Results 1 to 8 of 8
    Senior Member Three Rings tangcla's Avatar
    Sep 22 2011
    Melbourne, Australia
    What does this warning mean? Flashing exclamation mark, three beeps
    So I notice occasionally when I start my car, and when I go around corners in a spirited manner, that I get three long beeps, and the red exclamation mark on the dash cluster lights up (the handbrake one). No error codes on the scanner; what does it mean, and how do I make it go away?
    www.tangcla.com - photography
    Canon 5D Mark III x2 | 16-35mm f/2.8L | 24-70mm f/2.8L | 70-200mm f/2.8L IS
    100mm f/2.8L IS macro | 200mm f/2.0L IS | 580EX-II x2 | 430EX-II | PocketWizard TT1/TT5
    Jun 23 2010
    Athens, PA
    Top off your brake fluid is my guess
    Senior Member Three Rings B6cool's Avatar
    Oct 23 2012
    tricycle
    ^^^^this
    19" BBS CK wheels, Bilstein PSS9 coilovers, 034motorsport front adj. control arms and rear swaybar, Vw Brembo 4-piston front brakes, b7 rear brakes, StopTech SS Brake Lines, Sprint Booster.
    Buy my parts PM me - for sale b6 s4 front brakes Tyrol sport stiffening kit, kW v1 coils. Usp front valance unpainted.
    Sep 22 2011
    Quote Originally Posted by AudiNFS View Post
    Oh right - thought it was something more complicated than that, haha. Thanks :)
    Sent from my SM-G900I using Tapatalk
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    Is it the same warning that comes on when you drive with the handbrake pulled a little ?
    If so , it could be the micro-switch for your handbrake light that needs to be adjusted/replaced, since it only happens when you're doing some ''spirited driving'' ?
    Jun 07 2013
    West
    Quote Originally Posted by tangcla View Post
    Check the owners manual.
    Feb 18 2014
    Arizona
    ^^^^ and be ready for a brake job soon. the fluid in the reservoir drops a little as the pads wear out, if it's low enough to give you that warning then the pads are probably pretty thin
    Sep 22 2011
    Thanks guys, it was just the brake fluid being low. It was above the minimum but it only triggered on certain inclines and turns.
    Pads were changed to new ones not too long ago, but will keep an eye on them.
