Page 2 of 2 FirstFirst 12
Results 41 to 56 of 56
  1. #41
    Veteran Member Three Rings DoItAllGarage's Avatar
    Oct 29 2013
    WA to ID
    I'm also looking at lifts. I just don't have the room for a 2 or 4 post lift, so was thinking about a scissor lift or quick jack. I know with a scissor lift it may be difficult working on the drivetrain and exhaust.
    Sent from my SM-G930V using Audizine mobile app
  2. #42
    Senior Member Three Rings migo1980's Avatar
    Sep 05 2007
    Raleigh, NC
    I had an HD9-xw *extra wide loved it never had any issues. $250 for the dedicated circuit and $800 for the lift install and $3000 for the lift. Best money I ever spend on a garage.
  3. #43
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Yes it limits more than a two or four post lift for sure. With the taller lift pads you can gain access. There are versions of scissor lifts like the MDS‐6 that have open centers and can be parked on so they do not take up much space. They just cost more.
    I love my lift and it was worth every penny!
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
  4. #44
    Jan 04 2013
    Phoenix, az
    Lowest setting doing a fender liner.
    F3D4D0BB-9E89-4CBD-B2D1-ACE07C809DE3_zpsrqumxfxx by Victor M, on Flickr
    Highest setting because I can roll right under the car to work on motor, exhaust and steering rack.
    P6025611_zpsea172020 by Victor M, on Flickr
    Shot looking down the channel you can see it's still pretty open.
    P6025614_zps925b1843 by Victor M, on Flickr
    Sorry still learning to post pics from flicker, so links pulled
  5. #45
    Nov 12 2009
    2012 S4, 90 VW Corrado
    Louisville, KY
    Quote Originally Posted by DoItAllGarage View Post
    I went with a more expensive scissors lift like cspcrx mentioned, the Atlas Kwik Bay. Open access to the center and 13 lock positions.
    I built some wood ramps for mine. Bought it when I still had my A4, which was lowered on coilovers. The S4 at stock height will clear it without ramps, but there's no room to fit pads on the pinch weld lift points.
    https://photos.app.goo.gl/zCHMQV7E6fKfRXtC2
    I can have the car in the air in minutes. Only had it a year and a half, but should have bought one years ago. Money well spent
    2005 A4 USP (Gone)
    2012 S4
  6. #46
    Oct 29 2013
    WA to ID
    I will be forced to share the lift with my daily-drivers and my project foxbody, so I will need a lift I can transfer back and forth. If I wasn't in the middle of a project, I would go with the open center scissor lift. My last research is to find the correct quickjack length that will work for the A4, S7, and foxbody, if possible.
  7. #47
    Veteran Member Four Rings nefkntym's Avatar
    Jan 30 2007
    a bunch of tools
    Monument, CO
    Moved houses and reinstalled the Maxjax, right through Racedeck tiles. Has been like that for over 2 years now with no issues if anyone is on the fence.
    2023 Q7 - Ibis White
    2024 SQ8 - Chili Red
    So many have come and gone…
  8. #48
    Jan 04 2013
    Phoenix, az
    racedeck is good stuff, love mine.
  9. #49
    Oct 29 2013
    WA to ID
    Awesome garage!
    Sent from my VK815 using Audizine mobile app
  10. #50
    Jan 30 2007
    a bunch of tools
    Monument, CO
    Awesome garage!
    Thanks, since those pictures I have put in a lot of shelving, storage cabinets and a place to sit and work while you are doing work.
  11. #51
    Feb 04 2013
    aw11, 3x Starions, e70 X5, LMM dually
    Asheville
    I run a Bendpak scissor lift. Have hoisted a bunch of different cars on it. Only thing that doesn't fit is my wife's E70 X5 (due to where the jack pads are).
  12. #52
    Jan 30 2007
    a bunch of tools
    Monument, CO
    I like the StarQuest car. Loved those when I was in high school.
  13. #53
    Jan 04 2013
    Phoenix, az
    My buddy had a blue Conquest car was sick back then.
    I see your also running a rapid air system, or were at the time of the pics. I put one in earlier this year. LOVE IT! I did three air drops with reels so nice!
  14. #54
    Feb 04 2013
    Asheville
    I haven't installed the maxair yet :/ I've been super lazy and don't use air often. I have enough parts for 4 drops terminating at the middle of the two garage doors with a 20' hose reel.
    Re: Starquests, I actually have 3 black '88 SHP Starions.
    1 Automatic daily driver condition:
    1 title-less 5-speed parts car - turned 1UZ-FE VVt-i / A650e swap.
    1 5-speed parts car that's a runner as well.
    2011 A6 3.0t S-Line
    2010 S4 6-Speed
    2009 LMM dually
    1988 Starion SHP (times 3)
    1986 AW11 MR2 N/A
  15. #55
    Jan 04 2013
    Phoenix, az
    Very cool. You will love your MaxAir system once installed. I had been pulling all of the parts together for it for about a year and finally installed it just before the summer. I went with rapid air fittings and reels, those made a huge difference as well. You can actually hear it with the impacts!
  16. #56
    Veteran Member Four Rings miztahsparklez's Avatar
    Dec 19 2010
    North CA
    Quote Originally Posted by CardFan View Post
    How much more clearance underneath are you working with? Is there a lot of room in the middle between the sides of the car?
    I'd probably consider something like this so I don't have to drill into the slab.
