs to be closed to start. You can leave it jumped for the time being but you have to make sure you leave the car in neutral or else it will lunge when you try to start it.
    Veteran Member Four Rings littleredwagen's Avatar
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    I had this on a past Audi and it was the starter, it would take a couple of times to get the starter to crank. This was on a 3.2 FYI
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    2011 S4 Prestige 6mt Black
    2001.5 S4 EPL Stage 3 Yellow
    2005 S4 Avant 6spd Red
    Apr 22 2014
    Kelowna
    Bump
    Veteran Member Four Rings Leor604's Avatar
    May 25 2010
    Vancouver
    Can't say for sure what your problem is but, in my case, when I had the same problem they replaced the throw out bearing and the clutch fork (under warranty). My clutch pedal was always a little "gritty" feeling for the last inch of travel. They did the clutch pedal lube TSB but it didn't help so I am not sure that my throw out bearing wasn't a bad one right from day one. Smooth as butter since it was replaced and no longer need to bend the firewall to start the engine.
    Apr 22 2014
    Kelowna
    In the pictures I've seen of the master cylinder(ECS tuning) there's a electrical plug connection. Would that be where that sensor would plug into?
    Veteran Member Three Rings Legacykid's Avatar
    Mar 05 2010
    ATL
    I had this issue years back went to 2 dealerships 3 times. one of which was towed. Finally they changed the whole master cylinder and the issue went away completely. I could double check the paper work for exactly what it was.
    Apr 22 2014
    Kelowna
    If you could that would be great. I was gonna go the master cylinder route first anyway as it's easier and cheaper than doing the clutch (not that that wouldn't have been a good excuse to get a stage III from eurocode)
    Mar 05 2010
    ATL
    ok so first the system was bled. then they replaced clutch master cylinder replaced.
    then months later removed clutch fork replaced with updated clutch fork. also replaced beering and sleeve.
    says there is actually a TSB as well
    Apr 22 2014
    Kelowna
    Quote Originally Posted by Legacykid View Post
    Huh good to know. I'll have to ask them about the TSB. Pretty sure they said there wasn't any outstanding TSB last time I was in.
    Mar 05 2010
    ATL
    Mind you this was in Feb 2012 then April 2012. So maybe things have changed but I had this exact issue. One of the 3 times I was at the dealer had to be towed.
    Apr 22 2014
    Kelowna
    What year is your S4?
    Mar 05 2010
    ATL
    2011
    Jul 10 2013
    Memphis, TN
    We just had a car with the same issue in the shop. Same exact message and a no start concern. Ended up being two things. The clutch and the starter. The clutch was the real concern and the starter was a consiquencal failure due to the issue prior to the total failure of the clutch. I would be willing to say your issue is the clutch. Does the clutch pedal feel normal?
    Apr 22 2014
    Kelowna
    Clutch feels fine, no chatter. Engages and disengages fine. But thanks for the input, I think I'm going to be picking up a Euro code clutch/flywheel kit anyway.
    Veteran Member Four Rings xuandatou's Avatar
    Oct 17 2012
    NoCal
    Guess it would be clutch switch, similar issue happened to my B5 S4, and after I replaced the switch, it never happens again.
    Veteran Member Three Rings tanklee's Avatar
    Dec 31 2004
    NJ / Miami
    are you able to scan the car? i did a bunch of clutch switches on 4.2 S5s and it had a fault (common issue), but haven't done it on the newer 3.0s.
    2000 B5 A4 Quattro
    2000 B5 S4 6spd Stage 3
    2014 B8.5 S4 DSG
    2005 B6 A4 Quattro USP
    Apr 22 2014
    Kelowna
    I have the cable but its out on loan with a buddy at the moment. I can't seem to find the switch listed as a part anywhere.
    Veteran Member Three Rings chuthis's Avatar
    Nov 30 2012
    socal
    It sounds like there isn't a definitive answer to this issue. I've had it happen to me off and on for the past year. When it first started happening, I brought it into the dealer but of course they couldn't replicate the issue.
    Does anybody have the TSB# that was mentioned earlier in this thread?
    10' S4 | 14' SQ5
    Apr 22 2014
    Kelowna
    Finally got my cable back and ran a scan.
