Results 1 to 17 of 17
    Jul 20 2009
    Current- BMW 335, Jeep Rubicon, Jeep Grand Wagoneer, Past- 02 Audi TT, 04 Audi A6 2.7T S-Line,
    Middle Tennessee
    Coolant Temp Sensor location 3.0
    For the life of me, I cannot find the Coolant Temp Sensor (the one on the radiator. Not the ECT) on a 02 3.0 Avant. I've used the search tool to no avail. Can someone guide me to the right direction?
    Dec 10 2009
    B6 A4, B8 A5, ML350 Bluetech
    Verona, NJ
    #35 or #45, One is a sensor and the other is a plug. Not sure which one is actually the sensor.
    Dec 10 2009
    Verona, NJ
    Quote Originally Posted by Spike00513 View Post
    ...What?
    That's not even a 3.0 engine...
    There are two CTS's? I thought it was just one at the back of the motor that people commonly replace with the updated/revised green-top?
    That is a 3.0 6 cylinder engine.
    Yes, there are 2 sensors, one is more prone to failure. #3 is the GREEN sensor most people replace, the BLACK sensor is either at position 45 or 35, one is a sensor and the other is a drain plug.
    Veteran Member Three Rings john_gonzo's Avatar
    Feb 03 2009
    Florida
    Jul 20 2009
    Middle Tennessee
    Your picture does not have a 3.0 engine. It has the 3.0L V6 TurboDiesel offered in Europe on cars like the A5, which is very different. What OP is looking for is for the NA-market, naturally-aspirated V6 3.0 aluminum block w/ iron liners. I assume this matters.
    I believe "ASN" is the engine code for the 02' 3.0, and here is the "Coolant System" diagram I found on ETKA for that engine. I assume it applies to all of the 3.0's, whether they be ASN, AVK, and so on.
    #4/5 is the drain plug.
    According to ECS Tuning, there is only one CTS, and that is the one behind the engine that people replace with the updated green-top.
    OP's location is Tennesee, so I assume he has the NA 3.0 and not a turbodiesel european 3.0 that came out after the B6 stopped being made.
    That is correct. It is it the 3.0 non tdi. I'm looking for the Grey or the sensor at the radiator. I see on the diagram that #45 is a drain plug and no sensor.
    Mar 14 2010
    Q7 3.0T & 911 C4S
    Wyoming
    My 02 3.0 has no sensor there either. Just a plug.
    Daniel J
    @gtg_drives
    Jul 20 2009
    Middle Tennessee
    Quote Originally Posted by DEPECHE View Post
    This is what I was referencing.
    Jul 20 2009
    Middle Tennessee
    So where is the sensor on the v6 3.0?
    Mar 14 2010
    Q7 3.0T & 911 C4S
    Wyoming
    CTS is located behind the passenger side head between the firewall and engine. Green sensor is the only one on the 3.0 avk.
    Daniel J
    @gtg_drives
    Jul 20 2009
    Middle Tennessee
    Thanks for the clarification. Its odd that ECS Tuning and other part stores list the "grey" 2 pin sensor (lower radiator hose) for along with the green 4 pin sensor (ETC) as parts for the 3.0
    Aug 27 2013
    Philly
    Quote Originally Posted by newvances View Post
    That is strange. We have the one green one, and then a low coolant sensor in the coolant tank. Thats it. What is wrong with your car that you are changing these sensors?
    Jul 20 2009
    Middle Tennessee
    Quote Originally Posted by SJorge3442 View Post
    My fans are running on high while the car is running and they continue to run for up to 5 min after the car is turned off. This is causing battery drain. I checked the relays and they look brand new. Relay box is bone dry. Temp gauge is reading normal. Heater is blowing hot as expected. I was going to change temp sensors before I spent the money on the Fan control module. VCDS shows no codes. I'm open to suggestions.
    Nov 11 2010
    Rochester, MN
    I happen to have one of those grey sensors from ECS Tuning, as I decided to replace them both as preventative maintenance...only to discover that my 2003 3.0 AVK does not have the grey sensor. It just has a plug on the bottom.
    19" B8 S5 Peelers
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    I don't know where exactly, but there is a way to read the temperature reported by the sensor via VCDS. It has two thermocouples in it, one goes to the cluster, the other to the ECU, so the cluster can have the proper temp, and the ECU can get a different reading. That would be the only way to really confirm the sensor is bad. Given the low cost though, you're only really saving yourself the aggravation of changing it out. I hope that it the sensor will fix it for you though.
    Jul 20 2009
    Middle Tennessee
    Thanks for the feedback. I have started the removal of the hoses, and the plate to get to the sensor. Unfortunately, the crankcase vent hose crumbled in my hands and now I have to replace it too....
    Aug 27 2013
    Philly
    You can replace this whole system with the appropriate sized heater hose and brass fittings from Lowe's!! Save your money and spend it else where. those replacement kits are super expensive. Find the user JohnGonzo on here and check his pictures. He's done this sucessfuly.
    Feb 03 2009
    Florida
    You can replace this whole system with the appropriate sized heater hose and brass fittings from Lowe's!! Save your money and spend it else where. those replacement kits are super expensive. Find the user JohnGonzo on here and check his pictures. He's done this successfully.
    You said it!
    I used heater hose with 3/4" internal diameter. The extra elbow mentioned in the first pic is visible in the second and third pictures.
    My PVC tubes had this yellow slime inside.
    The same slime was thick inside the valve covers. The covers have baffles that can be pried out for cleaning.
