What's a good color for valve covers. What's everyone paying for powder coated v-covers & where. My car is brilliant red. Some time in the future I'll have a wrinkle red manifold
05' B6 S4 Brilliant Red 6MT: JHM 93 Tune ● JHM Ported Manifold w/spacers ● JHM Lightweight Pulley ● JHM Lightweight Flywheel ● JHM STG3 Clutch ● A.W.E. Catless 2.5" Downpipes ● Custom 2.5" Corsa Non-Res Exhaust w/x-pipe ● KW V3 Coilovers ● Stern Adjustable Upper Control Arms ● JHM Short Throw Shifter
00' B5 A4 2.8 5MT: Gone
PAST 2004 Audi S4 4.2L 2006 Audi S4 4.2L 25th #167
2015 Audi B8.5 A4 2.0T P+ S-line JHM K04-R Turbo 3" HFC/Downpipe FMIC Stage 3 K04 ECU and Stage 2 ZF8 TCU tunes ECS-Luft-Technik CIA/Air Scoop/Silicone Intake Tract GFB DV Bilstein Sport Struts/Shocks H&R Sport Springs 034motorsport Catch Can Kit D/L Control Arms/Bushing Rear Sway Bar with Front/Rear End Links 15mm-F/20mm-R Spacers Bullet Nose Studs/Nuts RS4 Honeycomb Mesh Front/Fog Light Grilles
TGM C7 S6
DG B6 S4
2017 Colorado Z71 Duramax
2006 Triumph Daytona 675
18 Catalunya RS3 Unitronic Stg 2/TCU Stg 2, APR DP & Intake, CTS Intercooler, 034 MPs, ECE Dogbone (0-60-3.18 : 1/4-11.16 on 98 RON) & 05 S2000 w/ ITB setup
Gone, but not forgotten- 19 C43 AMG / 12 Abarth (full bolt on) / 07JHM SC'ed / 08 Evolution X (full bolt on) / 05 M3 Dinan SC'ed / 05 LGT w/ Hybrid Turbo ......and many others!
"Bitches... Come over here and have sex with Charlie Murphy" ~ Rick James
SUSPENSION-KW V3-Hotchkiss RS4 sway bars-034 Adj UCA-034 strut mount-034 F&R end links-034 motor mounts-034 Snub mount W/bracket-034 Trans mount l BRAKES-ECS Stage 4 BBK-ECS rear rotors & lines, Hawk pads l Engine-JHM Tune-JHM 6 rib pulley-Milltek catless DP's-FI exhaust l EXTERIOR-RS4 black grille-Custom headlights-LED city & DRL lights-ECS LED tail lights & plate lights l INTERIOR-Custom steering wheel-SRP pedals-ECS LED lights-MOMO shift knob-Gen 2 RNSE & AMI l WHEELS-OEM RS4 W/ Michelin PSS
Forget the B8, keep the V8!
My engine rebuild: http://www.audizine.com/forum/showth...Engine-Removal
JHM Lightweight Flywheel--Stage 4 Clutch--034 Street Density Engine Mounts--034 Street Density Transmission Mount--034 Snub Mount--034 Zero Tolerance Bracket--USP Metal Slave Cyl/Metal Clutch line--JHM Short Throw Trio Package--JHM intake Manifold Spacers--JHM tune 93 octane--2.5" 200 cell downpipes--Magnaflow catback--Avant Garde M310 18" Rims--Cross Drilled, Slotted Rotors
2007 RS4 Avant
2006 A4 2.7 MT Avant
2007 A4 2.0 AT Avant
2013 Q5 3.0 AT - Wifes
RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
Current- B8 A4 2.0t S-Line Stasis Challenge Extreme Edition, Alcantara Headliner, ALA/ACC and 3g+ swap
D3 A8 4.2 Black/Peanut (Daily)
