This is the second time happening to me and it bothers me a lot. Here is the back ground.
2007 s4 with just less than 75k miles. I use mobil1 0w-40 with oem filter every 4k miles. I don't see any blue smoke at start up. There are no oil leaks. I park it in my garage and it is spotless. Which means it's burning it but not during start up. I don't floor my car either. I do tend to drive my car aggressively but I rarely rev it up to redline. Most I will go on normal driving is 5k and that's rare too. I stay under 3500rpm most of the time. My commute is 10miles each way and I take local street to get to work and take the freeway on my way back.
About 10-20k miles ago my oil minimum light came on after 4k miles of driving. I wasn't 100% sure if I put 9.5qts of oil when I did oil change prior to the light coming on so I decided to just keep an eye on oil level. Fast forward to today. It's been about 3800-3900miles since oil change and my minimum oil level light turned on again. My car is modded but nothing to cause the oil burning. Well I don't think its causing it. Piggies, cat back, JHM intake manifold, JHM ecu...
So what is causing to burn oil? How can I diag to find out what parts are causing it? What can I do to make sure it doesn't burn more than .5qt per 4k miles???
I did notice some people are saying our engine just burns mobil1 0w-40 oil. Is it possible that our engine just doesn't get along with m1 0w-40? anyone having issues with m1 oil with our car?
