Results 1 to 19 of 19
    Sep 27 2014
    Sweden
    Max boost at k04 setup?
    What will you say is max safe and efficant boost on k04's?
    My setup is:
    K04-015 turbo, modified alittlebit of a company here in Sweden
    3'' downpipe with no cat
    3'' exhaust
    Saab/Opel C20LET 380cc injectors (red top)
    Stock 4bar fuel pressure reg
    3'' MAF
    Proper software tune from a tuner in Sweden.
    ADR cam-shaft's
    Forge 008 valve
    Uprated silicon hose from LMM til turbo
    Castrol 5w40 magnatec oil, change every 5000km/3100miles.
    Mine is running about 23psi/1.6bar at 4000rpm and hold 18-19psi/1.25/1.3bar at 58-6000rpm..
    I do not run trackdays or something, just regular streetdriving..
    Will it be safe?
    Have been running like this since about July, no problems yet..
    Car is running pretty well, do leave 'regular' k04 setups behind and I'm not very far from GT28 setups.. (with stock rods)
    Sep 09 2012
    Austin, TX
    Quote Originally Posted by amx2k View Post
    My setup is:
    3'' exhaust
    3'' MAF
    ADR cam-shaft's
    Forge 008 valve
    Will it be safe?
    23 psi is generally considered the upper limit of the K03/K04 without E85 or meth. You are pushing it, and a good FMIC and/or WMI would definitely help things. I wouldn't go over 23 psi, though.
    "Yep, you're a raper" - redline380
    Aug 23 2011
    Erie
    When I had a ko4 I turned it up til it wouldnt go up any more! Just made sure I was getting enough fuel and keep turning it up... I ended up w 27psi tapering down to22-23 if I remember correctly
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    That seems fine, but probably the highest boost I would choose.
    What is your intercooler setup? I think the biggest "problem" with running too much boost on a K04 frame turbo is high IAT, but a proper intercooler will help.
    2001 Corvette (C5) Z06
    Sep 27 2014
    Sweden
    At the moment, when it's about -10 degrees Celsius here in Sweden, the stock one, can't see that the IAT are very high, about 25-35 degrees at the most with these temps we have here now.
    Are these 380cc injectors big enough?
    Have testet with a wideband lambda at the A/F ratios was about fine, that was on 1.4bar than..
    I don't have 1.5-1.6bar for a long time, maybe just a sec or something before it drops a littlebit..
    Veteran Member Four Rings DiertyEuroSpec's Avatar
    Aug 21 2009
    Fairfield County, CT
    Get bigger intercooler. You will need it when summer rolls around.
    2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA | RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    What is the maximum injector duty cycle? If your maximum injector duty cycle is above around 80%, then your injectors are too small.
    Sep 27 2014
    Sweden
    I will get a bigger intercooler soon, had order one, but got the wrong kit so returned it.
    My IAT is not so bad? What is the MAX in C for IAT ?
    I have not seen at the duty cycle for the injectrors yet, will take a look tomorrow..
    Senior Member Two Rings rockersteady's Avatar
    Apr 10 2011
    another 4x AEB B5 1.8t QM , a b6 QM and b5 S4
    Sydney Australia
    Ill chuck in my 2 pennys
    Can you elaborate on the K04 you have fitted?
    You asked max boost and max efficiency. They are different. You want to make the most HP or most torque?
    Max boost for efficiency (and biggest area under the torque curve) will be about 18psi on a modified k04 tapering to as low as 12psi at limit 5800rpm.
    This will also achieve Best HP (and greatest torque area) by restricting/ holding n75 duty cycle to 80% . You need to let some gas out of the cylinder head and restricting it thru the k04 outlet will only raise reversion. (Exhaust gas cant get out, mixes back in the cylinder, will over heat, will raise cylinder temp, and cause knock = HI boost but LOW torque)
    You can run higher boost and achieve a higher torque figure but it will output short bursts only.
