Originally Posted by
Koyin
Can anyone share how to install the front bracket? I need to replace my old broken bracket. I got the two small metals with it which I’m confused how to use them. There is no instructions anywhere as to how to install. Any information would be appreciated.
So the "metals" you are referring to - Is that the spring nuts? the parts that slide over the plastic tabs and give the screws something to grab? If you kneel down in front of the Audi rings (and pray to Audi gods for making such a kick ass car), look about 2/3s the way down the grill, lower than center and you should see two tabs "about" where the middle of the license plate would be. Slide the spring nuts over those tabs. It should be self-explanatory from there if you are using an OEM license plate bracket. You can see how the screws mount.
Short of a video on how to install, look for one on how to remove and reverse - engineer it?
https://www.youtube.com/results?sear...+plate+bracket