    Chassis Type: FL (8T0)
    Scan: 01 03 05 08 09 10 15 16 17 19 22 36 42 46 47 52 53 55 56 5F
    62 6C 72
    VIN: WAUMGBFL2BA052170 Mileage: 81450km/50610miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (J623-CCBA) Labels: 06E-907-551-CAK.clb
    Part No SW: 8K0 907 551 D HW: 8K0 907 551 A
    Component: 3.0T SIMOS84 H07 0003
    Revision: --H07---
    Coding: 0104000A180F0128
    Shop #: WSC 06325 000 00000
    ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
    ROD: EV_ECM30TFS0218K0907551D.rod
    VCID: 32611F81651B5F8E527-8067
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
    Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
    Component: ESP8 quattro H04 0050
    Revision: -------- Serial number: --------------
    Coding: 280D1A
    VCID: 82010F411D3BAF0E027-80D7
    Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
    Part No SW: 8K0 907 064 CG HW: 8K0 907 064 CG
    Component: BCM2 2.0 H05 0431
    Revision: 00002001
    Coding: 0F0100
    VCID: 77F7EE95C6F97AA6A59-8022
    Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
    Component: J764 ELV MLB H37 0042
    1 Fault Found:
    00955 - Key 1
    002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 9
    Mileage: 81135 km
    Time Indication: 0
    Date: 2014.11.23
    Time: 14:09:29
    Address 08: Auto HVAC (J255) Labels: Redir Fail!
    Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
    Component: KLIMA 3 ZONEN H08 0180
    Revision: C1000000 Serial number: 01180920100984
    Coding: 66102000
    VCID: 800505491337BD1E143-80D5
    Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
    Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
    Component: BCM1 1.0 H30 0392
    Revision: 10030001 Serial number: 00000000652848
    Coding: 26009011003CAF212600000300003D0D4F9C92480201016100 0000
    Shop #: WSC 06325 123 12345
    VCID: 3C7D31B9BF5F99FE88B-8069
    Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
    Component: WWS 150910 H06 0070
    Coding: 00FD11
    Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
    Component: RLS H04 0003
    Coding: 025028
    Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
    Component: E1 - LDS H08 0090
    Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
    Component: HOMELINK H01 0010
    Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
    Part No SW: 8K0 919 475 Q HW: 8K0 919 475
    Component: PARKHILFE 4K H06 0070
    Revision: 11001001 Serial number: 51201026500657
    Coding: 30000D
    VCID: 47975E55F699CA26159-8012
    Address 15: Airbags (J234) Labels: 8K0-959-655.clb
    Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
    Component: AirbagVW-AU10 H41 0610
    Serial number: 003GLD0GJ2TX
    Coding: 303937354230303030304A55304C384B3053
    ASAM Dataset: EV_AirbaECUVWAUDI010 003010
    ROD: EV_AirbaECUVWAUDI010_AU48.rod
    VCID: 458B545DC495D836E75-8010
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
    Component: BF-Gewichtss. H02 0040
    Serial number: 5810000R1000000W1P
    Crash sensor for side airbag; driver side:
    Serial number: 6334MSME54620F33B
    Crash sensor for side airbag; passenger side:
    Serial number: 6344MSME54615658E
    Crash sensor for side airbag; rear driver side:
    Serial number: 6352QSME656C4C02O
    Crash sensor for side airbag; rear passenger side:
    Serial number: 6362QSME626F080AP
    Crash sensor for front airbag; driver side:
    Serial number: 63732SME3B73183E6
    Crash sensor for front airbag; passenger side:
    Serial number: 63832SME10703828T
    Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
    Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
    Component: Lenks.Modul H17 0014
    Revision: -------- Serial number: 90304JIA000SJ
    Coding: 000016
    VCID: 3E793BB1A9438BEEA6F-806B
    Component: E221 - MFL H02 0010
    Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
    Part No SW: 8K0 920 981 Q HW: 8K0 920 981 Q
    Component: KOMBIINSTR. H08 0258
    Revision: 00000000 Serial number: EJG53JF9A
    Coding: 831D09008300D705020000
    VCID: 4183404DD8BDF416DBD-8014
    Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
    Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
    Component: GW-BEM 4CAN-M H09 0117
    Revision: EC000056 Serial number: 5600E1090780B6
    Coding: 00C303
    VCID: 830F0A450221A606091-80D6
    Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
    Component: J367-BDM H07 0170
    Address 22: AWD (J492) Labels: 8K0-907-163.clb
    Part No SW: 8K0 907 163 A HW: 8K0 907 163 A
    Component: 4 Wheel Drive H10 0025
    Serial number: 003108100001005
    ASAM Dataset: EV_AllWheelDiffeQSPCAN 003016
    ROD: EV_AllWheelDiffeQSPCAN.rod
    VCID: 2E590BF171237B6E36F-807B
    Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
    Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
    Component: MEM-FS H06 0074
    Revision: AA000000 Serial number: 00001002103842
    Coding: 00581B00000000000000
    VCID: 3B7F32A5BA519EC6811-806E
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
    Component: TSG FA H08 1401
    Coding: 011C13204E00410001
    VCID: 53AF7A0532C17686791-8006
    Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
    Revision: 00002001 Serial number: 0135139501
    Coding: 0106063A00FA444580B0013200000000
    Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
    Component: GTO BF H06 0050
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
    Component: J245 PS039 H06 0041
    Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
    Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK
    Component: DSP Prem H10 0190
    Revision: 00010001 Serial number: 34882004552501
    VCID: 7AF1F7A1F5EB67CEDA7-802F
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
    Component: TSG BF H08 1401
    VCID: 52A17F010DDB7F8E727-8007
    Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
    Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
    Component: EPB Audi B8 H09 0100
    Revision: 00000003 Serial number: 10000000610221
    Shop #: WSC 00000 000 00000
    VCID: 346D1999970F51BE40B-8061
    Address 55: Xenon Range Labels: 8K0-907-357.clb
    Part No: 8K5 907 357 B
    Component: Dynamische LWR H02 0010
    Revision: 00000001 Serial number:
    Coding: 0000004
    VCID: 397328AD706DACD693D-806C
    Address 56: Radio (R) Labels: Redir Fail!