    The secret is less boost allows you to run more timing and this will generate more torque for the longest time on the small turbine turbos.
    99.5 QM, 2.0 stroker EFR 6758 e85 at 7 bar, 413 Bosch fuel pump in 034 Surge tank. Miltek 2.75, CM 240mm fx400 x 6, koni CO's, Stoptech BB, stealth V8maf in stock airbox, VVT upgrade,
    Concept, build and tune by Quattro motorsport
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    Most of the J31 K04-15 (2000 A4) owners were pushing 25-30psi, the K04-15 tends to do best at 25psi. No matter what, after 20psi the K04-15 really can't hold that boost to redline so the boost tapers in the upper rpm.
    Jun 08 2011
    Stillwater, MN
    Quote Originally Posted by M-Hood View Post
    Interesting. I wonder why Dave with Motoza said 18psi is what my 01 is best at then? We've done numerous logs at different settings and that's what he found as optimum. Any input?
    2001 A4 1.8T Quattro Manual Brilliant Black-Motoza e85 K04 Tune on 550cc Bosch Injectors and 4BAR w/ Borg Warner K04-15 running 21PSI-FastWayRacer Ebay FMIC w/ 2.5 Piping-OEM N75-Axiom Performance 255LPH FP-3" Eurocode Tuning Test Pipe-2.5" XS-Power Exhaust-UPGR8 TIP-710N-Single Mass Valeo Clutch-Green Coolant Temp Sensor-Standard OEM Plugs-Standard-OEM MAF-Rare 17" Alloy Wheels From Romania
    Jun 08 2011
    Stillwater, MN
    Quote Originally Posted by rockersteady View Post
    Yup, near redline my K04 setup is around the 12psi mark, but definitely feels healthy all around.
    Sep 27 2014
    Sweden
    I don't have any more information about the k04-015, than it's been modifyed, I see about 1.25-1.3bar/18.1-18.8psi at 6500rpm, that's a littlebit more than a regular K04 does I think?
    Have been racing against another A4 with a regular k04, and I did left him good behind.
    I have got my hands on this intercoolerkit for a low price, will I make any big difference in performance after mouting this?
    I had FMIC on my last A4, that was only chipped and 2.5'' exhaust, can't say I felt so much difference after I fittet te intercooler to that car, but that was just chipped k03, 16psi..
    I do want to make as much HP as possible, I'm on stock rods and clutch so the torque is not so important, if you understand what I mean.
    Sep 27 2014
    Sweden
    Not many answers to get here.. Are you all sleeping guys?
    Sep 09 2012
    Austin, TX
    Considering the boost you are running I would say you will see a benefit. Lower IATs mean denser air means more power. Plus it will be less prone to heatsoak in the summer or after harder runs, so you will keep your performance day in and day out.
    It wouldn't be a bad idea to invest in water-meth injection while you are at it. That will cool things down substantially.
    Sep 27 2014
    Sweden
    Water-meth injection is not very normal over here, what does that do ?
    Veteran Member Four Rings B5nDisciple's Avatar
    Aug 23 2014
    2006 Honda Odyssey--Cannondale Caad 12--Giant Talon
    Tucson
    https://www.youtube.com/watch?v=HkPFZWd8wj4
    Then Jesus said, “Come to me, all of you who are weary and carry heavy burdens, and I will give you rest." Matthew 11:28
    Sep 27 2014
    Sweden
    No I don't wanna bother with that, could easy installed another turbo than..
    Aug 23 2014
    Tucson
    Well it's a good alternative to getting a new intercooler which could actually cost more depending on what setup you went with. The only drawback (IMO) is having to make sure the tank is filled all the time. For me it would only make sense to have water-meth as a dedicated track car or weekend warrior. But some people run it in their daily and just get used to the extra fluid type to keep tabs on. You can use a proper windshield wiper fluid, so it's not hard to come by.
