Originally Posted by
aluthman
Great info but I think you maybe missed what we're trying to do. We've got EA113 engines and are looking at using some of the newer injectors in place of our older hdev1 style injectors, not the other way around.
Sorry for the late reply. I understand what you are trying to do by using an HDEV5 injector in an EA113 platform engine. That is why I noted the difference in drive currents between HDEV1 and HDEV5.
Remember that GDI injectors are flow classed at 100bar (industry standard). When we test stock injectors we prefer to use the vehicle based drive profile. This gives the most accurate data for the flow curve.
If you are re-purposing an HDEV5 injector and driving it with an HDEV1 drive profile, it may not flow as much as you think. ("HDEV1 use a low pull in current, only 6-8Amps. While HDEV 5 uses 11-12Amps.") The HDEV5 injector may not open as quickly or as much (as it should) with a lower drive current. Inversely, you may want to try driving the HDEV1 with a higher current to see how much you can squeeze out of it by increasing the opening speed and the maximum lift. If you are able to get to drive current, then you can change the drive profile in the EA113 to run the higher HDEV 5 drive current profile. If you tell us the injector drive data for EA113, we can test some of the HDEV5 part numbers at that profile to see what happens.
I have some part numbers that canadianA4B7 sent me and from some our own search. But our bench is busy with GM LT injectors right now, so it may take a few weeks.
There were some questions about spray patterns. The HDEV 5, overall, has much better spray plume quality than the HDEV1 (when compared to particle distribution and average particle size).
If anyone has any other info we can use for testing injectors, please let us know.
-Frank
