I've searched and searched and have not found one successful thread where someone has changed the coding, I've replaced my module and recoded it to stock successfully. This summer I installed b6 s4 front brakes on my car and I've found the front brakes are very grabby causing the abs to come on in wet and even sometime dry conditions since they grab so well, I have driven the car once since its snowed and it sits in my garage because even with blizzacks on it the lightest dusting of snow the abs goes off trying to stop where my b5 with snow tires I can stop way faster.
Obviously this is a bias issue as everything in the front is new and it doesnt pull any which way, eventually I'd like to swap in b7 a4 rears when its time to replace my rear brakes but in the meantime I'd like to make my setup work as is. In my last hour of searching I've read that certain part number modules won't take certain coding and that the b6 a4, b6 s4 and b7 a4 all use different p/n abs modules and I'm scared to try coding it since the damn thing is so touchy I don't want to render my abs totally useless in the event it doesnt take the coding and fuck up.
My car is a 2002 1.8t quattro m/t stock coding is 04275 I've read that the brembo option is for the s4 brakes but the fnr option is b7 a4 brakes however the s4 uses the same caliper as the b7 and I can't find any hard proof which code to use.
If anyone has any insight feel free to post it and I'll give it a shot, worst case I'll code it to b6 3.0 312mm brakes and hope it makes a difference.