    Part No SW: 4G0 035 082 G HW: 4G0 035 082
    Component: Radio U SIRIU H51 0133
    Revision: AB001007 Serial number: 471I%0A7529436
    Coding: 020007010000000001
    VCID: 244DE9D927EFC13ED0B-8071
    Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
    Part No SW: 8T1 035 664 F HW: 8T1 035 664 B
    Component: H-BN-NA H49 0189
    Revision: -------- Serial number: 490I40A7583467
    Coding: 010200000206E1EF45000F0E000000030000
    Subsystem 1 - Part No: 8R0 060 884 P
    Component: NAR 2010 0407
    Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
    Component: DU7 High H43 0098
    Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
    Component: E0380 Bedient H08 0100
    Subsystem 4 - Part No: 8R0 060 961
    Component: CD-Database 1886
    Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
    Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
    Component: TSG HL H06 1401
    Coding: 010C13204000210001
    VCID: 56A98311213363AE9EF-8003
    Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
    Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
    Component: J772__Rearview 0040
    Revision: --H04--- Serial number: 525PA8-J0791BY
    Coding: 1000006
    VCID: 38752DA94B67B5DE6C3-806D
    Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
    Component: TSG HR H06 1401
    End ---------------------------------------------------------------------
    Dec 31 2004
    NJ / Miami
    does the car not start when you just tap the key in the ignition, but start when you press and hold the key in the ignition? if so, replace the key battery (key battery getting worn out), then report back.
    2000 B5 A4 Quattro
    2014 B8.5 S4 DSG
    Apr 22 2014
    Kelowna
    I never put the key in the ignition and the battery is new
    Dec 31 2004
    NJ / Miami
    hmm, doesn't hurt to give it a shot next time just to rule out the simple stuff. i dont want to condemn anything expensive just yet.
    edit:
    and you are talking about the key battery right? not the regular battery? just want to make sure. i only see "lower limit" faults in the access/start modules when key batteries go bad.
    2000 B5 A4 Quattro
    2014 B8.5 S4 DSG
    Apr 22 2014
    Kelowna
    Yes it was the key battery and not the regular car battery haha. Come to think of it, that may have been the day that I tried the second set of keys and it complained about the fob battery. Either way its been good the last few days, but I've been pushing the pedal extra hard to the floor.
    Apr 22 2014
    Kelowna
    I will try putting the key in the ignition though like you suggested
    Established Member Two Rings Dubber4life's Avatar
    Nov 08 2009
    New England
    I've had this exact issue happen to me (2010 model) about a year ago. It's a known issue and there's a TSB for it. Basically 1 of 2 things has happened, either a) your throwout bearing has failed, or b) your clutch has worn down enough for the throwout bearing to no longer fully disengage clutch. In my case it was the throwout bearing that failed, and in that case if your car is still under warranty it will be fixed for free under warranty. If they find signs of excessive clutch wear or abuse then you would get stuck footing the bill. In your case it doesn't really matter since the car is now out of warranty. I can try and find the TSB number from my invoice when I get home later and post it.
    Cesar
    2010 S4 | 6MT | Prem+ | Quartz Gray | Black/Brown Nappa | Nav | Sport Diff | B&O | Stainless Steel Inlays | 19" Wheels
    Mar 05 2010
    ATL
    My car has recently started to do this again. Except it doesn't say depress clutch to start.. instead it just turns acc. On and when I renegade clutch pedal and press key in it starts fine. I'm out of warrenty and don't want to deal with anything. Could it be the clutch is warn? Have 55k on an 11 s4 doesn't slip ever.
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    I have 80,000 on stock clutch I do not have this issue. My throw out bearing did fail when I was under warranty.
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Apr 22 2014
    Kelowna
    TSBs are still fulfilled outside of warranty aren't they?
    Apr 23 2009
    Forked River nj
    No really depends on the service department. They do not have to.
    Past
    Feb 13 2004
    S Ã C, CÃ*
    This is exactly what mine does. Some days i dont have to jam the pedal down, most i do. Its been like this for a good 20k for me now, i have just grown to live with it till i get the clutch replaced. Its not the switch at the MC, since that would trigger the press clutch pedal to start. The only thing i have read is replacing the clutch fixes this issue, how it does, i dont know. I tried to look for another switch, but never found anything. My clutch still grabs perfectly fine.
